Question about HP Officejet J4680 All-in-one Printer Wireless working
Reset hp printer to English
It is in another language that I do not know...It is suppose to be configure to English
SOURCE: HP Laserjet 3030 printer/scanner/fax Language has
How can i change HP laser jet 3030 printer's language?
Posted on Mar 25, 2008
printech
  • 159 Answers
press Enter bottom
press left arrow key twice
press enter key
select the language you need then press inter
Nikhil Gedam
  • 87 Answers
SOURCE: How to reset Language
When a super NVRAM init is performed, the all-in-one language and telecom country/region settings
are undefined. The user is prompted to set the language and telecom country/region. Until these settings
are defined, the all-in-one will not return to the Ready state.
CAUTION A Super NVRAM init erases all data that is stored in both the unprotected and
protected NVRAM memory.
To perform a super NVRAM init
1.
Turn off the all-in-one.
2. Press and hold down the * and 5 buttons.
3. Continue to hold down the buttons while you turn on the all-in-one. Hold the buttons throughout
the entire power-on sequence.
4. When Permanent Storage Init. appears on the control-panel display, release the buttons.
5. When prompted, set the language and telecom country/region.
6. Allow the all-in-one to return to Ready before using it.
Posted on Oct 30, 2008
wayneard
  • 1901 Answers
SOURCE: HP PSC 1610 Language reset
Press SETUP until you see 4. PREFERENCES. (Spanish-Preferencias) Press OK.
Press RIGHT ARROW until you see SET LANGUAGE & COUNTRY/REGION. (Spanish-Idioma & Pais) Press OK.
Press LEFT ARROW or RIGHT ARROW until you see ENGLISH. (Spanish-Inglés) Press OK.
When Prompted, press OK.
Press RIGHT ARROW to select the country. Press OK.
When prompted press RIGHT ARROW to select Yes or No. Press OK.
Here is a link to the User Guide. It's on page 93.
PSC1610 User Guide
Posted on Nov 25, 2008
SOURCE: I need to change the language back to English on
Press OK to open the control panel menus. Use the following to navigate through the menus.
  • Press the left arrow (c01683597.gif ) and the right arrow (c01683598.gif ) to scroll through the menu options on the control panel display.
  • Press OK to select a menu option. An asterisk (* ) appears next to the active selection.
  • Press the back arrow (c01683599.gif ) to return to a previous menu.
  • Press Cancel (c01235250.gif ) to exit the menu without saving any changes.
Using the instructions above select the System Setup Menu > Language control > select the desired language and press OK.
Posted on Apr 28, 2010
Change language from german to english on p3015
Hit the Menu button.
Arrow down to the 6th menu option which is Configure device. Hit OK.
Arrow down to the 3rd Option which is System Setup. Hit OK.
Arrow down to the last option. Hit OK and you can change the language to English. Hit OK.
May 15, 2012 | HP P3015 Laser Printer
How do I reset displaylanguage to english HP C6180
You can do a reset on your printer.Unplug the power cord of the printer.Press and hold the # and 6 buttons together and then plug the power cord back into the outlet.Keep holding the 2 buttons until the display goes blank or RESET is displayed.If the printer automatically turns off, turn on the printer.The printer should start up and you will be able to select language code.
Oct 26, 2011 | HP Photosmart C6180 All-In-One InkJet...
How to configure language setting from ferench to english
Hi
Delete french software . Go here and chose the appropriate unit model in " drivers and support "
Select OS and download english software / driver :.
http://www8.hp.com/us/en/support-drivers.html
Best regards ,
fanaudi .
Jul 04, 2011 | HP Designjet 5500 (42 in.) InkJet Printer
How do I change the language to english on The Hp Photosmart premium prinetr
You can reset the printer back to its factory reset and setup the language again. Follow the steps here Three Ways to Reset the PhotoSmart Premium Fax C309a All-in-One Printer. It is easier to do it from the hardware itself, easier to do it fresh from the start than navigating a language you can't understand. goodluck!
Dec 12, 2010 | HP Photosmart Premium C309A All-In-One...
Language
unistall the printer driver fully . connect the printer with a good cable to the printer and it will show that new hardware found through that you can configure your printer ..........
in that new hardware wizard you have to select have disk option.........give your CD path to get the file
Oct 07, 2009 | HP DeskJet 3325 InkJet Printer
A student has reset the menu to Russian.
My company uses nothing but HP printers some are connected to the network while others are locally connected to a computer. I have worked with this exact model.
First, the easiest thing to try is to power cycle the printer. Hold down the button to turn off then turn back on. You can also unplug it from its power source then plug back in.
Power cycling this printer should reset the language to default (English) or it will let you select the language when it comes back on. If that doesn't work then you can try to change it using the installed software.
Considering the fact that someone accidentally changed the language, I am assuming this printer is connected directly to a computer that you all have access to and this is not a network printer.
If this is a local printer (connected directly to the computer via USB or parrallel port) then you should have an HP Toolbox app or some other program that allows you to configure software related settings for the device. Open this tool and you should find an option for the language. This may not be available, depending on how the installation was handled (if it was installed using the CD provided by the manufacturer or installed using downloaded drivers).
Try this out and let me know if it helps.
Mar 26, 2009 | HP Color LaserJet 2600n Printer
Hp business inkjet 2600: do not know how to change menu language back to english
From the User Guide:
To configure the LCD control panel language
1 Ensure that the printer is turned off.
2 Press and hold Value on the LCD control panel and turn on the
printer.
3 Press Value to scroll through the language list.
4 Press Select to confirm the language selection
Dec 03, 2008 | HP Inkjet 2600 Printer
Laserjet 3600 HP printer in wrong language in display led screen
When you say writing, I assume you mean the language on the printer's display. Here's a step by step guide (since I assume you can't read the Japanese).
Press the blue Checkmark button to access the menu system. Press the down area twice which will give you access to the configuration menu. Press the Checkmark button to select this menu. Press the down arrow twice to access the system setup menu. Press the Checkmark button to select this menu. Press the down arrow 13 times (you can just keep pressing it until it gets to the bottom. It won't go any farther than the last entry) to get to the very last entry which is language.Press the Checkmark button to select this menu. The languages will be displayed in their native scripts. The first one is English. Press the Checkmark button to select English. And you are done. Press the U shaped arrow to get back to the main menu.
Sep 20, 2008 | HP LaserJet 3600dn Printer
HP Officejet J4680 All-in-one Printer Wireless working Logo
44 people viewed this question
Seeker5211
Seeker5211
