Sw56app with DE message
Every time we go to use our washer, the message dE comes up. What is this and how can we remedy the problem?
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
On your Samsung washer, the "dE" error code typically occurs just after the rinse cycle. This will leave your machine filled with water as it does not drain because the washer thinks that the lid is open. Reset the cycle to properly drain the water then stop it before it fills up again.
Check to make sure nothing is preventing the lid switch from letting the cycle continue. Debris, such as lint or paper, could have fallen into the switch hole. Rust or an object could also block the hinges on the back of the lid. Clear anything off of the washer that may interfere with the lid switch then try to run the cycle again.
Posted on Dec 04, 2012
  • 489 Answers
SOURCE: DE error code
That is a door switch error problem.  The door latch is not sensing the door closed.  You may need to replace the door latch assembly.
Posted on Apr 28, 2008
  • 6 Answers
SOURCE: LG Washer dryer error dE
Unplug the machine.
Plug back in (maybe 10 seconds later).
Mine had several dE messages. Unpluged, waited 10 seconds, when pluged back in, it remembered which cycle and parameters I had it on, then locked the door and continued with no problem.
Posted on Apr 12, 2009
SOURCE: getting a display of DE
DE refers to a Door Error.
Please check the following link for more detailing on this.The solution is also mentioned in the same link.
click for detailing on DE error code
To get the manual, here is the LG website, you just need to enter your location details and get the manual among the choice.(The reason for this is that few models are available only in some countries)
click here for LG Website
Good luck,Please do rate my solution and post comments.
Posted on Apr 19, 2009
  • 351 Answers
SOURCE: Washing machine problem
"dE"
- Lid open error Lid is open during wash cycle. Close lid.
· Check wiring harness
· Check lid switch
· Check unbalance switch
· Check circuit board "OE"
- Water overflow error Water supply does not stop after sensing an overflow condition. Turn off household water supply to washer and unplug power cord.
· Check water inlet valve
· Check pressure sensor switch
Posted on Apr 30, 2009
jumptrout51
  • 3361 Answers
SOURCE: washer wont turn on flashing de
Open the washer and clean the drain pump.
Posted on May 20, 2009
Where is the door latch located on the LG top loader washer turbo drum model T6755pp
How to Troubleshoot a DE Code for an LG Washer ' eHow
www.ehow.com > Home & Garden
Although sometimes the only way to correct the DE error is to hire a professional to check and fix the washer, there are a few at-home troubleshooting efforts you .
Aug 05, 2015 | LG Washing Machines
Bosche front loader de error message help
dE is a door error, check switch, door alignment and wiring harness
May 28, 2014 | LG WM-2277HW Front Load Washer
LG Intellowasher 7kg WD-14125RD shows DE error
DE is for a door lock error and you will need to replace the lock. Here is the part to order.
Dec 07, 2012 | LG WD-12126RD Front Load Washer / Dryer
What does dE message mean on an LG washer?
DE = Door Error.
Latch, sensor or similar has failed.
See this link:
LG - http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=799
Thanks!!
Oct 24, 2011 | LG WM-2277HW Front Load Washer
My washer is showing dE message what is this mean?
The machine identifies and indicates some operational errors through a series of beeps.As you are using LG WM2455 Front load Washer it is showing error message The error message "DE" This error signal beep during drain.Unhook/clean drain pipe and press the 'Start/Pause' button to continue cycle.Thanks for your question.
Jun 17, 2011 | LG WM2455 Front Load Washer
What is an F1 error message?
El codigo F1 para las Whirlpool Cabrio lo define la se?al de presion fuera de rango, para esto, primero hay que verificar el estado del tubing plastico ? manguerita que va de la tina hasta el sensor que esta en la tarjeta principal, que no este rota y/o doblada, luego realizar el test # 6, nivel de agua y calibraci?n del sensor de presion. Para esto hay que estar seguro de que la tina este sin agua, al igual que el tubing, luego entrar en test modo 2 y seguir los pasos.
Jul 08, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
"dE"
· Check lid switch
Apr 30, 2009 | Washing Machines
Unplug the machine.
Mar 17, 2008 | Washing Machines
Lg wm2277hw
You do not have an "OE" error, you have a "DE" error. DE error is "drain error" which displays if the washer has not pumped out after 10 minutes. If there is water in the machine and no obstruction in the filter I would suspect that the pump impeller is bad, and you would need a new pump motor. (part # 4681EA2001D) Pump motor is located directly to the left of the filter, and can be accessed by tilting the washer back and reaching it from underneath. The pump housing is held onto the machine by three phillips head screws.
If you have "DE" error and there is no water in the machine that's a whole different problem I'll address if you say that's the case.
If you need good service, try calling a small dealer who sells and services the procuct line you are having a problem with. You can find LG servicers at us.lgservice.com but avoid the utility companies, A & E, Sears, and all the big guys who try to service every brand but often times are not very familiar with your brand.
That should help. Carl S., factory authorized LG technician for over 10 years.
Aug 25, 2007 | LG WM-2277HW Front Load Washer
Washing Machines Logo
121 people viewed this question
Top Washing Machines Experts
