Question about Whirlpool Dryers
Just got a whirlpool cabrio dryer today and it is not drying, its getting very hot and the clothes feel like they have more moister in them after running dryer. now it has water leaking from under it. what could cause this?
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
Check the internal and external duct work for blockage.
Posted on Dec 04, 2012
3 Suggested Answers
  • 10 Answers
SOURCE: Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
The vent may be stopped up, or the vent hose crimped so the air cannot escape, you can check the air flow at the vent on the outside of the house while the dryer is running.
try cleaning the vent and the lint screen with a vacuum cleaner, you may need to replace the vent hose, this should solve the problem
Posted on Jun 02, 2009
  • 192 Answers
SOURCE: my dryer whirlpool wed5300sq0 is getting hot but
I suspect you have a blocked air vent. A blocked vent will definitely extend your drying time. You may even find yourself having to run a load twice to get it fully dried. One way to confirm this is to disconnect the vent hose from the back of your dryer and dry one load with the machine venting directly into your laundry room. If that load dries quickly then you know the problem is a blocked vent. Most vents get blocked by lint near their exit to the outside. There's usually a screen at this location to prevent small animals from crawling into your house. Often this screen gets clogged with lint. Most vents are designed to allow removal and cleaning of this screen from the outside.
Posted on Jul 07, 2009
Why is my Whirlpool cabrio platinum dryer leaking water, and taking over an hour to dry clothes?
Is this an older dryer? Long drying times are often caused by lack of good heating or poor air movement through the drum. Air movement depends on a properly turning fan and a clear exit of hot moist air to the outside vent. Check and see if you get a strong blast of air from your outside vent. If you don't, you may have a fan problem, plugged vent, or kinked vent tube. The water leaking could be because you don't have any drying going on due to the aforementioned problems.
Feb 05, 2016 | Whirlpool Cabrio Platinum High Efficiency...
Clothes remain wet after multiple times through drying cycle; the "AF" warning lamp is on as well.
AF= Air Flow: there is a restriction; check to make sure that the lint screen is clean,and that the door seal is in place and the vent isn't obstructed, just disconnect the vent and run the dryer, if it clears its the vent tube if not feel the back of the dryer with it running should feel hot/warm air continuous, if not feeling a lot of air, the you will need to take the dryer apart and clean all the lint off. if all checks out good then the control board. Hope this helps Tim
May 22, 2011 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Dryer running but no hot air and clothes are not drying? Is heating element burned out?
Good chance it is. Make sure it is getting power first. You can check with a voltage meter.
Feb 27, 2011 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Dryer feels hot but takes longer to dry cloths
Clean the entire venting system out. The moister sensor detects any lint build up and puts the heat in the check mode which will produse very little heat until its cleaned out
Jul 08, 2010 | Frigidaire FER311FS Electric Dryer
Dryer won't get hot enough to dry clothes
mAKE SURE THE VENTING SYSTEM IS COMPLETELY CLEANED OUT. a MOISTER SENSOR DETECTS ANY BUILD UP OF LINT CAUSING TO KEEP THE HEAT IN CHECK WHICH TAKES LONGER FOR THE CLOTHES TO DRY
Jun 13, 2010 | Hotpoint NBXR463EBWW Electric Dryer
Cabrio dryer won't get hot only warm
Clean all lint out of the exhaust vents tubes You will be surprised to see it work again
A moister sensor detects lint build up and shuts the heat off or nearly off at all times
May 31, 2010 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
No hot air
clean all vent tubing and try again
the moister sensor will keep the burner off if lint is build up inside the exhaust duckwork
May 09, 2010 | Whirlpool LER5634L Electric Dryer
Won't dry clothes thoroughly
It could be or the moister sensor is bad. Do this first for most people never think of doing this. Disconnect the entire venting duct work. Inspect it and clean it. If you get a wad of lint every foot length from this vent this will be your problem in drying clothes. The clogged vent will not let the exhaust pass through and the moister sensor detects that and shuts off the heat automaticly
Apr 20, 2010 | Whirlpool LER7646E Dryer
Dryer
Today my whirlpool dryer started making a loud noise. it is drying the clothes but the noise is loud.
Jul 06, 2008 | Kenmore Dryers
Dryers Logo
347 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De GO PATS
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
