Question about Haier HLP21E Top Load Washer
Something must be clogged because the water wont flow into the machine and sprays around the top of the hose end at the washer. I checked the little filter under the hose and its clean.
The original hose blasted off the faucet end and I thought I just needed a new inlet hose. Bought 2 and it simply is not letting the water come in the washer, I took off the little blue filter and there is water standing in the port and what looks like a valve?
  • 35 Answers
There should be lights blinking, indicating a fault.
If this unit is brand new call warranty service.
If this unit has run in the past you will need either a new intake valve or new computer sequencer board.
Posted on Oct 15, 2013
4 Suggested Answers
SOURCE: Haier XQB55-10 : water leakage from inlet hose jointer
Inside the connector is a flat washer and a mesh filter. one side of the mesh filter has a strip/bar across it, this filter goes into the base of the connector with the strip/bar upwards, make sure it is seated in the connector properly.
Then fit the flat washer ensuring that it is clean/undamaged and lying flat at the base of the connector, the mesh filter strip/bar has at either end a small lip, the washer goes underneath the two lips, if it is placed on top of these lips it leaks!
99% positive on this, if not buy another hose!
Posted on Mar 16, 2009
  • 67 Answers
SOURCE: Popping while removing Hose Adapter
This is a common occurrence. When you turn the tap off, high pressure water is stored in the washer hose & fitting. Try leaving the tap turned on while you remove the quick-release hose adapter. Or turn the washer on (so that it would be drawing water) while you disconnect it.
Posted on Jul 27, 2009
caroldon
  • 17130 Answers
SOURCE: Hello, my washing machine has
The drain valve is faulty or the valve is choked wit dirt and kept half open. you can find the valve connected at the outlet hose from the tub.
Remove the drain valve and try cleaning . Check the voltage on the valve once the wash cycle starts , it must be OFF . If it leaks then the valve is faulty and needs a replacement if cleaning wont help. However if voltage stays on to keep the valve open then it is a fault with the controller which should give the volatge only for draining .Check in the controller section for the drain valve driver to be faulty. It might be difficult to change the driver which can be a SCR or a relay as the PCB's are epoxy filled to prevent moisture on board.Other wise the board has to be replaced or for a stop gap you can have a manual switch but the washer becomes manual.
I hope my advice helps, please check and decide, Credit me if this info is useful.
Posted on Aug 20, 2010
Washer will spin but not fill with water nor agitate....
Machine must have full tub to agitate, so lack of water is likely causing that. Step 1: Unplug machine. Next turn off the water supply at the taps behind the machine. With pliers loosen (about 1/2 turn each) both hose ends at the machine connection. If one or both hoses do not relax, but instead spray water continuously STOP retighten them and let me know. If hoses do relax finish removing them. Where they attach is the inlet water valve. There are screens at the ends of that valve that can become clogged with lime and other debris. If they are covered with crud clean them with a toothbrush. If not look at the supply hose ends and the hose itself. Lime will also build up in the hose ends and can severely affect water flow. Put the hose ends over a bucket or the tub of the machine and turn on water supply to check pressure coming from the hoses. If you've got good pressure and the screens are clean you likely will need a new inlet watervalve. Before purchasing one you should be sure and check the wire connections at the valve. Make sure you've unplugged the machine then wiggle the connectors around and make sure they are seated properly. Then try the operation again. If still no water the valve is surely bad. Let me know.
Jan 20, 2013 | Washing Machines
Wont fill up with water
Do you get any water coming into the washer?
If water is not entering the washer, check that the incoming water valves are open and water flows through them. (Take off the hoses and put a bucket under the pipes.) Make sure that any filters are not clogged (for example with bits of damaged washer). Make sure that the hoses are not kinked. Next take off the hoses from the washer's fill valve and check if the filters are clogged (not present on all washers). Try replacing the hoses (there are anti-flood hoses that will seal themselves if they sense a leak). If that doesn't help, then the valves probably need to be replaced.
If water is entering the washer, check the filters at the inlet valves for partial blockages. Next check your water flow rate. (If the flow is too low, the washer may shut down. Check your manual for details or add a comment with the model number of your washer.) Next check if the water is being siphoned into the drain. This will occur if the drain hose is not positioned properly in the stand pipe (or sink). If the end of your drain hose is lower than the washer water level, this can happen.
I hope this helps.
Aug 11, 2011 | Whirlpool Washing Machines
Lf code on washer.checked hoses and valve both ok unit will run after opening the lid and closing lid and pressing start again. takes 10/15 minutes for a load to start
LF means that it is taking too long to fill. (If the water fill time exceeds ten minutes, the water valves are turned off and LF is flashed.)
Supply hoses could be kinked or clogged(some have screens in the end).
This could be a supply water pressure/flow problem. Make sure you have good water flow though the hoses to the machine. (Take off and try running into a bucket)
The water fill valve may be failing to open all the way or it could be clogged.
I hope this helps.
Mar 20, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
GWWJRR4170E4WW WASHER WONT STOP FILLING WITH WATER. pRIOR TO THAT IT WOULD AT RANDOM SKIP CYCLES OR NOT SUT OFF AT THE END
pop open the front. Check the little 1/4 in hose going to the side of the tub. It may have gunk build up inside it blocking air flow. Its the pressure hose that tells your water level switch how much water is in the washer. Clean it out as well as the port it attaches to.
Dec 01, 2009 | GE WJRR4170E Top Load Washer
Is there a cold water filter on this machine. The
there is often a screen located in the hose end ... you can clean, replace or remove the screen and always replace the hose washers but its far better to replace both hoses with good quality new ones .. the safe lifetime of the hoses is only a few years ... so its a good idea to replace them every few years anyhow ... while you have the hoses off you can check water flow to make sure the shut off valves are not clogged .. (make sure they were both fully "on" to start with) .. if there is good water flow and the screens are not clogged then you may have a clogged solonoid valve (just inside the machine at the water inlets) (has wires going to it also)
Oct 04, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
HOW TO DRAIN WATER IF MACHINE SOPS AND WONT RESTART
I take it that you have tried rotating the cycle knob slowly through the point at the end of the wash cycle to the rinse cycle? On many machines, this will trigger the pump to drain the tub. Yet I am guessing that you have already tried that.
You could try running a garden hose from the machine along the floor and then outdoors. Next, take the end of the garden hose and place it into the top of the machine so that the end of the garden hose goes to the bottom of the tub. Feed in another five feet of garden hose into the machine so that this five feet is below the water level. Now, hold the palm of your hand over the end of the garden hose at the bottom of the machine and while doing this, pull out the extra five feet of garden hose and then remove your hand from the end of the garden hose. This should have "primed" the end of the garden hose with water so that the water will get sucked out of the machine and flow through the garden hose to the outdoors.
If this doesn't work, then you will need another person to **** on the other end of the garden hose in order to get the water to start flowing through the garden hose.
Apr 25, 2009 | Maytag MAH2400A Front Load Washer
Bissell carpet cleaner
The water sprayers on your Bissell are probably clogged. I had this problem this morning, myself, with my machine, about 15 months old. They get clogged up with mineral deposits. This is a *fairly* easy thing to fix yourself. Read all the way to the end before trying this fix.
Unplug the Bissell. Remove the water container pieces from the top of the base. You'll probably reveal two red plastic pieces mounted in the Bissell's base, about .75" x .75". These spray water on your brushes when you press the water-and-soap trigger at the top of the Bissell's handle. These water sprayers tend to clog. See the metal spring running up the hose, behind each red water sprayer? As you squeeze the red plastic sides of one red water sprayer, use a screwdriver or other tool under the spring to wedge up the hose, to release the sprayer from its mount in the base. Stick a finger in the hole of the base of the Bissell where the sprayer was mounted and run it around the edges there including on the underside of the base to clean out any gunk you can find. Clean any gunk you can off the red water sprayer with an old toothbrush.
Now you need to remove the water sprayer from the hose. You need a pair of pliers. Use the pliers to squeeze the brass colored clip that is keeping the red water sprayed mounted to the end of the small hose there. Move the clip down the hose so it compresses the spring and is no longer on the red plastic water sprayer. Now you can twist and pull the red water sprayer out of the end of the hose. You'll need a little hand strength to do this. Just be careful not to break the water sprayer by using a tool. They're not particularly delicate, but breaking one would render your Bissell useless until it was replaced, so use a little care.
When you've removed a red water sprayer from the hose, put the outer end of the red water sprayer in your mouth and seal your lips around it, and try blowing through it. You can't blow air through it, right? It's clogged. Open up a paper clip and push it back-and-forth through the small hole in the end of the water sprayer back towards its middle. You'll probably push out a line of white mineral deposits. Clean them off the water sprayer with the old toothbrush, and try blowing through the water sprayer again. If air passes through clearly, you've fixed it. Now you have to put it back together. Push the water sprayer back on the end of the hose. Use the pliers to reposition the brass clip on the end of the hose over the water sprayer. Push the red water sprayer back into position in the base of the Bissell.
Now do the same for the other red water sprayer.
I had a problem when I fixed this on mine this morning, because when I pulled one water sprayer off, the hose advanced up under the spring and I couldn't reattach the red water sprayer, because it couldn't reach the end of the hose. So try to use the brass clip or some other means (rubber band, tape, another clip) to keep the hose from crawling up inside the spring after you pull the red water sprayer off the hose. If the hose gets up under the spring anyway, despite your best efforts, I fixed this by removing the six screws on top of the Bissell base (the surface of which the water tank mounts on top of), and then pried it up. You can pull out the hose, reattach the red water sprayers to the hoses, position the hose *very carefully* inside the base (there are mounts under there they need to fit into, so you don't break anything), push the red water sprayers through the mount holes and mount them, and then reattach the screws to the base.
There's something else you may need to do that can help get the water flowing. This one's easier. The Bissell uses pumps, which need to be primed. Sometimes an air pocket inside the machine keeps water from flowing. To prime the pumps, separate the two water tank pieces. Fill the base as usual and mount it on the Bissell without the top water tank piece. Plug the Bissell in and **turn it on**. (The Bissell must be running to do this.) Kneeling on the floor in front of the Bissell, reach up and press the soap and water release trigger at the top of the Bissell's handle and hold it in as if you wanted water to go through. On top of the water tank is a plastic grommet hole about 1 inch in diameter, through which you pour water to fill the tank. Seal that hole with the flat of your hand. You'll feel a bit of suction. Lift your hand up and down a few times. Release the trigger and repeat a few times. Now that you've cleaned out your water sprayers and primed the Bissell's internal pumps, I'm hoping water will GUSH through your Bissell once again.
As you probably have learned the hard way, as I did, it's VERY important to do a lot of cleaning of the Bissell after each use, more than the manual tells you to do. Clean the bottom of the unit. Empty all the water. Thoroughly rinse out both water container pieces. Unscrew the three clear plastic pieces, one in front, two on the sides, that surround the brushes, and rinse them thoroughly in water. Clean off the brushes and all the lint and gunk around and above the brushes. (A water spray bottle and toothbrush are helpful here.) Tip the machine and blow all the water out of the hole in the base. Release the red clip springs on the red water sprayers and blow on them. Doing this will slow the failure of the Bissell. It's a great little machine for the money, but it does have a learning curve and need more pampering than a vacuum cleaner, doesn't it??
Jan 24, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
Water Leaking really bad from the Dispenser area
Disconnect the plug from the outlet. Remove the top of the washer panel by removing the 2 back hex screws then sliding it back to lift it off of the washer. Take off the front control panel by removing the phillips screws holding it in place. Remove the dispenser drawer. Check the dispenser housing for clogs or lime build up at the bottom of the dispenser housing. Or the drain hose (large black hose attached to the front of the drawer housing) to the washer may be crimped or clogged.
Aug 14, 2008 | Maytag MAH6700AWW Neptune Front-Load...
My washer wont drain
Either your pipe to sink is clogged or nearly clogged or the pump on the washer is about to give out. Does the water spray out vigorously when using the container, or does it just flow out?
Jul 02, 2008 | Kenmore 24032\24036 Top Load Washer
Haier HLP21E Top Load Washer Logo
78 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
