Question about Whirlpool LER5636P Electric Dryer
My whirlpool duet sport model # wed 8300 swo dryer is running but wont get hot and the clothes sensing light stays at the sensing mode whether the clothes are either wet or dry. Will this cause the dryer not to get hot?
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
What you will need to do is remove the front lower panel ..Test the thermal fuse with a meter for continuity. Here is the thermal fuse to order in case you find it bad.
Posted on Dec 04, 2012
  • 67 Answers
SOURCE: Whirlpool Duet Dryer is scorching clothes
there is a sensor in the exhaust line in the dryer, near the motor. this tells the heating element to shut off when it gets to a certain temp, either during reg cycle or if the exhaust gets clogged, it is meant as a safety measure, but it sounds like yours is bad so the heating element never shuts off. it is not an expensive part and easy to replace
Posted on Oct 28, 2008
  • 36 Answers
SOURCE: Whirlpool Duet Dryer WED9600 Beeping during drying
Dear Customer
Please perform the following
please rate this,thank u
Posted on Dec 16, 2008
  • 14 Answers
SOURCE: my Whirlpool duet dryer is getting too hot
YOU NEED A NEW THRMO KIT
STEVE'S APPLIANCE
516-300-3249
Posted on Apr 06, 2009
SOURCE: whirlpool duet front loader dryer....sensing light won;t shut off
I have a whirlpool electric dryer and it cuts off and shows E 1... What is the problem?
Posted on Apr 21, 2009
blueextc3221
  • 15935 Answers
SOURCE: Whirlpool Duet Steam Dryer Beeping
Symptom: Dryer turns on, drum spins, but you have no heat.
Any of the following components are more than likely suspect as being bad:
Heating Element
Thermal Cut-Out
Hi-Limit Thermostat
All these components COMBINED, should cost less than $100. If you fix it yourself, you will avoid the additional cost for labor.
If the dryer isn't blowing ANY air at all, but the drum still turns, you may have a bad blower fan assembly inside the dryer. Or, the blower fan assembly may be clogged.
If your dryer performance has been failing (i.e., clothes taking longer to dry), it may be for a reason. You need to ask yourself when the last time you cleaned the dryer ventilation. If you can't remember, or if it has never been done, this can contribute to the dryer failing. All dryers need proper air flow in order to dry properly. If the ducting becomes clogged, the heating circuits will actually overheat and eventually fail. This usually results in the Thermal Cut-Out (TCO) blowing or the Heating Element failing or BOTH. When these components fail, they must be replaced. Remove the dryer hose from the back of the dryer and inspect it thoroughly from where it leaves the dryer to where it exits your home. It should be clear with no kinks or clogs. If your vent line runs under a crawl space make sure it is suspended above the ground and has no sags where lint could collect. RULE OF THUMB: The SHORTER and STRAIGHTER the vent duct, the BETTER. After you inspect the vent ducting, turn the dryer on and make sure you have forceful air flow coming form the dryer. This will prove that your blower fan is working properly or not. Since you stated that your dryer is not currently heating, the air will be cold, but you should still have some force behind it. If the air flow is weak, you need to clean the duct work INSIDE the dryer. It is important to keep a dryer checked routinely. I recommend once per season (that's 4 times per year). Dryers are the cause of many house fires. These fires are due to lint accumulations inside the unit catching on fire. A little preventive maintenance can prevent significant problems in the future.
Getting to the heating circuit to determine if the components are good or bad is the next step. If your dryer has the lint screen on the top of the unit, you will need to remove the back panel of the dryer to expose the heating circuits. If the dryer has the lint screen in the door, you will need to remove the lower kick panel under the door by using a putty knife to release the retaining clips. They will be located along the seam in the front about 2 inches in from each side. If this is a Kenmore Elite or Whirlpool Duet, the lower lick panel comes off by removing the screws under the bottom edge of the panel. (HINT: placing a block of wood under the front feet of the dryer can make access much easier). If your dryer has no lower kick panel, you have to remove the entire front panel on these models. This is accomplished by lifting the dryer top and removing the screws that hold the front panel in place.
NOTE: The heating circuit should be troubleshot with the dryer UNPLUGGED. Dangerous voltages are still present with the dryer turned off. Resistance readings are as follows:
Heating Element (located inside heater box) - remove the two leads from the ceramic terminals on the heating element and take a reading across the terminal points. It should read 9 - 13 ohms.
Thermal Cut-Out (TCO) (mounted to the heater box.) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
Hi-Limit Thermostat (mounted to the heater box, closest to the heating element leads) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
If any of the above readings are abnormal, replace the component. NOTE: If the TCO or Hi-Limit Thermostat is defective it is highly recommended by most manufacturers to replace BOTH components at the same time. They are often sold as a set. Without doing so, these components can cause potentially fail again.
NOTE: One item I failed to mention - Double check the input power for your dryer FIRST. You should have 220VAC at the receptacle and terminal block. The dryer will STILL tumble and the timer will still function with a portion of the input power missing as these circuits only require 110VAC. The heating circuits, however, require 220VAC to function. If one leg of the receptacle voltage is missing the dryer may exhibit "No Heat" like symptoms. This could also be an indication of a burned or failed power cord. Continuity checks performed with the dryer UNPLUGGED should indicate a short between the prong end of the cord and the respective lugs at the terminal block.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!@#$%^
Posted on Sep 30, 2010
Whirlpool duet sport dryer stopped running after 20 minutes into a 40 minute cycle on hot.
Check for clogged vent. Vents will clog midway and if vented to the outside of a house, there is a plastic cover that usually gets covered with lint that gets wet and dries to a hard mask.
Feb 02, 2017 | Whirlpool Dryers
Whirlpool Duet dryer runs way too hot, even during air only cycle.
sounds like restricted air flow to me . check filter and the vent for plugged pipe
Apr 18, 2012 | Whirlpool WED9400S Electric Dryer
Duet dryer on sensing mode>what does that mean
The "Sensing Mode" occurs when the dryer is trying to detecting the dampness of the clothes in the dryer to determine if they are dry or not.
If the dryer is "stuck" in sensing mode - there is a problem that should be checked.
Sep 06, 2011 | Whirlpool Dryers
Why does the display say"wet" when the clothes are
Try cleaning your moisture sensing strips with windex. Maybe something wet and sticky is on them
Dec 01, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool duet dryer model # GEW9200LW1, when powering up goes directly to touch up, and will not start. thermal fuse ok
Dirty moisture sensing strips? Have you tried cleaning them with windex?e03f8f0.jpg
Number 34 these measure resistance by picking up wetness from the clothes. Dryer sheets can coat these with a non penatrable film which fools the brain into thinking them clothes is dry so it moves towards the cooldown mode and shuts off with wet clothes. Clean them sensor strips real good and party on!
Oct 11, 2010 | Whirlpool Dryers
Whirlpool duet front loader dryer....sensing light won;t shut off
Apr 01, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool Duet dryer won't start F30
well the sensing light will stay on till it feels wet clothes against it if you in auto dry mode it says it wont start without feeling wet clothes against the silver bars in the vent housing it says it will run in manuel mode even if it doesn't feel them pull the top off the dryer and on the right hand side is a tech service sheet in a plastic bag see what it says
Mar 30, 2008 | Dryers
Time skips from 18 minutes to 6 minutes on automatic mode
It is the moisture sensor system, it is not sensing the wet clothes. Open the door, inside you should see a part with 2 metal bars that is around 3 inches long, clean these bars with a mult purpose cleaner. Sometimes fabric softner sheets and detergent builds up on this so that the machine cannot sense the moisture. Hope this helps.
Jan 28, 2008 | Whirlpool GEW9250 Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
701 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
