Question about Swingline 520E Electronic Stapler Black
Where is the gear key located in model 520e stapler
2 Suggested Answers
SOURCE: How in the world do
Slide the cover foward and lift up.
Posted on Jan 18, 2011
I have loaded a new staple cartridge into my Swingline 520e stapler and it isn't releasing any staples when i attempt to staple something.
Not sure but check for staples that are jammed where the new ones go in. i had one single staple which stuck in and would not let the new ones come out.
Dec 21, 2017 | Staples Office Equipment & Supplies
How do I open the stapler
Hello, Go to this website for a manual to fix or on this website, call cust. support. Swingline Manuals Swingline
Oct 23, 2014 | Swingline 520E Electronic Stapler Black
How do I load staples in model 520e
Hello, Go to this website for a manual or call cust. support on this website. Swingline Manuals Swingline
Our Canon NP6035 copier won't staple. It had a jam in the stapler, which I removed. We installed a new staple cartridge. The stapler makes indentions in the paper, but it won't advance any staples.
Do you have a 10 or 20 bin finisher? I'm guessing you have a 10 bin. Did you install the stapler cartridge in correctly? There is a small black plastic gear that cracks and the stapler will not work. The two way's to solve the problem is to replace the gear or the stapler unit. Both may be had to find. Good Luck
Aug 24, 2010 | Canon NP 6035 Copier
Swingline 520e does not staple
The trick to clearing this is to rn the stapler WITHOUT the cartridge in. We removed several visible jams, but once we ran it with the cartridge out, a huge piece of staple came out, and then we were able to put the cartridge back in and use it. Woot!
Sep 16, 2009 | Staples Swingline® 36115 Staple Guns Tools...
Stapler is not dispensing staples after new cartridge is inserted. Can you help?
Remove the staple cartridge, look into the cartrige area, are there any stray staples in this area, if so remove them, cycle the unit a couple of times without the cartrige in place, check the output end, any stray staples here? re assemble making sure you pull the first row ow staples even with the nozzle of the cartrige.
Hope this helps
Ed
Apr 30, 2009 | Office Equipment & Supplies
My Swingline model 520e jams every other time I staple.
There were a few staples left in the cartridge when the stapler stopped working. I went thru all the steps on bottom for stapler after changing the cartridge with two different cartridges. It makes the noise and puts marks in the paper, but no staples come out of it.
Mar 18, 2009 | Staples Swingline® 36115 Staple Guns Tools...
E532-0001
An E532 happens when the stapler unit either does not move from front to rear, or rear to front, or hangs up and stops part of the way. A broken stop gate can get in the way of a stapler and keep it from moving. Usually the two inside gates are the problem. The bottom spring may have fallen off when the plastic tab on the bottom of the gate (which holds the spring) breaks off. Or the parts of the gates that come in contact with the white rollers on the stapler assembly become dry and need to be greased to allow the stapler to slide past them. Also check the wiring harness that runs from under the stapler, through an opening and then connects to the stapler itself. Wires have been known to break internally at the wire-tys and cause erratic E532s. Check each wire with a meter for continuity. Hope this helps a little.
Jun 06, 2008 | Office Equipment & Supplies
Swingline 520E Electronic Stapler Black Logo
69 people viewed this question
Top Swingline Office Equipment & Supplies Experts
Paul Bade
Stitch85
Level 1 Expert
Are you a Swingline Office Equipment and Supply Expert? Answer questions, earn points and help others
