Question about TCL Recertified - 40" 1080p 60Hz LCD HDTV L40FHD
My tv has no volume and it is not on mute - TCL Recertified - 40" 1080p 60Hz LCD HDTV L40FHD
    Problem Solver:
  • 15 Answers
Try it in audio video,tuner,or maybe the unit speaker may have the problem.You can also try set the unit to factory reset..
Posted on Dec 04, 2012
Tv on mute no remote how can I turn mute off
If you have no volume control on the main TV, unplug the TV and then turn it back on. The mute should be cancelled. If you have a volume control, turning it up should cancel the Mute function. It does on mine.
Nov 02, 2015 | Televison & Video
How do you un-mute tv settings
Try pressing the mute (speaker symbol with diagnol line) or just press up/down volume button
Sep 08, 2014 | Televison & Video
Www urcsupport com
Does your TV have a "half-mute" setting:
* press MUTE once to reduce the volume to 50%
* press MUTE a second time to reduce the volume to zero
* press MUTE a third time to restore the volume to 100%
Jul 01, 2013 | Televison & Video
My philips srp5107wm/17 only changes the volume on my tv no matter what device i have it set on
The Philips remote is set to "push trough" the volume/mute to the TV for devices that typically don't have a volume function. Older versions of Philips remote used to allow you to select the device to push volume to, but for some reason this is no longer available (or at least I haven't found out how to). So here is the solution I used.
Teach (learning function) the remote to use whatever device you like for volume/mute.
1, Press the button for the device you would like to change
2. Hold down "learn" and the button you want to teach ex. "volume up" until the red light comes on
3. Place the original remote of the device you would like to change the volume on 5-10 cm away from your Philips remote and press "volume up" for this example
4. Repeat these steps for the "volume down" and "mute" buttons
5. Repeat these steps for other devices you would like to "push through" volume/mute to a device other than TV
Hope this helps others. I did find that some devices like SAT may not allow you to change the volume/mute, but otherwise this workaround does the trick.
May 05, 2012 | Philips SRP5107WM - Universal remote...
I turned on the tv this morning and there is no sound.
Make sure the TV isn't muted. Some times, the cable/satellite can have a seperated volume control. Check to make sure that isn't muted as well. And last, make sure, if you have a home theatre system, that it isn't muted.
If you have multiple systems and each control volume, chances are, one of them has been muted which affects another.
Mar 10, 2011 | Sanyo DP26649 26 in. TV
Mute is on won't shut off.
Tries pushes the volume button up on the remote or the tv volume manual button + - the mute,will go away,the mute button on the remote don't work?The tv remote crontrol is dying.
Feb 03, 2011 | Panasonic Televison & Video
"muting" shows up the screen and I no longer get volume, can not the muting off as I can not see where I would change that setting.
Are you sure it's not the TV telling you that it's muted? I went down the tubes on that one myself.
The receiver's Mute can be defeated by just rotating the volume knob upward. Ditto with TV's.
May 11, 2009 | Pioneer SX-205 Receiver
Toshiba Regza 32C3000A tv sound keeps droping out, the mute button when pressed on and then off brings it back on. seems as if the tv is auto muting itself?
Could be a contact piece of the MUTE button from your remote that is causing it.
Go out and Big Lots or Radio Shack to get a cheap universal remote control(big lots would be between $5-$10) Pick up the code for it,and when the tv happens again,your the OLD remote MUTE button to turn it back on and then put away this remote control and use the new universal remote control.
However,if the problem is coming from the manual MUTE button on the TV,you need a repair tech, to fix it!
solutiondoct
Nov 10, 2008 | Toshiba Televison & Video
My volume sounds muted on my 36" toshiba tv, nothing is working
Good day.
Please check on the speakers of your unit. They may be busted.
chris
Mar 20, 2008 | Toshiba 36A40 36" TV
How do you mute tv but not headphones?
Look in your TV's menu options. I have an RCA TV which allows me to turn on (or off) the headphone port and set the volume of the headphones. Once you turn the headphone volume up, then you can turn the TV Volume all the way down with your TV remote while the headphone volume remains where you set it. Hope this works for you.
Feb 13, 2008 | RCA WHP141 Consumer Headphones
TCL Recertified - 40" 1080p 60Hz LCD HDTV L40FHD Logo
237 people viewed this question
Top TCL Televison & Video Experts
MegaByteMe
MegaByteMe
Tom Chichester
Are you a TCL Televison and Video Expert? Answer questions, earn points and help others
