Question about HP Compaq Presario SR1420nx (SR1420NXPS69AA) PC Desktop
Compaq 1420 nx turns on then turns off immediately
I tried to boot up my compaq desk top computer which I haven't used in over a year. It worked fine previously. When I power it on it runs for about 2 seconds, then shuts off. All 3 fans are operating.
  • HP Master
  • 5,660 Answers
A brief primer if I may;
Electrolytic Capacitors are used on the motherboard, and in the Power Supply, in the Compaq Presario 1420nx Desktop PC;
HP Support > Compaq Presario SR1420nx Desktop PC > Main Support page,
http://h10025.www1.hp.com/ewfrf/wc/product?cc=us&dlc=en&lc=en&product=457247&
Product information > Product specifications > Motherboard Specifications, P4GV-LA (Guppy),
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00363478&tmp_task=prodinfoCategory&cc=us&dlc=en&lc=en&product=457247
Scroll down to the motherboard Photo.
http://capacitorlab.com/visible-failures/index.htm
General example of a Switched-Mode Power Supply, (SMPS), case open,
http://en.wikipedia.org/wiki/File:ATX_power_supply_interior-1000px_transparent.png
Personal computers have used this style of Power Supply, for quite some time.
The one in your computer is just an ATX style, and is the type used in MANY personal computers. (Not Small Form Factor, however)
THIS IS NOT an invite to open your Power Supply, and attempt repair.
The capacitors used are Radial Aluminum Electrolytic Capacitors.
The blue ones marked by the letter B, are high voltage. MAY have Up To 100 Volts stored.
Your fingers touch the terminals on the bottom, of one of these babies; the shock can be BAD to FATAL!
Your fingers touch a circuit, that one or more capacitors are in, and the shock can be BAD to FATAL.
There is a Proper method to discharge them, BEFORE working on the unit. Am not going to post.
(Does NOT involve a metal screwdriver, or other metallic object! Good way to have hot molten metal spray in your face!)
The method of repair is to REPLACE.
Inside an Electrolytic Capacitor is Electrolytic Paste.
This paste breaks down over time. Chemical composition breaks down.
Computer engineers know this, and use capacitors that are rated at twice, or 200 percent; of what is needed.
This way when the capacitor breaks down to 50 percent good, it is still 100 percent good for the application it is used in.
Unplug an electronic unit from power, and the chemical composition of the paste breaks down more rapidly. All electronic units need a trickle charge when being stored. (Pawn shops know this)
To summarize;
FOLLOW Anti-Static Precautions after unplugging your computer from power, BEFORE reaching inside your computer. (Don't know, and would like to? Post in a Comment)
Check the 'caps' on the motherboard.
Note* Sometimes the Electrolytic Paste dries up, and shows NO outward visual signs of failure.
'Caps' on motherboard found to be good, suspect the Power Supply.
I can guide you in testing it, or you may have a KNOWN to be good, Compatible power supply, from a working computer that you can borrow for a test unit.
Regards,
joecoolvette
Posted on Dec 04, 2012
  • joecoolvette
    joecoolvette Dec 04, 2012
    To Add: I suspect the Power Supply. Why? Because I believe it has a weak voltage power rail. 1) If ALL of the LED's (Lights) were on at once, they would use less than 1 Watt of power. 2) EACH fan uses 2 to 3 Watts of power. 3) A typical Processor can use from 51 to 125 Watts of power. Therefore a Power Supply with a weak voltage rail will have plenty of power, to light simpy little LED's, and spin fans, but Not enough power to turn the Processor on. Intel Celeron, Model 340? (2.93GHz) Uses Up To 73 Watts,http://en.wikipedia.org/wiki/List_of_int... (Scroll down) Bet the computer is dirty inside also. Regards, joecoolvette
  • Charles Panchak Dec 04, 2012
    Thanks for the help. I removed and reinserted the ram and the modem board (I think it was modem board. Now machine stays running, but makes a steady beep sound which lasts about 5 seconds, stops and beeps again. Nothing showing on monitor
5 Suggested Answers
siawolf
  • 749 Answers
SOURCE: HP Compaq Presario SR2013WM ...Power Problems ?
Unless the power button sticks or does not pop back out, i doubt the issue is in the switch, but it can be tested by replacing it with a momentary switch from Radio Shack (not an exact fit, but good for testing)
This sounds like a power supply issue. That would be the first thing to check. If it is NOT connected to anything except the power cord , it shouldn't run unless switched on.
Could also be the motherboard, but before you start dismantling the computer , check the obvious. Open the case (usually to screws on the back) inspect all the cables, reseat your ram chips and addin cards.
Not to scare you ar anything, some of these presarios have bad capacitors on the mother board. coupled with the fact that they are difficult to clean (inside) and airflow is not maximized in the case, they tend to cause the capacitors to swell and leak, losing voltage.
When you are inspecting the insides of your case, take note of any capacitors (little cans with crosses on the top) on the main board inside around the CPU fan that are swollen or leaking.
If you find these in bad condition , i would replace the motherboard.
Posted on Apr 04, 2009
pankaj_dic
  • 1250 Answers
SOURCE: Compaq Presario SR1650NX will only
DO one thing remove the RAM from the slot , then insert it again, then check
Posted on Sep 17, 2009
sparky1500
  • 1066 Answers
SOURCE: Computer died - will not reboot - even to show system bios.
motherboard or cpu failure. or possibly power supply.
Posted on Dec 27, 2009
mpcheeseman1
  • 1400 Answers
SOURCE: my hp compaq presario sr2150nx would not turn on
Is power supply set for 115 volts?
Is power supply compatable to motherboard voltage input?
Posted on Jan 16, 2010
Dell desk top just spins when tuned on, won't load internet, why ?
I would try this.
You may have a virus, malware, adware, a browser hijacker, or pups (potentially unwanted programs).
A. If your computer will boot and you can operate it ok...
Download and install Malwarebytes and Superantispyware (Note: If you can\'t do the download on your machine, do it on a friend\'s, put them on a thumb drive, and install them from it). Then scan your computer with each program, and quarantine anything found.
B. If your computer won\'t boot, or can\'t operate properly after boot...
Tap F8 when you are booting, select "Safe Mode With Networking". Download and install Malwarebytes and Superantispyware (Note: If you can\'t do the download on your machine, do it on a friend\'s, put them on a thumb drive, and install them from it). Then scan your computer with each program, and quarantine anything found.
C. If this process finds malware, to keep stuff like that from coming back, I recommend you get the paid version of Malwarebytes.
Jul 23, 2014 | Dell Computers & Internet
Why won't my COMPAQ PRESARIO SR2032X desk top
Please turn off the computer, start hitting F8 at the start-up and then choose last known good configuration. If this does not work, choose Safe mode options.
If still does not work, please try to restore the computer to factory settings. You can try to hit F11 or F10 at the startup to initiate recovery.
If not working, please tell me what error message you get on the screen.
Jun 01, 2013 | Computers & Internet
My Compaq series SR1311 NX won't run, need a replacement
Responsibly recycle that "dead" computer, and buy a new computer with Windows 8.
Jan 14, 2013 | Compaq Presario 900 /1500 Series EVO...
Compaq 1420NX - When I turn power on it runs for 2 seconds and shuts off. All 3 fans are operating. I haven't used it in over a year, and it was working fine when last used
b> Computer does not boot up The problem maybe the RAM, it is faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you. Just like you sometimes need a mechanic to repair your car, sometimes you do need a technician to diagnose and identify the fault or faults on your computer. Not only does a good service technican have the experience to deal with this type of problem, they also have the equipment that allows them to look at things the average computer user can't see, and he has a collection of replacement parts that can be used to quickly test individual components on your computer.
Dec 04, 2012 | Compaq Computers & Internet
Compaq presario cq70 wont boot up
old Compaq (now HP)
https://h30434.www3.hp.com/
first screen died, now wont boot, to external VGA monitors.
Fn+F4, sure. the external command key. sure
ok VISTA, first time any one tells what OS is there, wow.
step one on all PCs lap or desk top is what,
does the screen show any text at all?
like Hit Esc to enter setup or BIOS>
we first see of BIOS is alive. it not the PC is DEAD.
zero text means DEAD PC> and NO BIOS means DEAD PC
so out comes that old useless LT battery.
useless as in , if its original its bad. most are.
you skipped step 1 here, (battery out)
and next fans work? and blow air, no lint packups. inside.
learn that PC's go dead, with overheat, can happen fast.
http://pcdied.com/black-screen.html#Laptop
Jun 28, 2017 | Compaq Computers & Internet
My dell desk top computer will not boot up
please insert the recovery disc and boot from cd and recover the computer.
Mar 19, 2012 | Dell Dimension 3000® Pentium® 4...
I have a Compaq Presario SR2020NX. I press the power button and the fan comes on, the green light is bright , the cd drive blinks then stops as if the computer is starting but nothing happens. The fan...
Disconnect the drive and try to boot to the BIOS (usually with F1, F2 or Delete key). If that doesn't work, try removing all cards from the computer (except a video card if the video port is not on the motherboard). If you can boot this way, try inserting back any removed cards to see what hangs it. Do you hear any beeps when the computer is booting (beep codes)?
Sep 24, 2011 | HP Compaq Presario SR2020NX PC Desktop
I want to hook a tv to my computer compaq presario model # SR 1420 NX how do i do it
You need a TV Tuner Card. Either an Internal or an External one.
http://shop.ebay.com/?_from=R40&_trksid=p3907.m570.l1313&_nkw=tv+tuner&_sacat=See-All-Categories
Aug 28, 2010 | Compaq Computers & Internet
Compaq Presario S5100 NX PC Desk Top -
Is the Driver sor the sound card up to date, try to see if it is even installed, if it says that no audio device is installed, go to the drivers page for your computer, and then download the sound driver for your sound card
Oct 07, 2008 | Compaq Presario S5100NX (E120866) PC...
HP Compaq Presario SR1420nx (SR1420NXPS69AA) PC Desktop Logo
76 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
