Question about Century Tool 2320I Heater
Century Dyna-Glo Propane Construction Heater, fan stays on?
I just bought a Century torpedo style propane heater from Lowes. This is the RMC-FA50C model, the smaller $99.00 unit. Fresh out of the box, I turned the control switch clockwise to the "off" position and then plugged it into the wall. The fan and the ignitor run constantly, even in the "off" position. I am new to this kind of heater and just wanted to make sure this unit is working correctly before I hook it up to the propane.
So the question is: Do the fan and ignition spark run constantly even when the switch is in the off position or is this unit defective?
Thanks.
  • gregg284 Jan 11, 2009
    I gave that a try. The fan runs full speed and the ignition sparks in all 4 switch positions. I am not sure if this is a variable speed fan either since all 4 switch positions have it running at what seems to be full speed.
  • Jyackle5
    Jyackle5 May 11, 2010
    Try turning the switch counter clockwise to turn off.
The heater is designed to continueously run the igniter , so as if there is a flame-out ,it will reignite the burner,and not dispurse unburned gas into your enviroment.
Posted on Jan 17, 2009
Did you figure this one out? The dyna glo propane heater is a pretty reliable unit.
Posted on Nov 07, 2010
I have a dyna glo RMC 40 NGT vent less wall heater that I would like to convert to propane, I need to know which conversion kit to buy, and where. Thank you.
dyna glo natural gas heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
dyna glo ventless rmc50 ngt can this heater be changed from natural gas to propaneuse, ... Dyna Glo Natural Gas conversion to LP Gas I have a Dyna-Glo natural gas space ... Question about D-E36 Infra-Red Wall Mounted Panel Heater ... dyna glo heater model #RMC-40GT I believe on your particular model , that you ...
Parts for Dyna Glo, Thermoheat and Dyna Glo Pro Heaters
spaceheaterparts.com/category.sc?categoryId=13
Shop Dyna Glo, Thermoheat, Dura Heat, Workhorse LP and oil fired htrs ... Circuit Board 2201181 Dyna Glo & Thermoheat 150k Nat Gas Htr RMC-FA150NGDGD ... This spark plug (ignitor) is used on Dyna Glo and Thermoheat 40K btu LP.
Propane Wall Heaters - Walmart.com
www.walmart.com > ... > Heaters
WalmartDyna-Glo IR18NMDG-1 18,000 BTU Natural Gas - Infrared Vent Free Wall Heater. $170. ... Dyna-Glo 40K Liquid Propane 360-Degree Tank Top Heater. $88.00 ... Dyna-Glo Deluxe RMC-FA125DGD Portable Gas Powered Forced Air Heater.
1352062 Dyna Glo Natural Gas conversion to LP Gas
162.220.53.34/F/.../t1352062-dyna_glo_natural_gas_conversion_lp_gas
Jan 12, 2016 | Heating & Cooling
Propane torpedo lights but doesnt stay lit
I'm confused. First you listed this as a propane torpedo heater. Second, it's a problem with and All Pro PK115 T Forced Air Kerosene Space Heater. And finally, you say "propane torpedo lights but doesn't stay lit."
Which is it? To really help you, I'll need the correct manufacturer's name & model number. And whether it's propane or kerosene fired?
Thanks.
Mar 02, 2011 | All-Pro Kerosene Garage Shop Heaters - All...
Unit will not lite
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Dec 26, 2010 | Reddy Portable Forced Air Propane Heater...
Need a control knob for: dyna-glo pro propane heater. model: # rmc-tt30dgp-01, # rmc-tt30dg, # rmc-tt30gd. this is the off/low/med/hi temp. control knob.
I AM TRYING TO FIND A PROPANE REGULATOR FOR A DYNA-GLO PRO. THE MODEL # IS RMC-TT30DGP. THERE IS A NUMBER ON THE OLD REGULATOR. THAT # IS S2NTT0002-2.THANK YOU.
Dec 17, 2010 | Heating & Cooling
Older torpedo style kerosene 50,000 btu smokes
clean out the fuel nozzle and if it wont burn cleanly, replace it.
Jan 03, 2010 | Heating & Cooling
Torpedo heater wont stay lit.
Do you have the serial number or the manufacture date? There are some design changes and I would need to know the year of manufacture to assist accurately. Usually it is a relay or the thermocouple connection that will affect the unit staying lit.
Mar 29, 2009 | Reddy Portable Forced Air Propane Heater...
I have a dyna-glo rmc-95-c6 heater it smokes and makes an awful smell  the flame is not as high as shown in the owners manual  what can i do to fix the problem?  thanks
You can buy the wick at Lowes. I have the same heater. They where $10.00 each so I bought 2. I will go back and stock up on them. Package Number DH-145 It will say it will fit RMC-95C thur RMC-95C7
Jan 24, 2009 | Heating & Cooling
Century Tool 2320I Heater Logo
906 people viewed this question
Top Century Tool Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you a Century Tool Heating and Cooling Expert? Answer questions, earn points and help others
