Question about Frigidaire ATF6000ES Front Load Washer
My Frigidaire Front Loader Washer will not turn on at all???
All of the sudden my Frigidaire Front Loader Washer will not turn on. I found a small rectangular magnet on the floor next to the washer. Could this be the problem? I have no idea where the magnet came from. It did not flip the breaker or anything like that, we checked. Can anyone help?
  • 640 Answers
It came from your dispencer activates a sensor on the unit right side,,,,take your dispencer out turn it over and that magnet goes on the left side when dispencer is right side up....yes that magnet is neeeded to start unit...onthejob
Posted on Jan 17, 2009
Our front loader washer goes crazy when spinning???wut shud we do??
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Apr 22, 2010 | Frigidaire Affinity ATF7000E Front Load...
LG washer WMo532HW-loud noise & leakage
Your bearings and drum shaft seal are leaking. This is a common problem with front loader washers and it is very expensive to have repaired. If you are handy you can repair this yourself for far less. If you think you are but are not handy, do not attempt. Buy only Japanese made bearings and not Chinese because for the small price difference it just is not worth the chance. Do your research!!!!
Feb 02, 2009 | Frigidaire GLTF1670A Front Load Washer
How do I put the belt on a frigidaire front loader washer
take the back of ,,might be 15 phillips head screws..around back,,than put belt on motor pully..and than on tub pully hold with one hand and turn,,either way..onthejob
Feb 01, 2009 | Frigidaire ATF6000ES Front Load Washer
Front end washer lights come on but doesn't fill.
it fell out of the dispenser, hold the dispenser facing away from you on the left side there is a small slot, place the magnet in vertically so the long side of the magnet is on the right when looking from the front with the drawer closed good luck
Dec 10, 2008 | Frigidaire ATF6000ES Front Load Washer
Washer won't spin in final spin out
Hello harley1964dm
You said, you have a Frigidaire front loader and it will not spin out in the final spin would you please help me. thanks
For a Frigidaire usually ,
If the washer won't spin.
Many times it's because the load is too small. Add 1 or 2 similar items to help balance the load.
If it does not remedy the problem try unplugging the machine for 5 minutes which will reset the system!
Let me now how it goes.
Please remember to leave a rating
Oct 11, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire front loader washing machine won't spin...
The problem is a faulty Door Latch Assembly. The same thing happened to my Frigidaire front load washer. The part is easy to install, costs about 60 dollars and can be picked up at most appliance repair stores . To access the switch just remove the wire around the front drum gasket, peel back the rubber gasket beside the switch assembly then remove the two screws holding it in place. remove the three wire connector blocks and swap in the new switch. My washer was giving me error code 41 witch is a faulty control board. But the problem was in fact only the switch...
Sep 02, 2008 | Frigidaire GLTF2940ES Front Load Washer
Water filling tub on washer
First thing is to run the machine as normal. After the cycle is complete and the clothes are removed, turn the water off, hot and cold, to the machine. If on the next usage there is no water in the tub then the fault has been found. And, no, the water valves are fairly easy to access and replace if needed.
Jan 26, 2008 | Frigidaire GLTF2940ES Front Load Washer
LTF2140E Front loader washer
My Frigidaire front loader washer model LTF2140E doesnt want to drain the water when set to wash (heavy-normal-quick selectors). It washes put thats it. I have to switch the selector to drain/spin then rinse/spin cycle to finish the load. I checked the drain hose for any clogs....everything is clear. Any suggestions? Also,iIs2.gif their any reset buttons for this type of washer?
Dec 13, 2007 | Frigidaire 24 in. FDB510LC Free-standing...
Frigidaire ATF6000ES Front Load Washer Logo
141 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
