Question about Whirlpool Washing Machines
Whirlpool front loader WFS1276AW Door will not open
After doing a load of washing the door will not release, I have tried switching it off at the wall, tried the time delay button how do i overcome this problem, the machine works I can set it for a washing cycle, but at the end of the cycle the door will still not open.
SOURCE: FRONT LOADER DOOR LOCK WONT OPEN OR JAMMED
On a Bosch wfmc3200uc there is a green plastic string, similar to fishing line, located behind the round panel on the front of the machine. It is attached to the top right of the round black piece. Just give a slight tug this will release the lock.
Posted on Oct 21, 2008
SOURCE: Door locked on compact Whirlpool front-load washer
This worked for me. I turned off the washer and hit the area on the washer directly to the right of the door handle (not hard enough to break something or cause a dent). It popped right open.
Posted on Sep 30, 2009
  • 56 Answers
SOURCE: Front loader AWM 6100 - door open light flashes and won't wash
I think it may have try and get your local engineer out to have a quick look tell your thinking of buying new and what price can he supply 4. and you like a free estimate .
Posted on Feb 11, 2010
  • 6 Answers
SOURCE: My Electrolux ewf1090 front loader door wont open
Turn the power off and leave for 5-10 minutes then turn on. This should release the door lock the problem could be the pump drain filter is blocked clean this and it should resolve future problems.
Posted on Dec 05, 2010
rickead1
  • 1998 Answers
SOURCE: My LG WD-8023 Fb front loader has the door locked
look down the very bottom of the machine you should see a couple screws on the bottom unscrew these and remve the lower panel you may have one screw also in the clean out you will be looking for a type of pull cord that is attached to the door pull the cord and the door will open. if the delay lock is not releasing then you would have to replace the door lock assembly in the unit if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations in the future Thanks Rick
Posted on Mar 15, 2011
Can't open the door of my front loader. Have done a load of washing now can't get door open, have tried to do spin cycle a few times, have switched the power off, still no luck?
if you have your manual it will tell you how to manually open the door,on most you remove the bottom panel.reach up new the door switch and you'll feel a piece of plastic that's on the bottom of the switch on a pull release for the door.next time send the model number and brand name so whoever helps you can answer you better.
Apr 26, 2011 | Washing Machines
I have a Whirlpool washing machine, front loader, AWM 323. I have just finished washing a load but cannot open the door!
If your machine is a Duet model or it's relative, first unplug the machine then remove the lower valance under the door (three screws on the botttom of the machine) reach up by the door lock and you'll find a plastic tab hanging down, that's the manual release for the door lock. Wile you have the valance off look inside the machine and pull out the technician sheets that are stuck on the inside wall of the machine, you may need them later.
Oct 27, 2010 | Whirlpool GHW9400 Front Load Washer
Door open signal
this is comon its the door micro switch they cost pennies to buy but pounds to fit,,,wip the top off and you should see the door switch by looking from the top its right by the door lock
Jul 04, 2010 | Whirlpool AWM6100 Front Load Washer
Feb 11, 2010 | Whirlpool AWM6100 Front Load Washer
Front door won't open at end of cycle
There is a safety switch on the door on front loaders which acts as a time lock. You have to wait a few minutes for it to release, if it does not open after about 5 mnutes the safety latch is faulty.
Dec 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Front load washer door won't open
There is an override switch directly below the latch under the machine on most front loaders.
Jan 24, 2009 | Kenmore Elite 45986 Front Load Washer
Whirlpool washine machine #AWM 3082 - door wont open
Try to unplug the unit for five minutes, then plug back in. Try to start a load, as soon as the door locks agian, hit cancel. That will sometimes let you get back in. Im not sure if this is a top loader or front loader, but there is a way (if its a front loader) to remove the bottom front kick plate, then you have to reach up the inside to the door latch assm, on the bottom of that is a small round handle, pull it straight down, and the door will unlock. If its a top loader (i.e. Cabrio, Oasis, Etc), you can open the top only by unclipping the top from the base. You can do this by putting a putty knife in between the top and cabinet, then finding the clips, pushing them in and lfting, you can get your stuff out that way.
Nov 16, 2008 | Whirlpool LHW0050PQ Front Load Washer
Oct 05, 2008 | Washing Machines
Open door
Turn off the machine and un plug, checked half hour later and the door opened.
Apr 19, 2008 | Whirlpool AWM8143 Front Load Washer
Washing Machines Logo
Sal De
Gerry Harvey
Gerry Harvey
