Question about Kitchen Ranges
When was Roper GAs Range model 1336 sold
Roper, model 1336, gas range. repair or replace?
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
What problem are you having?
Posted on Dec 04, 2012
fridgetech
  • 473 Answers
SOURCE: Roper gas range Model# FGS337GQ
Here are the codes for you range:
F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock (ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock (ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0
F5 - E1 and E2 Door latch problem Check door/latch switch, replace if necessary
Looks like yours is a bad oven control. There is a # at the end of your model # 0-5 that will determine which control it takes. Once you have that # you can look it up at http://www3.sears.com/ Looks like the part costs about $165.
Posted on Nov 05, 2007
  • 1314 Answers
SOURCE: Manual for Kenmore gas range
try this http://www.kenmore.com/shc/s/nb_10154_12604_NB_CustomerCare?adCell=AH
Posted on Dec 31, 2007
SOURCE: Convert natural gas range to propane
I want
Posted on Jun 09, 2008
aborcass
  • 2651 Answers
SOURCE: Maytag MGR5775QDS Gas Range Control Panel Problem
sure you can relace yourself, the part number, if you dont already have from previous repairs can be obtained fromthe sears website, or by calling manufacture direct. as far as a schematic there should be one located behind the range.
Posted on Feb 21, 2009
SOURCE: Roper Gas Range
F1 Error
My Roper gas range is sounding an alarm call with number F1 flashing. Can anyone reveal what the code means before I call service? Thanks!!
Posted on Jul 28, 2009
Roper gas range. Oven glow coil comes on but has no gas to heat?
if the glow igniter is on and it doesnt light its probably the gas valve
Feb 12, 2012 | Roper FGP300 Gas Kitchen Range
Tried to start my oven and it wouldn't. Gas range and the burners on top light up. Had a delivery of gas the other day, could that be part of the problem? Why doesn't my oven start?
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Aug 22, 2010 | Roper FGP325K Gas Kitchen Range
Roper Gas Range Oven Makes Sound
check you have ventilation. i.e. try with the window open
Feb 14, 2010 | Roper FGP305 Gas Kitchen Range
Why won't my roper gas range (FGS337KQ) stay lit? The oven will light for 30 seconds and then shut off. Ignition is working.
you may have air in you gas lines make sure to hold pilot setting down for about 30 sec then light
Oct 30, 2009 | Roper FGS337 Gas Kitchen Range
Have Roper LP Range model S8757. This is a self cleaning oven but takes forever. So I cleaned it myself and now oven won't light. Get F3 on display.
Your oven temperature sensor is bad and must be replaced.
It is inside the oven, a short metal piece extends into the oven. It is secured by a screw into the back wall of the oven.
Oct 12, 2009 | Roper FGP305 Gas Kitchen Range
Control panel Roper gas range replace or buy new range?
4337979 Control-Clock/Oven
Retails for $206.90 easy to replace good luck..
Sep 28, 2008 | Ovens
Stove replacement?
All the fault codes I could find on Roper indicates that this is an Electronic Oven Control (EOC) failure. This is your clock assembly. Searspartsdirect.com carries the part for about $47. I think for that price, it may be worth the attempt to repair the range, vice replacing one at a cost of hundreds of dollars. Just type in your model number and you can locate the clock assembly under the "Backguard Section" heading as item number 17 (part number WB27M10). I hope this helps you.
Aug 17, 2008 | Roper FGP325K Gas Kitchen Range
Roper Gas Range
F1 Error
Mar 24, 2007 | Roper FGP305 Gas Kitchen Range
Kitchen Ranges Logo
50 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
