Anonymous Posted on Dec 04, 2012
PANASONIC SA-PT650 IT IS 120V BUT IT IS PLUG BY 220V SO WHAT CAN I DO??
Anonymous
Level 3:
Top Expert:
  • Master 14,553 Answers
  • Posted on Dec 04, 2012
Anonymous
Master
Level 3:
Top Expert:
Answers
14553
Questions
Helped
2718524
Points
48227
Most likely it is beyond repair if it got 220 volts.
1helpful
Panasonic SA-VK760 Compact DVD Stereo. When I plugged in, the stand by light comes on, but machine doesn't turn on?
Question edited for clarity, add maker.
Question moved from Washing Machines category.
It needs professional repair unless you have a background in component electronics.
https://www.google.com/search?q=sa-vk960
How do I hookup speaker wires to my sa ak57 Panasonic stereo?
The SA-AK57 is the center of the SC-AK57 mini stereo home theater system. The included speakers have color coded wiring for the front speakers. One speaker connects to the red and black terminals on the SA-AK57; the other speaker connects to the blue and grey terminals. Push on the top of the terminal levers and insert the bare copper wire into the opening. Then release the lever. The center, right and left speakers use a single RCA or banana-plug connection and plug straight into the jacks on the SA-AK57.
Panasonic has the manual for the SC-AK57 on the product page: https://shop.panasonic.com/support-only/SC-AK57.html . The current link to the manual is ftp://ftp.panasonic.com/audio/om/sc-ak57_en_om.pdf . See page 7 for the speaker wiring.
I hope this helps.
I have a Panasonic SA-AK 67 Can any one tell how to connect it to my phone using aux cable
Hello Zubair, to connect your phone to the SA-AK 67, you need a cable that has two RCA connectors (White and Red) to a 3.5mm stereo jack
The RCA connectors, you connect them in the AUX input that is on the rear panel of the SA-AK67 and the 3.5mm stereo jack, in the headphone output of your phone
You select Aux on the Panasonic, you play something on your cell phone and you're done
I hope you find the information useful
Greetings Franco Dosil
Hola Zubair, para conectar tu tel?fono al SA-AK 67, necesitas un cable que tenga dos conectores RCA (Blanco y Rojo) a una ficha 3,5mm est?reo
Los conectores RCA, los conectas en la entrada AUX que esta en el panel trasero del SA-AK67 y el conector 3,5mm est?reo, en la salida de auriculares de tu tel?fono
Seleccionas Aux en el Panasonic, reproduces algo en el celular y listo
Espero te sea util la informacion
Saludos Franco Dosil
http://www.usersmanualguide.com/panasonic/cd_stereo_system/sa-ak57 http://www.usersmanualguide.com/panasonic/cd_stereo_system/sa-ak77
Hi guys, I'm new here! I have a Panasonic SA-AK770 and when I plug in the AC cable to it, the power led don't turn on ! Need some help ? I have already change the fuse but still, it don't turn on.
I DON'T KNOW. PLEASE PLUG SOMETHING ELSE INTO YOUR OUTLET TO MAKE SURE THERE IS ELECTRICITY THERE. UNLIKELY BUT LED MAY NOT BE WORKING. THIS LINK MAY BE OF ASSISTANCE WITH YOUR CONNECTIONS <https://www.manualslib.com/manual/119573/Panasonic-Sa-Ak770.html>
I have a panasonic sa-ht 700 but it did not come with a power cord. it does not have a 120 plug in like normal
The SA-HT700 is the main unit for the SC-HT700 DVD Home Theater system. For this system, the sub-woofer (SA-WA340) has the AC power connection. The sub-woofer is connected to the main unit by a "System cable". The power cord and system cable are shown in the manual. You'll need the sub-woofer if you don't have one. Amazon has a used sub-woofer listed here: https://www.amazon.com/Panasonic-SB-WA340-Powered-Subwoofer-SA-HT700/dp/B076HB8HQP . However, I don't know the third-party vendor.
A replacement power cable for some regions is available at Amazon here: https://www.amazon.com/Polarized-Panasonic-SA-HT700-SA-HT80-SCHT1500/dp/B00VFHP9US . I found the system cable here: https://www.amazon.com/Matsushita-Panasonic-K1HA25HA0001-CABLE-65/dp/B001DPHPCC . See the manual for the correct part numbers: ftp://ftp.panasonic.com/hometheater/om/sc-ht900_en_om.pdf . The accessories that come in the box are shown on page 3.
I hope this helps.
I have a panasonic dvd home theater sound system SA-HT930, and the dvd player, is broke can do nothing with it, need a new one but the plug between the ampli and the dvd wont fit on any new dvd theater...
Believe it or not there is a seller on eBay who offers a one-price fixit solution for your unit for $100.
http://cgi.ebay.com/Panasonic-SA-HT930-SA-HT940-Repair-Service-/360178573162?pt=LH_DefaultDomain_0&hash=item53dc50df6a
That aside, these types of systems are designed as a package to be used as a unit. Otherwise they might have standard connectors. Another closely-related Panasonic SA-HT system might work for you but I doubt anyone manufactures anyhting to adapt non-standard speakers to standard electronics.
They actually say on page 9 of the manual:
"Use only supplied speakers
Using other speakers can damage the unit, and sound quality will
be negatively affected.
I would interpret that to mean 'use these speakers only with similar Panasonic electronics'.
Non Responsive Buttons
Hello..
Is this system one that has speaker connections?
If so, all the speakers must be connected for it to work right.
2answers
Sa-ht740 power problem
I have same problems please If you know anything help me
my email adress
[email protected]
thanks
 Grubhead
Grubhead
SmartAviator
SmartAviator
