Question about BenQ MP620 Multimedia Projector
Shuts down after +-12 seconds
The heat light comes on and the projector shyts down +* 12seconds after start up
  • Anonymous Sep 08, 2008
    My LCD Toshiba projector has it indicator green. After turning on for 2-3 seconds, it automatically turn off. Having shutdown the main power it happen the same. Any suggestions?????
  • Anonymous Mar 14, 2014
    The projector work for 30 seconds and then turn off or just shut down. when wait for 90 second and then restart and again it shut down
Clean out the filters on the side of the projecter with a hand held hoover.
Posted on Jul 03, 2007
SOURCE:
When I turn my projector on within seconds it turns itself off
Are the fans all starting up? The symptom you describe is often associated with a faulty fan. Also could be a failed lamp, as the projector will shut down if the lamp does not strike within a defined time, although in this case the 'lamp' light should come on
Mar 31, 2014 | Sony VPL-CS7 Multimedia Projector
Lamp keeps cycling on and off.
the circuit is closed somewhere it shouldnt be
Apr 13, 2013 | Sharp XR-10X Multimedia Projector
Red lamp or heat light is flashing while projector is off. Can't be sure which it is because it is mounted 16' up. I've cleaned projector & filter with canned air from 12' ladder and red light stops...
Here is some information on this model which I hope will help...
The lamp indicator lights when the lamp is due to be replaced. It will flash if a circuit abnormality is found.
The temp indicator lights if an abnormal temperature is detected. If it goes too high it will shut down flash.
The lamp indicator is furthest away from the power switch if that helps.
If the lamp timer was approaching the end of the lamp life you would see a REPLACE LAMP nag screen when the projector is turned on. The fact that you have not mentioned this suggests that this is unlikely to be the problem.
The filters on the model are on the underside. There is a removable panel directly under the lens. You should not use canned air as you are blowing dust into the projector. It is recommended that you use a vacuum cleaner. Filters should be cleaned every 100 hours and replaced when the projector is relamped. You can wash the filter by hand with water only, ensuring it is dry before replacing it. Do not run the projector without the filter in place.
Feb 19, 2011 | Panasonic Projector Lamp for PT-LB50...
Projectors keeps shutting down after 20 - 30 seconds
reason for fan spinning at high speed after shutdown is to cool down the projector after it has been on
you will feel hot air from exhaust as this is taking the heat away from the lamp, where all the heat is generated
if it shuts down after 20 mins either the projector is blocked, maybe, a fan is not running, filter blocked, or the motherboard is now u/s
Apr 01, 2009 | Office Equipment & Supplies
Sanyo PLC SW20AR - Shuts itself down
check the follwoing :
check lamp physically for melted filament, white deposits on filament/ reflector, if so change lamp
if lamp looks perfect, the ballast needs to be replaced, also check for fans if they are running fine
Feb 08, 2009 | Sanyo PLC SW20A Multimedia Projector
Projector shuts down after turned on and both red lights blink
this model is prone to over heat. look near the lamp for the temp sensor it is most likely bad
Nov 30, 2008 | BenQ PE7700 Multimedia Projector
Acer pd110z projector lamp starts then stops
Probably a dying lamp. How many hours does it have on it?
You might try carefully removing the lamp and then putting it back in. Perhaps it has a slightly bad connection that is causing it to consume too much power and it shuts down.
Mar 21, 2008 | Office Equipment & Supplies
Unit powers up, fan shuts down no light.
The unit could be able to sense fan operation and prevent the lamp from lighting since this could cause heat damage or even a fire if allowed to light without any cooling.
If you can see the fan, try pushing gently on the blades, left, then right, to see if the fan shaft wobbles.
Mar 16, 2008 | Hitachi PJTX100 Multimedia Projector
Quantum Apollo 16000 Portable Projector
It sounds as though the unit is overheating. That would explain why the fan keeps running, and once it cools down enough it starts up again. What kind of environment are you running this in? Is there a way to put it in a cooler environment? Even having an external fan blowing on the unit could help. Honestly, unless you've got it in a very hot environment, it also sounds like a poor design for heat dissipation. Or possibly the heat sensor is bad, and shutting it down at a lower temperature than it should.
Aug 28, 2007 | Quantum Apollo 16000 Portable Projector...
BenQ MP620 Multimedia Projector Logo
314 people viewed this question
Top BenQ Office Equipment & Supplies Experts
Tom Chichester
Marvin
Marvin
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
