Question about Hansgrohe Showerpower Aktiva A8 Handshower - 28547/Color=Stainless Steel
How to remove flow restrictor from Hansgrohe Aktiva Aktiva A8 Hand Shower 28547
4 Suggested Answers
HANSGROHE US
  • 7 Answers
SOURCE: I replaced a broken Hansgrohe hand shower with a
Hi Christieb942,
When you get a new hand shower you can sometimes get sediment on the federally mandated FLOW RESTRICTOR. Not screaming, that is ****** in cheek. To CHECK the Flow Restrictor for debris, look at the hose connection end of the hand shower. You will see an INSERTED part that is green, yellow, or white. We have to push that in there to satisfy the EPA requirement for flow. You can pull it OUT and rinse it off. Then connect your handshower and try it and see if it is improved. You will not void the warranty in any way by doing this. I hope you understand what I am telling you, but if not you can call me 800-334-0455. I wish I could answer more directly, but Big Brother has eyes.
Posted on Sep 20, 2011
Digital G-pa
  • 9 Answers
SOURCE: leaky handshower hansgrohe croma c100
Grab a wrench and give it at least a quarter-turn. Hand tight isn't enough with a shower, even with teflon tape.
Posted on Mar 28, 2009
blueextc3221
  • 15935 Answers
SOURCE: loss of pressure in Hansgrohe shower panel
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 05, 2010
Is there a way to take out flow restrictor to Hansgrohe faucet? Model Talis S
The flow restrictor is located just inside the head where the hose attaches and can be removed with a pick or even a wood screw. Be careful not to scar the inside of the head when removing it because there is an o-ring on the hose that seals to that inside surface. There's also a screen on the end of the hose that can clog. Here's a link to info on removing and cleaning the head. http://assets.hansgrohe.com/mam/celum/celum_assets/16__hruh0618_pdf.pdf?3
Aug 11, 2016 | Hansgrohe Plumbing
Slow flowing hansgrohe shower head
First thing to check is the filter screen at the hose connection on the hand shower. If this screen is clean and there is no debris in the flow restriction device inside the handle end you will most likely need to clean the hand shower spray face. You can remove the unit from the hose and soak the spray face in CLR. Follow the instructions on the container for use and dilution. Soak for no more than 10 minutes at a time. After soaking, rinse the unit well and reconnect to the water source. Run water through it and while running rub the rubber spray channels to further clear up any deposits. Repeat the soaking and cleaning process at least two more times to clear out all deposits that may be limiting your performance. If you need more help feel free to contact me at Hansgrohe. 1-800-334-0455. Press 2 for tech and ask for David Scarborough. I'd be happy to help.
Oct 29, 2012 | Hansgrohe Shower 28504 Raindance S 100 Air...
Hansgrohe shower head water leaking out of connector
Is it a Grohe or Hansgrohe shower head? If it is a Hansgrohe shower head the first thing to check is if the self sealing filter gasket is installed at the connection to the shower arm. Hansgrohe shower heads have a black self sealing filter gasket in the head that some people remove assuming it is a flow restriction device. It is only a filter and does not restrict flow unless clogged with debris. Next make sure the flow restriction device below the filter gasket is still installed. On some models removing the flow restrictor will cause water to be expressed from the air injection ports near the pivot ball. Feel free to contact me at Hansgrohe. 1-800-334-0455. Press 2 for Technical and ask for David Scarborough
Aug 20, 2012 | Grohe Home
How to un-fit Hansgrohe Chroma 3-ways handshower?
Hansgrohe hand showers have filtration sometimes on the inlet side of the hand shower. You must unscrew the smooth conical nut from the handshower to expose the filter and the flow restrictor. If your hand shower is not equipped with a filter gasket, you should use one to protect your hand shower from the particulate.
Filter gaskets can be used at your body sprays and shower head as well if you have them. If you have a Hansgrohe thermostatic valve you don't need the little filter screens, because the valve is filtering the water good enough. We do not recommend opening your handshower for cleaning. There would be a strong chance you may not get it together again, or it may become damaged.
If your concern is with a buildup of lime on the spray faces, you can use a decalcifying agent to dissolve the deposits, but do not soak for more than 10 minutes and then rinse well with clear water.
Best regards,
Phil Heslep
Hansgrohe Technical Support
North America
Jan 08, 2012 | Home
I replaced a broken Hansgrohe hand shower with a new Hansgrohe Clubmaster 3 - now have very poor water pressure - how to correct?
Hi Christieb942,
Sep 18, 2011 | Hansgrohe Model 28525: Clubmaster Oil...
There is very little water coming out of the head. how do i take the head off
Check out the connection line to the hand held shower. Take it appart and check out the screen and make sure it is clean. Also there is a dime shaped restrictor that reduces water consumption down to 1.6 gals. You can remove that plate and the water flow will increase. The head on the shower itself you can soak it in vinegar to clean head up.
Hope this will be of some help yo you thanks.
Mar 26, 2011 | Hansgrohe Interaktiv 2-Jet Handshower,...
Removing flow restrictor from Moen Brantford posi-temp shower he
How I remove them is take a drywall screw and screw in to the flow restrictor. Then grab it with a pair of pliers and pull out.
May 16, 2010 | Moen T2153BN Brushed Nickel Brantford...
Flow restrictor
Hi, all the shower heads that I replaced, the flow restrictor was always in the nut that you screw onto the pipe that comes out of the wall.it's a plastic disc, with a little hole in middle.you can use a coat hanger to pull it out.
Nov 12, 2008 | Delta & Victorian 5 Spray Showerhead
Hansgrohe Showerpower Aktiva A8 Handshower - 28547/Color=Stainless Steel Logo
142 people viewed this question
Top Hansgrohe Home Experts
Shehu Pro
Shehu Pro
 John
John
Are you a Hansgrohe Home Expert? Answer questions, earn points and help others
