More info please
Hi again Tat4u,......thanks again for replying!!...just a bit confused now though as i've read a couple of websites solutions on making USB mem sticks bootable!!..after you've made them bootable you still have to get into the bios to change some settings before they can be used,and as i cannot get that far then this option is a no starter(i think)!?......So i will have to try the cd method.......will get hold of a cd first and then install Nero and then give it a go!!( not sure though how the notebook will read the cd,again because the notebook only powers up and doesn't go as far as BIOS or windows!?).......anyway i can only try this and if no luck then i'll have to think about 'plan B' :-) ......cheers!
  • 520 Answers
The page I said before hp.com has software to make usb bootdisk from floppy ;also has floppy image if you cant find a floppy.
create new folder on desktop...
download hp usb boot to desktop...
download floppy image to new folder
make sure usb stick plugged in..
unpack/install hp usb boot ..
in the program
select device(usb stick
select quick format and create a dos startup disk.
"using dos system files located at" new folder...
click start..
thats ur usb bootable ...before you add any files you can try to see if it works cos sometimes you dont have to access bios it finds auto...worth a try seeing as the whole proccess of downloading installing and making usb bootable takes about 10 to 15 min...
if bios recognises device pc will start and you will see c:/ promt
of course this isnt a c:/prompt it just fools the bios .
if at first you see non system disk gtry press ctrl+alt+del and let start again (sometimes have to do this,bit like kickstart)
if you see the same error then obviosly bios needs to be told but if its recognised then add your files to the usb stick and away you go.
Posted on Jan 12, 2009
Hi, I've a fagor feb20e Eco plus combi boiler in
There is a flow sensor in the circuit and it is not sensing the lower flow from just the hot water. When you put it on heat though it does.
May 31, 2013 | Water Heaters
Ic a110 power problem
Hi Joshua,
Not enough info provided, from you.
IC a 110 power problem means very little.
IC indicates to me that you havs an Icom radio, is that correct?
a110 is confusing me though. What exactly are you trying to say here?
To assist you in finding the answer, I need much more info:
1. The make of the radio i.e,. Icom, Motorola etc,.
2. The Model Number ie, IC-XXX, etc,.
Then I require as much info as possible regarding the problem
By just posting what you have doesn\'t help me help you.
Please reply with the above requirements, and I\'ll find a solution for you.
Cheers,
Peter
Dec 14, 2012 | Radio Communications
I cannot install my pharaoh onto my windows vista. When I clicked the 'Install' button, nothing happened, not even an error message. please help.
Hi guys tried a lot of stuff from a lot of diff websites none worked was about to give up and found this and it worked right of the bat i dont know who the guy is but thanx a Bunch.
http://nienpaper.wordpress.com/2012/01/21/pharaoh-installation-fix-problem/
Aug 11, 2011 | Sierra Online, Inc. Pharaoh for Windows
1982 Honda Magna V45 2 cylinders keep cutting out
Hi, Peter_faulkn for more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
1986 VF700C Magna Intermittent Ignition Problems
Total Motorcycle Forums
Honda 1986 VFR 750F Shop Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda 1986 VRF750F Owner Manual
Sep 02, 2010 | Honda VF 750 C Magna Motorcycles
How does the belt go oon the dryer
Check the illustration I`ve attached, hopefully it help`s.
If this help`s, please take a second and rate the solution here at fixya I`ve provided. If you don`t see your dryer, reply to this post and let me know. Thank you.
Good luck.
macmarkus :)
Dec 05, 2009 | Whirlpool LER4634J Electric Dryer
The red light on the front periodically will start flasing and the picture goes off. It is progressively getting worse.
I need bit more info about TV problem to diagnose problem.
1- Please check how many times red light flashing as there would be 3 seconds pause between flashes.
2- How old is this TV?
3- Do you replug TV to turn it On or it turns On itself?
Waiting your reply to provide you solution.
Thanks.
Nov 23, 2009 | Sony FD Trinitron WEGA KV-32FS210 32" TV
Monitor does not come on at reboot.
this iz due to some loose connection of ur cables.
try 2 figure it
Apr 25, 2009 | PowerLogix PowerForce G3 ZIF, 1.0 GHz...
Further Q
if you send me ur email I'll post it to you along with a free version spotmau via attachment.if you dont want to post email here mine is tat24me@yahoo.co.uk
ps al my pc's and software are checked by norton 350 for virus and checked separatly by my email server virus software so can GUARANTEE no problems with any software I send.
Jan 14, 2009 | Computers & Internet
LG Expert Microwave circa 2001
If it fails again, please reply back to this thread. Good luck!
Aug 14, 2008 | Microwave Ovens
Computers & Internet Logo
227 people viewed this question
David Payne
David Payne
