Question about Protron PLTV-26 26 in. HD-Ready LCD Television
Protron PLTV26 - Only Audio but No Video
I have Protron PLTC26 LCD TV. One day it just went dead. Not I connected it back using AV connection of DVD player. I can only hear audio but there is NO video. I have remote control, but could not locate owner manual. What way it can be reset to factory settings? How can it be solved?
  • 4 more comments
  • Anonymous Jan 12, 2009
    I will check it out today evening and let you know
    Thanks for prompt reply
    -jnks2005
    NB : For system admins : I wanted to reply back telling status and I had to select SOLUTION or I HAVE SAME PROBLEM. I should have other appropriate option to select.
  • jnks2005 Jan 16, 2009
    Hi lone99star,
    I had tried unplugging and leaving for many hours. I also checked in mid night when it was dark around, tv was on, sound was on and i looked very closely, I did NOT see any moving / ghost image on screen. Screen was pitch black. The power indicator LED in middle bottom is green.
    Do you have TV owner manual by chance or do you know steps to go to TV menu --> Color brightness. I doubt if brightness is made to lowest. If that is the case then I wont see anything on screen.
    My remote works. Is there way to rest TV settings to factory settings?
    Thanks in advance
    jnks2005
  • ghanab Jan 25, 2009
    I have Protron PLTV-26 LCD TV. Model # LT26C1P1One day it just went dead. I have remote control, but could not locate owner manual. What way it can be reset to factory settings? How can it be solved?
    Do you have TV owner manual by chance or do you know steps to go to TV menu --> Color brightness. My remote works. Is there way to rest TV settings to factory settings?
    Please Help Me, Thanks
    my email is: gmb757@yahoo.com
  • buter309 Jan 30, 2009
    have audio but no video. power light changes from green to orange or red
  • deepak narai Mar 20, 2009
    i can hear the audio and change the channels every thing is good but there is no video shown
  • file9876 May 11, 2010
    I have a Proton PLTV-26 Model: LT26C1D1
    I have sound but no picture. I tried your troubleshoot and it seems that I must have a bad backlight inverter. Can you help me locate parts and instruct replacement?
    Thanks!
    Ajna
    file9876 @ comcast.net
  • 362 Answers
Hi jnks2005, We need to check your backlight, while tv is on and you have sound, take a flashlight and shine it on the screen, look very close and see if you can see a dark video image, If so you have a bad backlight inverter. You can try to unplug your tv for a couple of hours and let it reset but it is most likely the inverter. Let me know what you see and I can help you locate parts and instruct the replacement. Please rate this solution. lone99star
Posted on Jan 11, 2009
What is the audio/video input?
Hi
Audio Video input or [AV] input is meant for to connect the TV to any external device which has AV output. For example, you can connect the TV with a DVD/VCR/Blu-Ray/Amplifier etc. The audio video output of the connectig device has to connect to the audio video input of the TV with an audio video cable. This cable can be bought from most of the electronic sparepart shops. After connectin it such, you have to go to the input selection window of the TV and must select the input of the tV to Audio Video. No tuning or any other adjustment should be done then. Just play the connected device and see the its output by Tv. OK.
Jul 10, 2011 | Toshiba 37C3030D 37 in. LCD Television
Can't get my Proview TV to recognize the signal
Good day!
Please check the connection of the jack from your TV to DVD.
Follow this step on how to connect the AV (audio and video) jack.
  • For the DVD connection.
  1. Find out where is the video out of the DVD.It is usually have a label (video out) and the color is yellow.
  2. After that,connect the jack (color yellow) to the video out of the DVD.
  3. Next,find out where is the audio left and right out of the DVD.It is commonly have a label (rear,front and center) choose 1 of the location you want.also it have a standard color (red and white)
  4. After that,connect the AV jack(red and white)to the audio out of the DVD.
  • For the TV connection.
  1. Find out where is the video IN on the rear side of the TV.It is usually have a label (video in) and the color is yellow.
  2. After that,connect the jack (color yellow) to the video IN of the TV.
  3. Next,find out where is the audio left and right IN of the TV.It is commonly have a label (audio in ) and found in the rear side of the TV.also it have a standard color (red and white).
After you connect the AV (audio/video) jack.Try to open the TV and the DVD and set your TV to the AV mode by pressing the AV label on the remote or on the TV button.
If the video is not appear on the AV1 try AV2 ,AV3 and so on.Or also try other AV on the TV.
I hope this solution will be helpful.Thank you and good luck.
May 06, 2011 | Televison & Video
I DON'T KNOW WHERE TO PLUG MY DVD CABLE IN TO MY KV SONY TRINITRON- THERE DOESN'T SEEM TO BE ANY PLUGHOLES
Hello
You can connect the DVD player ot your Sony TV in two ways. One way is via AV cable, and the other is S-Video cable. If you use AV cabel, connect the cable's one side ends to output sockets of the DVD player, marked as Audio-L, Audio-R and Video. Connect the other side of the cable's respective ends ot TV's respective sockets, marked as Audio_L, Audio-R and Video. This socket can be located at the back of your TV. If you expects a beetter picture quality, you can connect the TV-DVD by S-Video cable. If you connect it via Audio Video cabe, switch the TV to get AV-1, AV-2 etc, by input selector option. If you connect S-Video cable, Select TV' to recive S-video input via its input selector option. You can do these selections by the help of TVs remote control. OK.
Feb 23, 2011 | Sony KV-36XBR200 36" TV
How do i get to the channel to watch a dvd
You will need to connect the video and audio from your DVD to the Input of the TV. So use a RCA cord to connect from the video output /audio output of the DVD player to the AV/Input/video input/audio input of the TV. Now use your remote to select the AV channel and your video and sound will come. Do this carefully . Hope you try. Good day
Aug 13, 2010 | Zenith B27A11Z 27" TV
CANNOT SUCCESSFULLY HOOKUP A DVD/VHS TO MY VIZIO MODEL NOS. DVD-v2000 25W
I was the person chatting with you earlier on, before the chat was disconnected. My system went off and I'm sorry about that.
I'm responding here in order to make sure your problem is solved.
LAST QUESTION THIS IS A DVD/VHS DUAL UNIT AND IS CON NECTED WITH THE wHIT rED AND YELLOW TO FROM THE COMPONENT AREA TO THE BACK OF THE TV
You can do the connection by using two different methods: (a.) you can use the component method or (b.) you can use the AV method.
Using the Component method: The component is a combination of red, green and blue wire connection which brings video or display.This three must be connected for you to have a display of your unit on your TV.
Connect the Red, Blue and Green wires respectively to their appropriate places on the TV, then the other part on your DVD/VCR. Note that this connection will only bring a display and no audio. You will have to connect the red and white wire from audio out of the DVD to audio in on the TV.
Once you have successfully done the connection, put on the DVD/VCR and your TV, then press "source" on your TV remote and select component 1 or 2 for you to get a display.
B. Using the AV connection: The Av connection is using the RCA wires which is yellow white and red, just as we discussed while chatting. Connect the Yellow, white and red wires, from the TV to the DVD/VCR, the select AV on the TV remote.
Unlike the Component which its video connection is red, green and blue for display, the AV is only Yellow for display. I hope you under stand this.
Please try to follow my explanations and let me know, if you don't understand and I will explain further.
It was nice chatting with you.
Take care.
May 02, 2010 | Televison & Video
Sony Bravia 40'' LCD 240Hz TV can't get video signal from DVD
Are you absolutely sure you have it wired up right? Are the Cable RIGHT wires color to color, is the "Correct Input" selected? Remember you do NOT use "Channels" but an AV, AUX, or External.input. Most DVD etc, use AV, IE: Yellow, (Video), Red, (Audio), White (Audio) for the OUT connections. These go color to color at TV end. And uses 3 Cables. The "Other" type of Output/Input is Component Video. This is ALL Video, Red, Blue, Green, these go color to color as well. BUT you MUST also send the Sound, Via the AV, IE: The Red & White, AV, Audio IN/OUT connections, So you in this case would have 5 cables/connections in all.
Feb 13, 2010 | Televison & Video
DVD input with signal access
IF I understand you correctly, the VCR, Satellite, etc is connected using an RF modulator/coaxial cable wire going into Antenna in
IF this is true, then you have an AV IN port (red, yellow, white) free on the back. Just connect the red, yellow, white from the out of the DVD - you can use 1 or 2 - just remember which one you used; and connect it to the AV IN on the back of the TV.
THEN press ch down on the TV remote until you get to "AV1" - it is below channel 2; double check DVD player to make DVD is playing and voila!
Jun 22, 2008 | Philips Magnavox 27MS343S 27" TV
Connections for DVD Recorder/LCD TV/ SKY PLUS
Connect the AV output of the Sky box to the AV input of the Panasonic combo.Look at rear of the Combo and you will observe input and output RCA connections.Using RCA leads, hookup the Av output of the Panasonic to the audio/video input of the Sony tv. Power up Appliances, and you should be OK.
Apr 11, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Can't connect DVD player
Use your TVs remote and select AV usisng the TV/AV button. Most DVD players use the AV Cables to connect to TVs.Yellow Video Out to Video IN of TV, REd and White Audio Left and Right to Audio L and Audio R IN of TV.
May 23, 2007 | GE 27GT622 27" TV
Protron PLTV-26 26 in. HD-Ready LCD Television Logo
834 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Dave Naylor
Dave Naylor
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
