60p8342a philips tv picture looks red sound is fine
Picture looks red sound is ok
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Go to a unused video input and turn color off----screen there should not be red or even somewhat red, if it is the red screen control may have to be lowered just slightly.
Posted on Dec 04, 2012
ctf1800
  • 4402 Answers
SOURCE: philips rear projection tv 43pp8545 no picture sound ok
do you get a blinking read light?
Posted on Dec 14, 2007
  • 4 Answers
SOURCE: need help repairing Mitsubishi VS 4541 rear projection TV
I have the same type of TV, and I think it has a filed "power rail", as the LED does not burn at all, nor do the heaters of any of the CRT's. When I plug it in, I can hear the relays click in, and hitting the power button will cause the relays to click. Other than this, there is no sign of life from this TV. I really would like to find a repair manual or a schematic to aid in troubleshooting. The self-diag trick may be handy if the LED would come on. I'll try it and see what it does.
Posted on Sep 09, 2007
Slinteriors
  • 8617 Answers
SOURCE: Philips Rear Projection TV 43PP9202 Picture looks 3D
You need to replace both convergence ICs they are STK392-120 you will also need about four 6.8 ohm 1 watt resistors. You can get replacement ICs and resistors at the following link and they provide free instalation instructions with pictures. here is the link.
http://servicemanuals.vstore.ca/
Posted on Jul 22, 2008
SOURCE: bought 57'' philips tv picture fine but red overpowering
should be a knob on the back inside has 3 one for each lamp red green and blue just turn the red down a little
Posted on Apr 02, 2009
mjbarton74
  • 6 Answers
SOURCE: Philips hd tv
possible mother board issues, alot of times they get very hot and will fry out. have you also tried the input button? they will sit on another input if a kid gets ahold of it or someone has changed it to play a video game or dvd.
Posted on Apr 28, 2009
I have a old Phillips big screen TV. Serial# 72630137 Model# 60P8342A. No remote the p.o. tire has too much red. How do I adjust my picture.
GAIL,YOU NEED THE REMOTE THAT CAME WITH YOUR TV IT WILL ALLOW YOU TO ADJUST THE COLOR AND CONTRAST BRIGHTNESS YOU MUST GET INTO THE MENU TO DO THIS BUT YOU DIFFENTLY NEED THE REMOTE THAT CAME WITH THAT TV!!!
Jan 24, 2016 | Televison & Video
Philips 40PFL3705D/F7 turns on with sound no picture was fine the night before
looking online as i have same problem, sound without picture points to T CON board. approx $50-100 part + labor
Sep 18, 2012 | Philips 40PFL3705D 40 in LCD TV
I have a philllips 60in rear projection model num 60p8342a just has red green and blue lines accross the screen no sound untill i power off then picture will flash for about 1 second and turn off any i...
Most likely bad convergence chips--set uses two of the stk-392-120 chips and in this case one is shorted--only way to prove it is unsolder all 18 pins on each chip and see if set powers on and stays on---will look bad but you will know one of the chips is your trouble.
May 28, 2012 | Philips Televison & Video
Problem with the Philips Projection Televisions I have a Phillips 60P8342A 60 in 2002 Projection By jenny_royalt on Feb 08, 2010 I have a Phillips 60P8342A 60 in 2003 Projection and the screen is...
sounds more like the fluid in the blue and green CRT's needs to be replaced. Check the fluid and see if it is cloudy. If so - that is your problem. This is common for this series of tv.
Mar 08, 2011 | Philips Televison & Video
Philips Model 50PL9126D\37 Turn TV on and after a
Ur LCD inverter board is dead,must change to get ur picture back.It usally a long board.
Jan 21, 2010 | Televison & Video
Sound is not coming but picture is ok in philips 21 RF vardan tv
sound is not coming but picture is ok in philips 21 RF vardan tv
Dec 16, 2009 | Philips 32PW6506 32" TV
No sound but picture ok
check cabling, make sure no cracks/breaks in cabling. if you have another set of cabling try replacing. also if using red/white/yellow make sure all are plugged in tightly. if green/blue/red component cabling you would also need the composite cabling; yellow and the red for sound
Apr 04, 2009 | Philips Televison & Video
Need tv help
The sympton for contaminated CRT coolant is objects having a halo effect on the effected CRT color. The Blue and green are the CRTs most often contaminated. But to answer the question changing coolant does help. You can look into the crt with it turned on to see if the coolant is congealed. Just be carteful not to touch any components as you look into the CRT lens.
Feb 20, 2008 | Philips Magnavox 9P6034C 60" Rear...
No picture
phillips 17in lcd no picture
Oct 29, 2006 | Philips 17PF9945 17 in. LCD HDTV
Televison & Video Logo
57 people viewed this question
Top Televison & Video Experts
Electro Med Services...
