Question about Intel 945 Chipset Atx Gmch Heatsink
What type of heatsink to use on intel d945gcz motherboard?
The standard 775 heatsinks do not fit on this board.
5 Suggested Answers
cyrylthewolf
  • 143 Answers
SOURCE: Heatsink Removal
This is an easy one. :)
I am assuming that you're asking about removing your typical P4 HSF.
Direct from Intel's very own website! :)
http://support.intel.com/support/processors/pentium4/sb/CS-007989.htm#Removal
Good luck and please be careful. *nods*
Cyryl
Posted on Nov 04, 2007
preachw996
  • 1179 Answers
SOURCE: Heatsink for D945GCZ motherboard
You can find great coooling solutions at places like tigerdirect.com or newegg.com. There are a large option of heatsinks & fans available for this board so it all depends on what you want to pay. Hope this helps.
Posted on Feb 05, 2009
Nic61
  • 1073 Answers
SOURCE: have a 4wire motherboard for fan/heatsink on dell 530 inspiron
No need to buy a new fan, there are addapers to fix your problem.
Go to a good pc-store or order one from the net, the addapers are cheap to buy.
Good luck
Nic
Posted on Mar 13, 2009
SOURCE: Intel D865GVHZ (Gateway Hazelton) motherboard system cooling fan
This fan error message shows up when the CPU fan is not plugged into the CPU FAN plug on the motherboard. The Intel D865GVHZ
motherboard has a total of 4-fan plugs so it is easy to plug the CPU fan into one of the other fan plugs that is not marked CPU FAN on the motherboard.
Posted on May 07, 2010
Which fan/heatsinks can be used on an MS-7174 Ver 1 motherboard? It seems there needs to be clearance for some capacitors to fit beneath it.
Heatsinks are dependent on the type of processor that you have, I recommend that you call Microcenter or fry electronic
Apr 22, 2015 | MSI Computers & Internet
Trying to find heatsink unit to be able to use the board
Hello here is the intel homepage:
https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+945+Express+Chipset+Family+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+D945GCZ
Your mainboard is using the LGA 775 socket.
The heatsink fan looks like this:
The fan can still be bought in a computer store, online shop or a repair shop.
I will recommend to but a better fan, like the brand northq, because the standard fan is difficult to mount correctly on the mainboard.
Remember to add a bit of cooling paste on the cpu, before you mount the fan.
Good luck
Sep 17, 2013 | Intel D945GCZ Motherboard
Sir,i have intel motherboard d945gcz.i want to know that it actually support core 2 duo processor..?
this motherboard have processor socket LGA 775, so it can use for pentium 4, dual core and some core 2 duo. this is short list of core 2 duo that have socket LGA 775 specification: Core 2 Duo E4300, E4400, E4500, E4600, E4700, E6300, E6320, E6400, E6420, E6540, E6550, E6600, E6700, E6750, E6850, ..... (there is a lot of list that i can type in here, even there is Core 2 Quad that be use on this socket) ------> more detail visit this wikipedia website: http://en.wikipedia.org/wiki/List_of_Intel_Core_2_microprocessors
hope this useful, regards. Happy browsing.
Aug 22, 2011 | Computers & Internet
Hello, I have a Intel esys 865 gv / 775 motherboard. and win xp installed. The system hangs up after about 5 minutes after booting up. No error messages are displayed. all cooling fans are working. and...
Your system is probably hanging because of high temperature. Check cpu temperature in bios hardware monitor. If it is to high check the heatsink is fitted properly also apply thermal paste between processor and heatsink.
Mar 08, 2011 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
I don't know technical terms but there is a 4screw x that holds the sink to the mother board just to the right of the x is a small square over a chip is the square super to have a pad on it or no pad and...
Let me see if I can decipher what you have stated killa_klowns, and offer a solution.
1) The Processor has a Heatsink on it, or a Heatsink/Fan combo. Depends on what the computer manufacturer designer wanted to implement.
{Some computers have a Heatsink/Fan combo sitting on the Processor.
Other computers just have a Heatsink sitting on the Processor, and air is provided by a Front computer case fan pushing air through a plastic cover onto the Heatsink}
Typical design for a Heatsink/Fan combo (Stock design. LGA 775 processor socket. Also, not a gamer type of rig),
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5205492&CatId=493
Photos showing typical Intel Pentium 4 processors. Shows the top of the Processor's case that the Heatsink sits on,
http://www.cpu-world.com/CPUs/Pentium_4/Intel-Pentium%204%203.0%20GHz%20-%20RK80546PG0801M%20%28BX80546PG3000E%29.html
Where the headings state > Specifications - Pictures (5) - CPU ID (1) - Comments (15),
click on Pictures (5)
Thermal Paste should be used on the top of a Processor's case.
If there is a Thermal Pad, take it off, and fly it at the cat.
They're JUNK!
[ Always Thoroughly clean the top of a Processor's case, and the bottom of the Heatsink, before applying fresh new Thermal Paste. Same thing for every chipset.
> Observe Anti-Static Precautions A Processor is the most susceptible hardware component to Static shock.
Use a plastic scraper to clean the top of the Processor's case, and the bottom of the Heatsink.
I use an old credit card.
Then use Q-tips dipped in Isopropyl Alcohol (Rubbing alcohol) to clean the top of the Processor's case, and the bottom of the Heatsink.
May take several Q-tips dipped in alcohol. Usually a gooey mess.
CAUTION!!
Isopropyl Alcohol is EXTREMELY FLAMMABLE!
Use in a Well ventilated area with No sparks or flames present ]
The next chipset in line to use a Heatsink is a Northbridge chipset.
Termed Northbridge, for one, because in relation to how it is sitting on the motherboard, it is to the North of the motherboard.
On the motherboard the Northridge chip sits below the Processor.
The Northbridge chip may, or may Not have clips which hold the Heatsink on.
When no clips are used, > Thermal Glue is used to hold the Heatsink on.
{The motherboard chipset is the Northbridge chip, and the Southbridge chip.
Note* This info does Not apply to motherboards that support the Intel Core i3, i5, i7, or i9 processors}
The Super I/O chipset does Not use a heatsink.
Motherboard diagram,
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg }
Tell me what the motherboard manufacturer name, and Model Number is, and I can give you more detailed info about that motherboard.
Regards,
joecoolvette
Dec 04, 2010 | Sunon (16-02-006) Fan Kit
Right i need the size or model for the cooling fan that all intelboard mode E210882
The Heatsink/Fan combo is based on the processor socket used.
After a few search hits, I have seen E210882 on Intel based motherboards, that use two different processor sockets.
The Socket 478, and the LGA 775 processor socket.
The socket for the Socket 478 has the pin holes. The Processor has the pins. (478 of them)
http://en.wikipedia.org/wiki/Socket_478
The socket for the LGA 775 processor socket has the pins. The Processor has the pin holes. (775 of them)
http://en.wikipedia.org/wiki/LGA_775
Identify which processor socket you have, buy accordingly as to the Heatsink/Fan combo.
One example of a Heatsink/Fan combo for an Socket 478 processor socket,
(Only Intel uses the Socket 478 for their Processors),
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=578161&CatId=795
One example of a Heatsink/Fan combo for an LGA 775 processor socket,
(Only Intel uses the LGA 775 socket for their Processors),
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3302824&CatId=1588
Remember to observe Anti-Static Precautions, Thoroughly clean the top of the Processor's case, and aplly fresh new thermal paste.
(A Processor is the most susceptible hardware component to Static shock)
[ Example of thermal paste,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3071621&CatId=503 ]
If you would like advice on how to properly clean the processor's case, properly apply thermal paste, and/or what Anti-Static Precautions are, post in a Comment.
Nov 07, 2010 | Intel Motherboard
Need direct link to heatsink fan for Intel D945GCZ motherboard. What size, type, pins etc.?
this is a site about the specs on the board. it will tell you the socket type that is required for it. and what other specs you might want. CLICK HERE
Sep 30, 2009 | Intel D945GCZ Motherboard
Does anyone know what the part number is for the heatsink bracket for this mobo??
There is no part number, you go by the socket type which is a Socket 775 heatsink.
Regards.
Jul 14, 2009 | Intel D102GGC2 Motherboard
Feb 05, 2009 | Intel D945GCZ Motherboard
Intel 945 Chipset Atx Gmch Heatsink Logo
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
