Question about Dell Latitude D630 Notebook
D630 lcd screen - Dell Latitude D630 Notebook
  • Dell Master
  • 32,281 Answers
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Posted on Dec 04, 2012
Where is the LCD cutoff switch located ?
Both the D620 and the D630 use the same keyboard.
The picture below shows the keyboard.
Hold down the blue Fn key at lower left, and then press F8 while holding down Fn. Press F8 multiple times until the screen returns.
If that fails, the ribbon cable connected at the main board from the screen may be loose and removing it, then reconnecting it, is the most likely solution.
ixquick proxy com
May 17, 2014 | Dell Latitude D630 Notebook
Dell latitude D630 wont recognize projector
Connecting an External Monitor or Data Projector
You can switch to an external monitor or data projector by two methods. 1. Connect the external monitor to the laptop's video port, power up the external monitor first and the laptop. The video information will automatically switch to the external monitor. 2. If you power up the laptop first then you can switch the video output to the external monitor by pressing the Fn key and one of the Function keys, depending upon your make and model laptop. You can also toggle between the external monitor or both LCD screen plus the external monitor or back to LCD screen only by pressing the Fn key plus one of the function key. Here is a list of key combinations for some of the laptops :- IBM ThinkPad = Fn + F7 HP and Compaq = Fn + F4 Toshiba = Fn + F5 Dell = Fn + F8
Sep 19, 2012 | Dell Latitude D630 Notebook
D630 screen is black once it starts up it illuminates but stays black
You must detect what parts is failure
Screen display, inverter board or lamp
Follow these step.
1.- Connect an external monitor (at VGA port) and check the image in external monitor
If show clear image. The failure may be the inverter board or the lamp backlight
Inverter boars is more easy to replace.
You can buy an used cheap price on
http://www.ebay.com/itm/Dell-Latitude-D630-Inverter-Board-K021048-00-/260809995144?pt=LH_DefaultDomain_0&hash=item3cb97cb388
Replace and your screen will work again
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 21, 2011 | Dell Latitude D630 PC Notebook
Latitude d630 duo core, 2gb of ram, 80gb, my laptop is well started up but not displaying anything, (black screen)
From a power off state, hold the D key and press the power button see if you get 4 solid colored screens (Red Green Blue ans White) this is the LCD BIST and if you get those colors, then LCD itself is fine. in which case you likely have a motherboard issue
If you get nothing then the LCD is bad and likely needs replacing
Aug 05, 2011 | Dell Latitude D630 Notebook
Dell Latitude D630 Problem With The Screen has a D630 with nvidia nvs135 and it dont show nothing on the screen, i tried to connect it to a lcd monitor none works. The displays are working, but its just a...
If you don't get a display on the external monitor, then most likely your video circuit is the problem. If your laptop has a plug-in video card it can be replaced. However if it's integrated into the motherboard then you'll have to have that replaced.
Jan 26, 2011 | Dell Latitude D630 Notebook
My dell latitude d630 screen is working but the vga is having a problem even when i connect my laptop to CRT or LCD screens it does not appear with good graphics so i want to know if i can replace an...
Assuming the graphics drivers are up to date and assuming you have a high resolution set in the display on the control panel, the screen may be damaged or the VGA cable damaged. In extreme cases the onboard chip may be loosning from the motherboard. You cannot install an external graphics card on this laptop. I would check the above and see if the existing setup can be repaired economically
Jan 11, 2011 | Dell Latitude D630 PC Notebook
Thin green line running down screen on my dell latitude d630
you can try re-seating the LCD cable, see if that makes any difference.
Press Power + D at boot and see if the Green line appears in the 4 solid color screens during the BIST test, if it does, replace the LCD
Oct 04, 2010 | Dell Latitude D630 Notebook
I have Dell latitude d630, It is switching on but no display, when I switch on my laptop, its num lock light is on. capslock light works when i use caps button. Power light is on but hard drive light...
Attach an external monitor. Does the external come on? May have to use the FN key + F8 to toggle it between the LCD and the attached monitor.
When you say that the laptop LCD glows a little bit, this makes me think the back light of the LCD has gone bad. If it displays fine on the external, then it is a pretty good chance the LCD back light has failed. If you can attach an external monitor and see something on it, run the built hardware test. This is done from a powered down state. Then press the FN key + Power, this places it into the diagnostic. Follow the on screen instructions. If it comes back with an error code, write this down and compare it to this list at Dell website. http://support.dell.com/support/topics/global.aspx/support/dsn/document?c=us&l=en&s=gen&docid=14B3819735D6B40EE0401E0A55177ED2
Occasionally, reseating the LCD video cable to the mother board will have a positive effect. Here is a link to the online service manual that explains how to reset it. In the diagram it is labeled #5 It is located under the keyboard.
Aug 10, 2010 | Dell Latitude D630 Notebook
My dell laptop fell off my bed and now my screen is broken.. is there a way i can get my pictures off?
Provided the screen is the only thing damaged, you have several options.
  1. Connect and external monitor and use it to see what you are doing while you copy you photos to other media. (Fn+F8 enable external monitor)
  2. Remove the HDD, connect it to another system using a USB adapter, and copy your files: http://www.amazon.com/Universal-Drive-Adapter-Serial-ATAPI/dp/B0012TOG08
  3. Replace the broken lcd: http://cgi.ebay.com/DELL-LATITUDE-D620-D630-COMPLETE-LCD-WARRANTY_W0QQitemZ220582533329QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item335bbe58d1
http://support.dell.com/support/edocs/systems/latd630/en/sm_en/display.htm#wp1105347
Apr 03, 2010 | Dell Latitude D630 Notebook
My Dell Latitude D630 will power on but the screen is black....nothing will show not even the startup page for windows. What do you think the problem may be
I would suspect either the video card or your LCD screen.. A good test is to hook up an external monitor and see if that works. Be aware that when you start it up, you will have to hit the function key and special function key combo to switch it to the external display.
On the latitude, that is the Fn key plus the F8 key.
Mar 22, 2010 | Dell Latitude D630 Notebook
Dell Latitude D630 Notebook Logo
54 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
