Question about Motorola Mobility Triumph
Phone screen completely black
My phones screen is completely blank. I've tried turning it off and on and taking the battery out, but nothing is working. I can still tell that the screen works, I just can't see anything on it.
Is it a touch screen? Has it been dropped at all? If so, the internal screen could be busted. Sometimes the touch part will still work itll just be a blank screen though. You may need to order a new internal lcd screen.
Posted on Dec 04, 2012
pingping
  • 111 Answers
SOURCE: Everything works but no display
Ah! My friend. you are lucky that you ask the right person. I have fixed so many V551 with LCD defect so this symtom is usual on v551 and most Motorola Flip phones. As you know, the construction of the LCD cable has been designed by a long ellectric thin wire and one side will connect into the main and CallerID smaller LCD and the other end will connect to the main board and the part in the middle will stuck inside the hinge where the flip will apply a lot of force for the function of open and close. for a long period of usage, it will either worn out the middle part of the cable or loose the connection of either side which cause loosing display. That is why you can call and receive but cannot see anything. The simple thing is open the case and check first at the main board side for any bad contact and tougher the other side is inside the main LCD. If you find both side are still good in connection then the middle part is bad due to flipping so many time of the user in order to open and close. YOU THEN NEED TO REPLACE THE NEW LCD. I have two solutions to help you in this case: 1) View on the link below for the instruction of how to open the housing. http://sbarth.dyndns.org/seiten/rahmen.php?nav=motorolahandy Sorry the link is in German but you can look at the picture to follow. 2) Or email me at joe_dao2003@yahoo.com if you want me to repair the phone for you. I will charge you for only $10.00 for labor fee and $5.00 for shipping. I am sure to make your phne back to normal or your money back. My shipping address is below: JOSEPH DAO P.O. BOX 390307 MOUNTAIN VIEW, CA 94039 USA If you want other way to help, let me know. I am sure you will be happy with your phone back to normal. I hope this help
Posted on Apr 11, 2007
NickBeamAA
  • 53 Answers
SOURCE: Screen went blank
There is something you can try. Using a Torx 6 driver, remove the two screws located beneath the battery. Gently pry the plastic cover loose. There will be a flex cable connecting it to the other portion of the phone. Gently disconnect it. Using 99.5% isopropyl alcohol and a soft bristled brush clean the connectors on both the cable and the circuit board. Reseat the connector and reassemble the phone. If this does not work the flex cable or LCD may need to be replaced.
Posted on Sep 09, 2007
SOURCE: white screen`
I was having the white screen problem and what seemed to fix it was to take the back panel off, remove the battery and clean the connections.
Posted on Apr 23, 2008
SOURCE: RAZR 2 blank black screen
it seems there is a problem with your display flex cable, sometimes it comes loose and the lcd goes blank. you can buy a new one or get it repaired from a licensed shop, the motorola.com site lists some vendors you can got there to find one in your zipcode
Posted on Oct 23, 2008
  • 82 Answers
SOURCE: blank screen
That is a common defect in that model phone. You can call your service provider for a FRU replacement or contact Motorola at 1-800-331-6456 for repair.
Posted on Nov 13, 2009
The main screen on my Casio G'zOne Ravine (C751)
Let it charge for 24 hours before trying again. Battery may be too weak to light up the display yet.
Sep 24, 2013 | Cell Phones
LG Optimus blank screen
This sounds to me like the LCD Backlight has gone bad. You will need to get in contact with your carrier to inquire about warranty service or replacement.
Apr 10, 2012 | LG Optimus Black Smartphone
Black line appears and then screen goes blank
Your calculator is most likely fine electronically, but the contacts are being interrupted by contamination; it could be water or other fluid, dust, etc. The solution is to disassemble it completely and to rinse it out. Here are instructions for disassembling the TI-84 which should be similar.
http://www.instructables.com/id/Ti-84-Basic-Disassembly/
If there's water let dry completely before putting it back together. If pop, etc., rinse with isopropyl alcohol (99% alcohol) and let dry completely. The best thing is electronic contact cleaner, available in electronic, auto and hardware parts and supply stores and online. It must be 'safe for plastic' and 'non-conductive', and definitely NOT contain anything like ACETONE. These are harmless to electronics, and my be used to douse any device to clean up all types of contamination, including unseen carbon build-up from normal use. They dry quickly and leave no residue. They can be safely used in any other electronic device and to clean the contacts of old outlets, light switches, etc. -- anything with electronic contacts.
Try to rinse out all areas, especially where the screen makes contact with the main board. If there is any kind of crusty green build-up on the batter posts (due to battery acid corrosion), you may have to carefully rub this with a cloth until you see shiny metal.
Once you've rinsed all the available areas, let dry COMPLETELY (I place a blow dryer (low heat) next to drying parts for several hours to be sure) and put back together.
Mar 27, 2012 | Texas Instruments TI-83 Plus Calculator
Constant black screen on my galaxy S GTI9000
Solution-no but pretend that you are trying to get the phone right for the first time. Take the manual in your hand and do what you have to do to change the screen colour.
I do not know the prosydure by heart soI leave it to you.
Kolbrun
Feb 26, 2012 | Samsung Galaxy S GTI9000 Smartphone
Lg km900 blank screen during an incoming call -
There is a little rectangle shape thing next to the lg logo on the top of the fone screen. If this is blocked by screen protector it will cause the phone to blank of during calls. Its a power saver that blanks the phone when its near your face. Try it. Take off the screen protector & make a call. Then place your finger over the little thing & the screen goes blank. Just cut a lil space in the screen protector & that will fix the problem
Jul 15, 2010 | LG KM900 Arena Cell Phone
I ve just opened the box and turned on phone.Nothing on screen!
send it back. It sounds like even if your were to fix this by taking out the battery and putting it back in, it should not do that new. Get it replaced ASAP
Aug 29, 2009 | LG Prada KE850 Cellular Phone
Blank screen
Try taking out the battery overnight and then the next day put the battery back and turn the phone on. If the screen still doesn't turn on then it probably means the screen needs to be replaced or the cable connecting the screen to the phone board became loose or damaged. If this is the case, the phone needs to be serviced or you can try to open it up yourself and check the condition of the cable. Good luck.
Dec 10, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Motorola Mobility Triumph Logo
139 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
