Question about Toshiba 40RV525U 40 in. LCD TV
My Toshiba 40rv52u is freezing and fading out. It has had problems in the past where the screen would suddenly start going dark, but we could just turn it off and then on and it would be fine. That
We've had it for about 4 years, bought at BJ's Wholesale Club. It's hooked up to multiple gaming systems as well as a BluRay and a stereo system.
  • 159 Answers
SOURCE: Toshiba TV fails to recognize HDMI input
If the tv does all those symptoms but after some seconds the tv works and stays doing the job. THen the tv has a slow microprocessor to recognice the different resolutions or video inputs.
But if the tv cannot do anything and stay aout of signal forever. send the tv to the waranty. (no waranty? you have to use the component input instead to have digital signal reproduced
Posted on Apr 24, 2009
  • 100 Answers
SOURCE: just bought toshiba 40rv525u. worked fine for 2
Sounds like firmware problem if it is still covered by warranty the manufacturer can replace or sens you a usb with firmware update on it speak to your dealer about your warranty. If not covered let me know and i try find update for you.
Posted on Jan 08, 2010
budmrtn
  • 11361 Answers
SOURCE: My toshiba problem.
You may have bad T-CON board, try cooling it with small fan blowing on the vents of the TV.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Posted on Jun 30, 2010
budmrtn
  • 11361 Answers
SOURCE: I have a Toshiba Regza
Please start by looking at the power supply module first, look for caps with leaking/bulging tops, report back what you see so we can guide you further. Posting pictures will also help (use Insert Image icon, the one next to the right of YOUTUBE ICON).
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make a kit for you.
Posted on Aug 14, 2010
budmrtn
  • 11361 Answers
SOURCE: I have a 3 year old Toshiba Regza
Breaking down after 3 years is about right for LCD TV. It sounds like the T-CON board has gone out. Does the on screen menu look normal?
Learn about failed T-CON/LCD panel here and also read my guide to understand more.
http://www.scribd.com/doc/25276757/E40951307-TCON-Troubleshooting-10-22-09-OPT
http://www.mediafire.com/?zzjygannjty PDF download
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.interliquidparts.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Posted on Jul 04, 2011
Toshiba 40RV52U TV has just started cycling off & on. Is this a problem with the power board?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jan 20, 2016 | Toshiba 40RV52U TV
Right edge fades to black (Approx 2")
ok! you have defective horizontal linearity check horizontal section then check capacitors! like 180uf 200v or 200uf 200v. the problem is defective capacitors!
Sep 28, 2007 | Toshiba 44NHM84 44" TV
Toshiba Satellite C55-A5302
If it has Windows 7 on it there should be an option to dim the screen. Go to the Start menu and click Control Panel.
Click on the Power Settings icon. It should be in there on the left.
Dec 17, 2014 | Toshiba Computers & Internet
Toshiba 40rv52u remote control
If just using one remote to try have it tested----many digital cameras in a dim light will react with a flash on the display screen when remote is pointed at them and buttons pressed.
Also try putting remote against remote receiver lens on front of set--if it reacts close up---the remote receiver in the set is bad---can be same if no reaction at all.
Either the remote or the receiver---one or the other.
A last thought here is some sets (read owner manual) have a feature to lock out the remote which can be engaged by accident.
May 15, 2012 | Toshiba 40RV52U TV
There's 4 horizontal white tiny lines appear on screen to make the picture become 4 equal parts from top to bottom with many horizontal lines. My TV is Toshiba Lcd(40RV52U)
You have failure/weakening in the vertical section , the retrace lines appear due to the change in the freq.
Check out small value capacitors in this section. confirm by shorting parallel with the right polarity. Unless you are familiar with electronics please do not attempt unless with help. the fault is not very serious and could be attended with low expense.
Jun 30, 2010 | Televison & Video
Toshiba Satellite a45-s130 screen has gone real dark need a flash
Paul, Georgiana and You, 1. do you have an antivirus installed on your laptop? if not, then install one rightaway. 2. also from start->control panel->system->hardware->display adapters and monitor. uninstall the display adapters and reinstall them. similarly uninstall and reinstall the monitor drivers. 3. go to http://www.drivershq.com/Drivers/Toshiba/Satellite/A45-S130/4183/9941/10606/Drivers.aspx you will find here a driver detective that can detect your driver problems. try with that. 4. on the site above you will find drivers, for you to download and install on your laptop. if you still have problems, then you have
Sep 02, 2009 | Toshiba Satellite A45-S130 Notebook
Laptop screen fading in streaks
this thing happened in my laptop also i got green screen fully
then when i hit it behind the screen it was gone but comes many times then again i would hit
later on the screen was completly lost then had to replace the screen
yous is a starting period so go to a nearby computer service and fix the screen
May 27, 2009 | Compaq Presario M2000 Notebook
Screen Freeze and Fuzz!
bad screen cable, need replacing
Mar 25, 2009 | Toshiba Satellite A135-S4527 Notebook
Toshiba satellite a105 screen problem
You need a new lcd, The connectors are bad...
Dec 13, 2008 | Toshiba Satellite A105 Notebook
Toshiba 40RV525U 40 in. LCD TV Logo
62 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
