Question about Maytag PYE2300AY Electric Dryer
Kenmore dryer is squealing - Maytag PYE2300AY Electric Dryer
    Top Expert:
  • Maytag Master
  • 9,472 Answers
Replace the rear rollers. Here is the kit to order.
Posted on Dec 04, 2012
My dryer won't spin and is squeeling
It sounds like either the belt is loose or the drum is frozen. Try the following links to see if they help.
Appliance411 Home Service Appliance Repair Manual for Whirlpool Kenmore...
This will help if you have never repaired a dryer.
User Manual Downloads
Feb 05, 2016 | Kenmore HE2 6.7 cu. ft. Gas Super Capacity...
My dryer is squealing and won't spin
It sounds like the drum is frozen. The squealing is from the motor slipping on the belt. There may also be something keeping the belt from tightning. Try these links:
ShopYourWay
Feb 05, 2016 | Kenmore 73952 Gas Dryer
Squeals while drying clothescould this be a bad belt ?
It can come from two things, belt for sure when you over load the dryer or it is getting worn an second the rubber wheels the drum sets on can squeal.
Mar 29, 2014 | Kenmore Elite HE4 Electric Dryer
Kenmore series 80 Gas Dryer, in back of the dryer there is a fan at the bottom that squeals when I turn the dryer on. Is this easy to replace or oil to resolve the squealing. Suggestions are...
that fan runs off the motor shaft and can be lubed with some spray lube,, be sure that its not the belt thats squealing, check it for cracks, and bare spots
Jul 06, 2011 | Dryers
Kenmore solid state dryer. was squealing while running. now drum stops and starts. still squeals
belt, idler pulley, drum glide/rollers:
belt/idler pulley:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
rollers/glides:
http://www.partselect.com/dryer+replace-glides+repair.htm
belt configuration
http://www.applianceaid.com/images/belt-config.JPG
Dec 03, 2010 | Kenmore Dryers
Loud squealing sound when the basket first spins up this is a Kenmore stacked set, washer on the bottom, and dryer on top
Your problem could be a bad bearing...The drum rides in a bearing at the rear middle of unit..Its basically a plastic insert...When the dryer is first started the bearing will squeal until the plastic warms up..Normally you will hear the squeal at the back middle of dryer...Your problem may also be the belt tensioner...Again a plastic wheel with a metal bearing inside...Normally this squeal will be from start to finish..
Apr 20, 2010 | Kenmore 98702 Stacked Washer/Dryer
Kenmore series 70 dryer gas model 76712693-76712 squealing
Raise the top.
Remove the front panel.
Remove the drum.
Remove and replace the drum rollers and the belt tension roller.
Jan 20, 2009 | Kenmore 72982 Gas Dryer
Kenmore 400 dryer squealing noise
A little lubricant on the pulleys near the belts will go along way. Its vereasy to access these parts front the back of the machine with a 1/4 hex head screwdriver.
Jan 19, 2009 | Kenmore 63942 Dryer
Dryer really squeals
Ok this is a really broad question, Kenmore will squeal when a belt tensioner or motor bearing is out, a frigidaire or small kenmore with control panel above the door and serial number starting with x will squeal when the bearing is out on the drum or the motor. This is a general cover on dryer noise with a model like Kenmore series 80 I can give solutions ok?
Sep 20, 2008 | Dryers
Maytag PYE2300AY Electric Dryer Logo
29 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
