Question about Gaggenau AH 900-761 Kitchen Hood
How to clean gaggenau kitchen exaust filters?
Filters are greasy and the F light/button flashes periodically. What is the best way to clean the filters and ensure the finish is not damaged?
Took filter out to clean pressed contol switches to cancel red cleaning light but think I pressed wrong switches on control continually flashing when switced on and fan not working
You have entered a programming mode. BTW, the light is a time activated thing. There is no sensor for blocked filters. It is just there to remind people that don't bother clean them regularly. Try holding the on / off button in for 5 seconds. With out knowing what you actually did, it is a bit of a trial.
Feb 10, 2014 | Miele DA 289-4 Kitchen Hood
How do I get the red light to go off on fan
That is just a reminder based on operating time to clean the filters. Just hold your finger on the clean filter button for 10 seconds to reset it, as per the operators manual.
Jan 19, 2013 | Miele DA409 Kitchen Hood
Smeg KSE1V950X fan lights flash? Is this a filter cleaning issue and how do I reset it?
Yes this is a sign to clean the filters. Once they have been cleaned, it can be reset by pushing 2 buttons together at the same time - I just tried several combinations until they stopped flashing.
Sep 05, 2011 | Smeg KS9XSE Stainless Steel Kitchen Hood
The air filter light is coming on . Can you tell me where the filter is located and the correct way to clean or replace fillter. thank you kev
There are three filters in the RHFE-1004A. The lamp indicates the two air filters need to be cleaned. Turn off the heater. Then pull the filters up from the back of the top of the unit (the side against the wall). Vacuum or dust both sides of each filter. If you notice that the filters are greasy, clean them by washing them quickly with detergent. Rinse the filters completely and then allow them to dry before reinstalling them. (The last filter is above the humidifier water tray.)
The manual for the Rinnai RHFE-1004A is available here: http://www.inglenookenergy.com/rinnai/direct_vent_wall_furnaces/rhfe-1004fa/Owners_Manual_1004.pdf . See page 29 (page 31 of the pdf) for pictures.
I hope this helps.
Jul 15, 2011 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Fan light flashing on thermador vent hood model HNW36YS
Grease Filter Saturation LED The speed 2 LED in Figure 1 in is marked with an F. This LED will flash to remind you when the grease filter needs to be cleaned after 40 hours use. Follow the instructions for cleaning filters in thisFollow the instructions for cleaning filters in this booklet. Once the grease filters have been cleaned, reset the display by pressing button A for
Sep 05, 2009 | Thermador HNW48YS Stainless Steel Kitchen...
Press the ?filter? button to turn off the indicator light !!!
Try pressing and hold the filter button for about 15 seconds. See if this works for you. If I can help further, I am here......Eric Campion
Feb 26, 2009 | Broan-NuTone Allure III QS330SS Kitchen...
Exaust vent/ fan very weak
In your duplicate post, you mentioned your model, so here you go:
This is due to poor air flow, either to a blockage or a problem with the internal cooling fan or hood vent exhaust fan.
Are the grease filters or charcoal filter clogged?
You may want to check your owner's manual for info on checking the filters. Grease filters can be cleaned, but charcoal filters must be replaced about every 6-12 months.
The installation manual will tel you if there's some error in the installation setup.
You can download Maytag owner's manuals and installation instructions here.
Dec 10, 2008 | Microwave Ovens
Exaust fan has weak suction on maytage mmv4205baw
Dec 10, 2008 | Maytag MMV4205 Microwave Oven
Clean Filter Red light
I cleaned the filters as well earlier and the red filter light still blincked to clean the filters. Then I pushed the power button for about 10 seconds continously and then turned it on and the light turned off.
May 22, 2008 | Brookstone Pure-Ion UV Air Purifier
Gaggenau AH 900-761 Kitchen Hood Logo
Top Gaggenau Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Gaggenau Kitchen Range Expert? Answer questions, earn points and help others
