My paint ball gun shoots out all the air. and some times machine guns shoots and dis not stop i cant find out what is
SOURCE: I shoot 4-6 shoots and either the gun recocks and
Clean it and get a full fill on your tank.
SOURCE: Air is coming out of the nozzle but the paint is not coming out.
There are different filter screen sizes for different thickness of paint. Even with proper screen size one might need to thin paint. I hope this information is helpful. Please give a rating if this was helpful. Good Luck and have a Great Weekend.
SOURCE: air leakage from paintball gun
My first suggestion is to make sure your marker is clean, and properly lubed with a quality oil made for paintball.
Next would be to make sure you're checking with a full tank of air.
If lubing the marker doesn't fix you up, does it quit if you **** the marker? Not a condition you wanna walk around the staging area with, but it may stop the leak.
It can be an o-ring, and if it's been a while since you had any o-rings changed, it may be high time to get a set and change 'em all out, then you know they're all good to go!
Play hard, play safe, play with honor!
8^)
SOURCE: Paintballs will fall out of the barrel of my
Get another ball detente from ebay, this one is the cheapest one I could find.
http://cgi.ebay.com/NEW-TIPPMANN-C-98-BALL-DETENT-A5-BALL-DETENT-/370469346400?pt=LH_DefaultDomain_0&hash=item5641b19c60
SOURCE: when i put my paintballs
Sound like your ball detent is gone or broken.
The detent is a tiny piece of rubber that keeps the paintballs in the chamber and from rolling out the barrel. It's a cheap part, but you will need basic knowledge of disassembling a Tippmann 98 to replace it.
You can find ball detents here!
