Question about LG DLG2532 Gas Dryer
How do I access the thermostat - LG DLG2532 Gas Dryer
    Top Expert:
  • LG Master
  • 9,472 Answers
You will need to remove the front of the unit.
Posted on Dec 04, 2012
How do I access the cable connectors on a Eichenauer 40004314 heater thermostat unit on a Hoover VHC392T
did you take the panels off to access the Thermostats and heating unit?
Aug 10, 2014 | Hoover Dryers
Wiring diagram for smeg thermostat
Good Afternoon Friend,
I understand that you are looking for the wiring diagram, to replace the thermostat, in your Smeg appliance. The wiring diagrams are typically not accessible to the public. I suggest contacting the manufacturer, as they might have access to that wiring diagram for your appliance. Hope this is helpful.
-Best Regards-
WP
May 13, 2014 | Frigidaire FRS3R5EMB Side by Side...
On a 1997 Mazda Protege, must I access the thermostat for under the car, in order to replace the thermostat ?
do yourself a favor.. take this to a mechanic and let them change it..I fear you dont know how to do it yourself and may ultimately tear the thing up trying...
Dec 24, 2013 | Cars & Trucks
IM TRYING TO REPLACE THE THERMOSTAT ON MY 2004 ENVOY WHERE IS IT LOCATAED EXACTLY
The thermostat on this vehicle's In-line 6 cylinder engine is on the driver's side of the engine, below & behind the alternator. You have to remove the alternator to gain access to the thermostat housing. You also need to disconnect the battery before you remove the alternator to avoid sparks and shorts.
Most directions outline removal of the alternator to gain easy access to the hose clamps, bolts and housing of the thermostat. I have located a site that after free registration, has detailed instructions on how to do this job, and the link below that describes an easier method with photos. Check out:
http://forums.trailvoy.com/showthread.php?t=54225&highlight=replace+thermostat
Mar 15, 2011 | 2004 GMC Envoy
Where is the thermostat on a 1997 Oldsmobile 88 3.8 v6 engine
While standing at the front of the vehicle, look to the right side of the radiator to find a large hose connected to the radiator. It will lead you to the thermostat housing. The thermostat is located inside the metal pipe at the other end of the hose. Exact mounting details vary with model year. Generally, there are two bolts, one above and one below the housing that must be removed to access the thermostat. The heat shield on some models for the exhaust crossover pipe partially blocks access to the bolt heads, so some tricky tools are needed to remove it. On mine, I removed the EGR sensor and heat shield so I could access the bolt heads. Once removed, the thermostat is very simple to replace.If the thermostat is located on top you may have to take off the altenator tension bracket.
Mar 13, 2011 | 1997 Oldsmobile 88
I have a heat pump for heat and a.c. Yesterday, on the thermostat on the wall it said REPLACE BATTERY. How do I do that, and what size battery will it take?
Remove the cover of the thermostat. That will give you access to the battery. It's probably a AAA battery. The cover of the thermostat should just pop off. However, on some programmable thermostats, just opening the programming door will give you access to the battery.
Feb 25, 2011 | Honeywell Electronic Programmable...
I need to change the thermostat.. what do i need to do to get access to it...
The one thing that is in the way of getting access to the two bolts for thermostat is the alternator.
Sep 21, 2010 | 2004 GMC Envoy
How do I replace the thermostat in a 95 chevy Beretta 3.1 v6
you need a socket and a swivel to reach it, the bottom hole in housing is slotted so you won't need to take the bolt all the way out.
Feb 12, 2009 | 1995 Chevrolet Beretta
How to access heating element and thermostat on Admiral ade7000ayw dryer
The top has a hinge bracket in the back. pop the front up with a flat screw driver. you should see the heating element there and be able to access it from that point.
May 21, 2008 | Dryers
LG DLG2532 Gas Dryer Logo
41 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
