Question about Panasonic KV S2045C Path-Through Scanner
Only scans 1/2 back page in duplex scan.
Panasonic KVS2045c scanner - When scanning in duplex, the back page only scans 1/2 of it, with the other side black. Any idea what might be causing this?
  • 100 Answers
%95 of the times its a technical faliure, Talk to the store you bought it from or call Panasonic customer support, you can not fix this by yourself. =)
Posted on Aug 10, 2007
Can i skip blank pages while scanning duplex with a 5080c using capture perfect 3.0?
There is option to skip Blank pages. You have to specify in terms of percentage, above which the scanner will save and discard images below the specified percentage.
S. Mohan, India
Feb 28, 2013 | Canon DR 5080C Path-Through Scanner
Can i get front and back side of pages scanned at a time, if yes then how? how can i scan a book of 50 pages by giving one command?
What scanning software are you using? In Adobe Acrobat Professional 9, you can set up different scan profiles, including duplex scanning. The sheet feeder holds up to 50 pages; you just tell the software to make all pages one pdf.
Dec 02, 2010 | Kodak i1220 Pass-Through Scanner
My scanner is now adding a page with a black line that runs from top to bottom of the page and the actual document scanned is page 2. But the document is fine with no line through it. Does this mean that...
Check your scanner software settings. It is probably set at duplex ever time you start to scan. That is why you get two pages for every pass, the front and the back. You must place the document in the feeder in a way that the front side of the document is page 2. You may want to flip it next time you scan. So the main question is why there is black line from top to bottom? That is because there is a piece of dirt stuck on the glass of the scanner. You see, this scanner actually does two scanning when a page runs through it: the front and the back in duplex mode. So there are two scanners in side the box. The front page scanner apparently is dirty and needs to be cleaned with clean cloth and lens cleaner.
Aug 31, 2010 | Canon DR 3060 Path-Through Scanner
Canon Dr2050C Duplex scanning reverse page all black
Check your brightness setting for backside. Ideally keep it automatic, else you can manually choose the right brightness.
S. Mohan
Sep 18, 2009 | Canon DR-2050C Path-Through Scanner
Scanner is not reading multiple pages...
Check your scanning software settings. If you are getting only one file output, then you must have chosen 'multipage' option.
S. Mohan
Jun 12, 2009 | Canon DR-2580C Path-Through Scanner
Can only scan simplex or duplex
The scanner can scan in either simplex or duplex mode only. If blank page is scanned, then it will appear BLANK, else someone would say, my scanner is not scanning properly! Remove balnk pages using software or sort on file size and delete the small sized files. Take care to ensure they are really blank.
S. Mohan, India
Nov 20, 2008 | Fujitsu fi-5110C ScanMaker Scanner
Scanner problem
Try scanning a double sided document in duplex mode. Reverse the page and scan again. Make sure contrast/rightness settings are okay. If one side output is still not okay, then it possible that the lighting has failed. Either loose contact or failure of the lamp. Some scanners have LEDs and some have a lamp.
S. Mohan
Feb 19, 2008 | Office Equipment & Supplies
How to scanning double sided document in fujitsu 5120c scanner
You may want to try using Laser Fiche. This scanning software allows you to select "Duplex" which allows you to scan double sided document
Oct 23, 2007 | Fujitsu fi-5120C
KV S2045C scanner
Wow, it's been so long since I posted this, I cannot remember! I am the tech person and just was relaying the problem as an EX exployee relayed it to me. What did my original message say? I BELIEVE it was 1/2 black, but no image/words on the other half. Just black and white, but again, I cannot remember. Does it make a difference?
Dec 05, 2006 | Panasonic KV S2045C Path-Through Scanner
Panasonic KV S2045C Path-Through Scanner Logo
108 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
HEMANT GROVER
mahesh y.h
mahesh y.h
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
