Iomega Screenplay Director won't power up. The led
SOURCE: Remote code for the iomega screenplay
I bought the JELLY Universal PC Programmable remote in Portugal for 10 euros. The code for Iomega Screenplay is 2297. See it here: http://www.wiltsgrove.co.uk/sub-category.php?ID=1709&CID=0026&PID=IR2005
Posted on Mar 30, 2009
SOURCE: Iomega Screenplay Pro HD - No Menu
I had the same problem with the Screenplay Pro HD. My Iomega was working fine and one day after exchanging files with a friend I got the logo, then the loading message and then it went into a black screen while the blue light kept blinking.
Obviously the connection to the TV was fine because the logo appeared.
I solved the problem by downloading and reinstalling the firmware.
I downloaded the firmware from the iomega web site.
Notice that during the installation process you get the message that it will delete your data and then shortly after you have the option to delete or keep it. Hang in there. This part is a little nerv wrecking.
Hope this helps.
Rainer
Posted on Jan 03, 2010
  • 71 Answers
SOURCE: Resolution not supported error on Iomega SCREENPLAY HD 500gb
Avi files should be 700 or below when playing on a conventional tv,625 or 525 prefered.
if set to hd format trough HDMI output the display warning will not appear has the iomega will upscale trough the HDMI output,and will suport any resolution.
Posted on Jan 20, 2010
SOURCE: My Iomega Screenplay 500 isn't working
Your Iomaga Hard Drive is broken. The clicking noise is the heads ggrinding off the palate and this problem can not be fixed. If your player is less then 1 year old it is guarenteed and should be replaced. Otherwise, it the hard drive inside needs to be replaced!
Posted on Feb 07, 2010
SOURCE: Iomega Screenplay Pro HD Multimedia Drive works on PC but not on
If the blue light continues to flash after the screen goes black, then you need to reinstall the firmware. Look at http://screenplayprohd.wikia.com for information about getting the firmware and installing it.
If the blue light goes solid after the screen goes black then you probably just need to switch the NTSC/PAL selection. Press that button on the front panel several times, waiting a few seconds inbetween in press. If it continues to be invisible, plug the drive into another TV using the composite cables instead of HDMI to confirm if the menu comes up at all. If it does, reinstall the firmware.
Posted on Apr 06, 2010
Iomega screenplay director firmware
Iomega i ScreenPlay Director SPDHD - Lenovo Community
forums.lenovo.com > ... > Iomega Desktop Network Storage
Nov 16, 2013 - 5 posts
Hola, tengo un iomega screenplay director y hasta ayer me ... aqu?: Versi?n 1.4.0.92 del firmware de ScreenPlay Director: Leer primero Iomega Screenplay Director HD doesn't work on TV
Mar 15, 2015
Firmware Iomega screenplay HD500
Feb 9, 2014
How to find, download and install firmware on my i...
Jan 14, 2014
Iomega ScreenPlay Director error 12
Jan 10, 2014
More results from forums.lenovo.com
Dec 25, 2015 | Iomega ScreenPlay Director 1TB HD Media...
I HAVE THE IOMEGA SCREENPLAY DIRECTOR EDITION CONNECTED TO A MITSUBISHI 73" DLP TV THROUGH HDMI AND ALL I GET IS A BLACK SCREEN NO MENU
Try another HDMI port. Also, you may wanna try to switch the TV-set to various resolution-modes to see if the device 'likes' it better and sees it first.
Dec 26, 2012 | Iomega ScreenPlay TV Link Director
How do i connect my iomega screnplay director for the first time?
First Time Setup: 1. Connect the power supply to the ScreenPlay Director and an uninterruptible power supply (UPS) or power outlet. 2. Press the power button on the front of the ScreenPlay Director to turn it on. 3. Turn on your TV and change the input setting as needed to receive input from the ScreenPlay Director. 4. When the ScreenPlay Director setup wizard appears on the TV screen, select your language and the TV screen aspect ratio, then configure your network connection. Refer to the user's manual if you need additional instructions. NOTE: If you wish to skip the network configuration during first time setup, you can add it at a later time using Settings from the ScreenPlay Director home menu. See the user's manual for detailed instructions. ----------------------------------------------------------------------------------------------------------------------------------------- If you need any other information about your device, I would suggest looking at the user's manual as it will pretty much answer any other questions you have about your device. Click on the blue links below. ScreenPlay® Director HD Media Player User's Manual: View Online [HTML] ' Download [1.0MB zipped HTML]
Quick Start Guide [PDF 1.2MB]
Specifications
Dec 23, 2010 | Iomega ScreenPlay Director HD Media Player...
I have the iOmega Director. YouTube is not working. . Every thing I select says "The content you requested was not found".
April, 2010 - Iomega learned that YouTube made some changes to their programming APIs. Iomega uses YouTube's APIs, or programming interface, to interact with their service and their site. Until Iomega can learn more about the changes YouTube made, and re-program the ScreenPlay Director and TV Link Director to work with them, the online YouTube videos will be unavailable. Your device is working fine, but YouTube's service is temporarily unavailable.
Dec 18, 2010 | Iomega ScreenPlay
YouTube is not working. I have the iOmega Director. Every thing I select says "The content you requested was not found"
Nov 14, 2010 | Iomega ScreenPlay
I purchased an iomega 1TB screenplay director at P.C world in the U.k On my return to Spain I discovered ther was no "users manual" in the box, only the quick set up guide. Obviously I do not want to...
ScreenPlay Director HD Media Player:
User's Manual: View Online [HTML] http://www.iomega.com/support/manuals/hdd2010/spdirector/en/main.html
Download [652KB zipped HTML] http://download.iomega.com/english/manuals/english/screenplay-director-en.zip
Quick Start Guide [PDF 1.2MB] http://download.iomega.com/qsg/spdirector_us.pdf
Specifications https://iomega-na-en.custhelp.com/cgi-bin/iomega_na_en.cfg/php/enduser/std_adp.php?p_faqid=22159
Oct 12, 2010 | Iomega ScreenPlay Plus 34499 Digital Media...
I need to download iomega Screenplay 1T user manual
You should be more specific with which unit you have when asking questions about it.
ScreenPlay Director HD Media Player: User's Manual: View Online [HTML] http://www.iomega.com/support/manuals/hdd2010/spdirector/en/main.html
ScreenPlay Multimedia Drive: User's Manual: View Online [HTML] http://www.iomega.com/support/manuals/hdd2008/scrnply/en/consolidated/main.html#scrnply
ScreenPlay 60GB Multimedia Drive User's Manual: http://www.iomega.com/support/manuals/allhdd/screenplay/en/main.html
ScreenPlay HD Multimedia Drive: User's Manual: View Online [HTML]: http://www.iomega.com/support/manuals/hdd2008/sphd/en/main.html
ScreenPlay Plus HD Media Player: User's Manual: View Online [HTML] http://www.iomega.com/support/manuals/hdd2010/scrnplyplus/en/main.html
ScreenPlay Pro HD Multimedia Player: User's Manual: View Online [HTML] http://www.iomega.com/support/manuals/hdd2010/scrnplyprohd/en/main.html
ScreenPlay TV Link User's Manual: View Online [HTML] http://www.iomega.com/support/manuals/hdd2010/sptvlnk/en/main.html
ScreenPlay TV Link HD Media Player Director Edition: User's Manual: View Online [HTML] http://www.iomega.com/support/manuals/hdd2010/sptvlnkdir/en/main.html
Oct 10, 2010 | Iomega ScreenPlay
How do i download a manuel for my new screenPlay Director HD Media Player I have 700 Albums and it takes forever to scroll throught them on my TV
Downloadable Manual [652KB zipped HTML] http://download.iomega.com/english/manuals/english/screenplay-director-en.zip
May 25, 2010 | Iomega ScreenPlay
I have lost the operating instructions for this product.when I press power on the remote the unit blinks for some time and then goes the blue light goes out.what else should I be doing. Thanks in...
Downloadable User's Manual [652KB zipped HTML] http://download.iomega.com/english/manuals/english/screenplay-director-en.zip
May 15, 2010 | Iomega ScreenPlay
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
