Question about Bladez X350P Elliptical
Belt tension won't release to zero
Have programmed it to release tension to zero but there is still resistance
    Top Expert:
  • Bladez Master
  • 12,223 Answers
Please follow the next steps. God bless you
Check your owner's manual for diagrams and definitions. You'll need this information when you put the elliptical back together. You'll also want definitions in case you need to call the customer support line for assistance.
  • 2 Be aware that the resistance is often the part that requires repair. Resistance is managed magnetically, so often if the machine is working, but the resistance isn't setting correctly or at all, check the bolts that secure the magnets. If they are loose, the resistance will slip. If the bolts are fine, check the magnets themselves by using a refrigerator magnet and see if it is attracted or repelled by the your fridge magnet. If not, the magnets have de-magnetized and need to be replaced.
  • 3 Consider that if the foot pedals are attached with bolts, any slipping can be fixed with a quick use of the wrench. But if the foot pedals are damaged or breaking, order new foot pedals (see Resources below) rather than run the risk of a pedal breaking while you're on the machine.
  • 4 Check the hand bars. While not all people use them, as they can elevate your heart rate by up to 20 percent, they can become worn, too. While loose hand bars typically need a simple tightening of the bolt, be sure not to overtighten as the bolts can break.
  • 5 Know that if the axis is bent, it's likely you need a new machine. The axis is the central alignment of the elliptical. If the machine was used by a person who is over the maximum weight limit, it can be bent or damaged. It's not an easy fix and a better idea is to upgrade to a sturdier machine.
  • Posted on Dec 04, 2012
    Troy-bilt riding mower won't move in forward or reverse
    I had a similar problem with my TroyBilt 50 inch zero turn mower. Was cutting grass when it stopped going either forward or backward even though it would start and the PTO would move the cutting blades. Turned out the tensioner spring for the belt that drives the motors near the rear wheels had gone missing. Searched the yard where I had cut and moved the machine but couldn't find it. A new one cost me about $7.50. Put the new one on and it worked fine.
    Apr 19, 2013 | Troy Bilt 175HP Manual 42" Riding Mower
    Changing serpentine belt does it require a special tool
    no,15 mil.wrench to release the tensioner ,the bolt is left hand thread,so it won't unscrew when you release the tension on the belt.
    If there is no diagram on the rad. support of the belt routing you may want to draw a "map " of the belt routing just to be safe.
    May 21, 2012 | 1994 Oldsmobile Cutlass Ciera
    Toro Z5000 won't move
    did the belt break or fall off? are the trans release levers pulled out ?the ones you release to push it around
    Apr 14, 2012 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
    How to change a timeing belt on a 1994 isuzu trooper
    • Pop the hood and locate the belt tensioner on the front of the engine, which has a square hole in the middle of it. Stick the end of the 1/2-inch breaker bar into the hole and turn the bar counterclockwise to release tension on the belt. Then pull the old belt off of the pulleys and remove it from the engine.
    • 2
      Open the owner's manual and locate the belt routing diagram for the engine. If you can't find the owner's manual, there is a sticker under the hood that shows the routing diagram as well. Start installing the belt around the pulleys according to the diagram until you can't pull it any further.
    • 3
      Pull the breaker bar again, turning it counterclockwise, and put the belt around the tensioner. Then release the tensioner and visually inspect the belt to make sure it's not twisted or bent any odd directions, and make sure that the belt is sitting squarely in each pulley. If not, pull up the tensioner with the breaker bar again and adjust as necessary.
    Jan 12, 2012 | 1994 Isuzu Trooper
    2004 range rover serpentine belt replacement
    There are 2 belts on the vehicle. It is EXTREMELY crirical to make sure you make a diagram of exact path of belt through the pulleys before removing it. If you dont, You will find it difficult if not impossible to figure it out after the fact. If you place it back wrong and it manged to fit severe engine damage could occur.
    Standard procedure for any vehicle is to release tension on the tensioner pulley first'
    This is accomplished by releasing tension on the pulley it is spring loaded and will release by placing the appropriate socket on the
    pully and turning to release tension. (This can be difficult secondary to inadequate clearance. Lisle tools makes a tensioner pulley tool that I consider absolutely necessary.) then slip the belt off while maintaining force to keep tension off. release tension on tensioner again for clearance make sure belt is aligned properly on all pulleys befor you close the hood(bonnet).
    ulley tool and I consider this tool essential
    Dec 31, 2011 | 2004 Land Rover Range Rover
    1993 bmw 325i water pump belt routeing
    One of the routine maintenance items that you should perform on your BMW is the checking and replacement of your accessory drive belts. The belts are driven off of the crankshaft and power accessories such as the water pump, power steering pump, alternator and air conditioning compressor. There are typically two belts on the car - one that powers the air conditioning compressor and another that powers everything else. Both should be checked periodically (every 3,000 miles, or when you change your oil), and particular attention should be paid to the main belt. The car can run fine without the air conditioning belt installed. Some of the early E30 cars use a standard v-belt design, and some of the later cars use what is known as a poly-ribbed belt (having many channels or ribs on the underside of the belt). The poly-ribbed belt setup utilizes a spring-loaded belt tensioner pulley that provides the proper tension for the belt at all times, making adjustment unnecessary. The traditional style v-belts need to be tensioned using standard types of clamps and tensioners. When inspecting your belts, the one thing that you want to look for is cracks (yellow arrow - Figure 1). If you see any cracks at all, you should replace your belts. The cracks will usually occur on the inside of the belt (the surface that typically rides on the surface of the pulley). With the poly-ribbed belts, this is the grooved surface. With the v-belts, this is the surfaces on the legs of the 'V'. With the poly-ribbed belts, replacement is a snap. The tensioners that hold the belt tight can be easily released using a socket and or 8 mm hex tool. Different tensioners turn different directions, so you may have to rotate the tensioner clockwise or counter-clockwise depending upon your particular car. The description of this process is one of those things that is difficult to describe, but very easy to do. First, pry off the small plastic cap that covers the tensioner (green arrow Figure 1). Then, place your tool into the tensioner and try rotating clockwise or counter-clockwise - will become immediately apparent how the tensioner releases the belt (Figure 2 and Figure 3). Removal of the two belts is easy - you do not have to remove the fan. Simply release the tension on the belt from the tensioner, and then the belt should simply slide off. Release the tension, and then you should be able to unwind the belt from the engine. The belt should be able to be maneuvered around and through the fan - you do not need to remove the fan to swap out any of the belts (Figure 4). It is important to note that if your BMW has air conditioning, you will need to remove this belt first, as it typically blocks the other belt. Another tip - if the belt is worn, simply snip it with some large tin cutters and pull it out of the car, after you have released the tension on it. Installation of the new belt is easy. Simply slide on most of the new belt onto the pulleys, release the tension on the tensioner, and slide the belt onto the tensioner. Check to make sure that the belt is securely seated in all of the pulleys. Verify that the ribbed portion of the belt is set against the crankshaft pulley. The proper orientation of the belt is shown in Figure 5. Replace any plastic caps that you may have removed from the front of the tensioner pulleys. Now, start the car and peek in at the belts. Verify that they are turning smoothly on all of the pulleys. For engines with the older-style v-belts, the procedure is nearly identical, except for the tensioning. The alternator is mounted on a bracket that rotates and is used to keep tension on the belt. In addition, there is a small rack-and-pinion device on this bracket that allows you to crank up the tension on the belt (Figure 6). The first step in setting or releasing tension is to release the nut on the back of the bracket that keeps the whole assembly secure. Do not attempt to turn the geared bolt without first releasing this nut on the rear - you will most likely damage the bracket. With the nut released, you can now turn the geared bolt counter-clockwise, releasing tension on the belt. Belt replacement is nearly identical to the poly-ribbed belts. Well, there you have it - it's really not too difficult at all
    12_15_2011_4_43_36_am.jpg12_15_2011_4_44_18_am.jpg12_15_2011_4_45_17_am.jpg12_15_2011_4_45_53_am.jpg12_15_2011_4_46_27_am.jpg
    Dec 15, 2011 | Cars & Trucks
    DIY remove/replace serpintine belts on 1997 Buick Park Avenue with Supercharger.
    There is no need to remove any bolts from the engine. It is usually easiest to raise the vehicle and remove the right front tire and the plastic splash shield to gain access to the lower engine pullies. It is a TIGHT FIT getting the belts in between the pullies and the fender. All I can say to that is "welcome to the wonderful world of auto repair! - NOW maybe you have a clue why we mechanics charge so much to do seemingly simple things like "just" replacing a little sepentine belt?"
    Hopefully, the routing diagram below will help you to get the belts back on correctly.
    Oct 27, 2011 | Cars & Trucks
    94 LEXUS GS300, HOW DO RELEASE THE TENSIONER? (FOR THE SERPENTINE BELT) PUTTING A SOCKET ON THE BOLT HEAD ON THE TENSIONER WITH A BREAKER ARM, DOESN'T MOVE IT. DON'T WANT TO FORCE IT AND BREAK THE...
    You shouldn't need to loosen the tensioner itself. To release pressure on the belt tensioner, rotate the belt (or tensioner pulley if the belt is no longer installed) CLOCKWISE. This will release the tension to either remove the old belt or install a new one. Once installed, the belt tensioner will automatically take up the slack.
    Sep 19, 2011 | 1994 Lexus GS 300
    Replacing serpentine belt on 1996 Dodge Grand Caravan, do I need to access tensioner pully from under the car? The tool from the shop won't move far enough from the top to release the tension. Thank You
    This is the procedure for 3.3 and 3.8L engines:
    1. Disconnect the negative battery cable.
    2. Raise the front of the vehicle and safely support it with jackstands.
    3. Remove the right front splash shield.
    4. Release tension by rotating the tensioner clockwise.
    5. Remove the belt and install a replacement.
    6. Proper belt tension is maintain by the dynamic tension.
    7. Install the right front splash shield. Lower the front of the vehicle.
    8. Connect the negative battery cable.
    Jul 28, 2009 | 2004 Dodge Caravan
    Bladez X350P Elliptical Logo
    215 people viewed this question
    Top Bladez Exercise & Fitness Experts
    Electro Med Services...
    Tom Chichester
    qa1012
    Are you a Bladez Exercise and Fitnes Expert? Answer questions, earn points and help others
