Question about Arris Cable Modem Sb6180 Surfboard Docsis 3.0 Cox Charter Cable One And More
I have a motorola sb6180 to connect to a dir-615 router
My router is a d-link model dir-615
Computer says that the pin number is incorrect, please use no. on modem. modem nuber keeps coming up incorrect
You should refer to your wireless router setup manual for pin number....
you can also prefer this link to search modem pin no-http://www.dlink.com/uk/en/home-solutions/connect/routers/dir-615-wireless-n-300-router
Sep 03, 2012 | D-Link DIR-615 Wireless Router
D-Link DIR-615 Wireless Router not connecting with HP Network Printer
Please use the utility disc that comes with your printer. It will help you to connect your printer to your wifi router.
Or please check if you type the correct SSID of your wifi (Wifi Name). SSID are case sensitive.
Nov 04, 2011 | D-Link DIR-615 Wireless Router
I am connected to a DIR 615, it says I have wireless connection but it won't connect wireless, if I connect a cable it is fine??
Hi mike63771,
All you need to do is to set it up properly. Make sure that the router is connected to the computer using an ethernet cable so that the computer will be able to communicate with the router. Then open a browser type 192.168.0.1 on the address bar. The default username is admin and the password is blank. Go to the Wireless Settings Page then check the SSID or Network Name and the Network Key or Passphrase. Now try to connect to your computer. Click on Start then click on Connect To. Select your Network Name then if it ask you to enter a password enter the Network Key. You can personalize the network key on the router settings page.
Rate me if this helps so i can help other.
Thanks for using Fixya.
Feb 02, 2011 | D-Link DIR-615 Wireless Router
DIR-615 Wireless Router: i have a d-link wireless router dir 615 that i've ...
if youve changed the password on the router since the other computers logged onto the network, then you need to delete the network history from those computers.
Otherwise those laptops will be trying to connect to the network with the old details.
May 16, 2010 | D-Link DIR-615 Wireless Router
Dir-615 router will not connect, on set up it
do a factory reset - theres a reset button button on the back hold that for 30secs until the device resets
does the ethernet cable and PC work if connected directly to the modem whats the make and model of modem
Mar 19, 2010 | D-Link DIR-615 Wireless Router
D-Link DIR-615...Need how to connect cables
Here's the manual to your Router
D-Link DIR-615
http://www.clickonmacs.com/Support/Manuals/D-Link-DIR-615-Manual.pdf
At page 6 will tell you the ports of your router, the 4 LAN ports (shaded in blue) is the connection right through your computer Lan port. The Internet port connected to your Modem, and the DC port for the power source.
Jan 31, 2010 | Computers & Internet
D-link dir-615 cannot connect to internt
it could be a problem with your internet connectivity. check with the isp.
Jul 26, 2009 | D-Link DIR-615 Wireless Router
Arris Cable Modem Sb6180 Surfboard Docsis 3.0 Cox Charter Cable One And More Logo
149 people viewed this question
Top Arris Computers & Internet Experts
bobkoure
Level 1 Expert
Suddenlink Help
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
