LG WD1470FD won't open
Went to put new load in & door won't open. Catch maybe faulty?
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
You will need to replace the door lock assembly. If remove the top, you can reach down and manually open the door. Below is a video to show you how to replace the lock. Here is the lock to order.
Posted on Dec 04, 2012
  • 489 Answers
SOURCE: lg wm1280fhd Spring loaded door catch
Dee,
This one is hard because I don't have any information about your model #.  Are you sure the model # is correct??
Posted on Apr 28, 2008
  • 6277 Answers
SOURCE: door locked&spin light blinking &
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jun 28, 2011
  • 16 Answers
SOURCE: The door is jammed on my LG Intellowasher
Hi, Has all the water gone out of the machine? Try it on another spin cycle if it opens then the drain filter or pump could be blocked.
Regards Elect App
Posted on Jul 14, 2011
  • 184 Answers
SOURCE: I pushed the 'pause' button
Hi!
The machine knows it dint't finish the washing cycle, and, because it may be possible that water is still a lot inside, the door is locked.
If you are shure the door can be opened without the water coming out by the door, simply disconnect it from the electrical supply and wait a few minutes until the door unlocks. (you will hear the unlock click)
Posted on Aug 08, 2011
Testimonial: "It worked, thanks!"
rickead1
  • 1998 Answers
SOURCE: Hi, I can't open the
I am unable to find that model number for your unit but I did find another that was close and is also an LG Tromm click this link http://www.appliancepartspros.com/partsearch/frame_diagram.aspx?diagram_id=28702783&pkw_=basket&model_id=5520802&NewWindow=1 you would have to remove the bottom panel the one that has the drain filter attached to it by removeing the screws that hold the panel in place. Once the panel is removed then you would reach up along the side that the door lock assembly is on and you will see and feel a cord with a ring that you would pull and then your door would open once you pulled this cord. In some units if you unplug the machine for 7 minutes this also causes the control to reset and sometimes this also causes the door to be able to open once the control is reset. If you have any further questions message me back and please remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation Thanks Rick
Posted on Aug 16, 2011
Boot won't close and hold.faulty catch in lock mech... Key and central locking works but the catch won't hold
with the boot open use a screwdriver to trip the catch and see if it will hold the screwdriver. if it does make sure that the seals around the boot edge are all in proper place. if it won't hold the driver then the catch will need to be replaced.
Aug 19, 2013 | Vehicle Parts & Accessories
I have the LG TROMM WM2688HWM. Tried to wash a load and keep getting the error message: 'The door is open....'. I have held it closed, pushed it closed, opened and closed many times to no avai
the door actuator may be defective. if ur model has one? other wise sounds like the board is not communicating with the switch
by pass the door switch like this:
Feb 13, 2013 | LG WM2688HWM TROMM SteamWasher
My LG washing machine door won't open
UE is unbalanced load. Unplug machine for 5 minutes then plug back in. That may cause it to unlock.
Oct 14, 2017 | LG Washing Machines
Door won't lock
try pushing the door and hold in if this does not work the door catch is faulty replace internal door lock then should work (common fault)
Sep 28, 2012 | Indesit IWC6125 Front Load Washing Machine
How to open rear door on 2000 buick lesabre electric door swich won't release
USE A SLIM JIM TO POP THE DOOR RELEASE CATCH FROM THE OUTSIDE, THEN ONCE OPEN, REMOVE THE DOOR CARD & REMOVE & REPLACE THE DOOR SOLENOID
Sep 02, 2012 | 2000 Buick LeSabre
The Driver's side door of our 1996 Saturn Stationwagon won't catch when you close the door. In otherwords, if I drove the car, I can close the door but it doesn't catch and therefore the door...
first make sure the bolts which hold the latch mechanism to the door are firmly screwed in. if that ain't it, remove the post which it clamps onto from the door jamb and switch it with one from a back door. close the back door firmly, lock it and never use it again. if that ain't it go to www.getsaturnparts.com and buy yourself a new door latch mechanism and pay an auto glass shop to put it in for you.
Sep 07, 2011 | Saturn SW2 Cars & Trucks
Faulty door catch on my LG washer?
I have had the same problem for a week now. Until I find a spare part I slide a scraper to push the catch open. That just works.
Dec 05, 2007 | LG WM-1480FHD Front Load Washer
Door wont lock
to test if there is a fault on your interlock you can close the door now with your hand bang it on the front of the washer were the door hits the catch most cases if it faulty than the washer will start it will then need replacing only thing you can do if faulty m8
Sep 22, 2007 | Hotpoint WMA64 Front Load Washer
Washing Machines Logo
101 people viewed this question
Top Washing Machines Experts
