Question about Zebra 110PAX4 Thermal Label Printer Print Engine - P/N 113el01-00000
Label not discharging far enough out of the print head
Label is still no the peller bar and when the tamper cycles the label strckd to the backing.... basicly the label position at the end of the cycle is about 1/8 inch too short but I don't know who to move it forward
  • 54 Answers
Zebra ,, Enter setup, change the peel off distance.
If you calibrate the printer it usually comes out just right, as the printer clalibrates for the distance automatically.
After calibration, if you still have a far or too short label, check for any loosness in the platen roller.
As the belts wear, or stetch, the platen will not exactly feed the correct distance over the roll.
Posted on Feb 24, 2009
Hi
Can you tell what the printer is and what the material spec is?
Regards
Bob
Posted on Jan 12, 2009
How do i adjust the printer to the tear off position
Print a config label by holding the cancel button and powering on 15seconds. Check print mode = tear off. If it is in rewind mode the label stops under the print head and does not backfeed before printing. Tear off pushes the perf to the tear bar and backfeeds before printing.
Dec 19, 2012 | Zebra S4M Thermal Label Printer
I have been using an epson stylus color 880 for years. One day it would not print. Replaced the cartridges and still will not print. It goes through the printing procedures but nothing shows up on...
The print head nozzles may be clogged. From the Utility section found in the EPSON printer driver, clean the print heads by performing a head cleaning followed by printing a nozzle check pattern. A head cleaning and nozzle check must be performed as a cycle. After printing a nozzle check, examine the printed dot pattern. Each staggered horizontal and straight vertical line should be complete, with no gaps in the dot pattern. If there are gaps in the dot pattern, continue with another cycle. Perform up to 3 cycles if necessary. If the nozzle check is not printing completely, and if the head cleanings do not help the nozzle check pattern to print completely, try replacing the ink cartridge. Any ink cartridge installed into the printer must have a blue label on top of it. If the blue label has been removed from the ink cartridge, do not install the cartridge. Using an ink cartridge, which does not have the blue label on it, may damage the printer. Caution: If you have already installed a cartridge which is missing the blue label, or if a previously installed ink cartridge was missing its blue label at the time it was installed, and now head cleanings do not help the nozzle check pattern to print completely, your printer may require service and you should contact the EPSON Connection for further assistance.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jul 08, 2011 | Epson Stylus 880 InkJet Color Printer
HI, our Zebra 4m+ is currently set to a Darkness of 30 as that seems to eb th eonly way it will print enough detail on the label. We have tried adjusting the pressure settings to no avail. Now we are...
Full resin ribbons tend to require higher darkness settins on all thermal printers.
It could be a mismatch between label and ribbon. This would need to be looked by your supplier.
May 25, 2011 | Zebra 105SL Thermal Label Printer
We are getting white vertical lines running through our barcode label. it looks like printer ribbon is wrinkling when printing them on long runs. How can we stop this
When you have this problem you need to determine if the ribbon is wrinkling before or after the head. If it is before the head then you need to adjust the bar prior to the head. There should be a phillips head screw there and directly behind it there is an adjustment. Loosen the screw and then move the bar (it is slightly arc'd) so it smooths out the ribbon. This is the least likely suspect. Most likely the head is not square. If the head is not square with the roller below it will cause the ribbon to "dance" as I call it. It will slowly move over then jump back to its rightful position. Or it could just wrinkle. If this is the case and your print looks good then you can adjust the ribbon bar right where the ribbon comes out of the head. There are two screws at the top. Loosen both of them and this adjustment bar will slide all the way back. Once this goes back. Manually manupulate it until it smooths out the ribbon. Once you manually figure out where it is smooth then tighten the screws back up. Feed a few labels and see if the ribbon is smooth.
Jan 27, 2011 | Datamax I-4208 Thermal Label Printer
Using Zebra140Xi4 with fancy Stationary(Tamper proof) on HP UNIX server, the new printer prints half the data intermitantly and complete the next minute. i.e Print our inconsistently the data on the label...
cara pembersihan head printing zebra 110Xi4 ini gimana?
kenapa hasil tulisanya jadi bergaris-garis
padahal headnya tidak kotor, dan hasilnya di sangat tidak memuaskan/ dan bagaimana cara pemersihan headnya supaya tidak terjadi lagi...
Nov 19, 2010 | Zebra 110Xi4 RFID Label Printer Transfer...
When I print my labels, there are lines that run through it
The lines(voids) are being caused by elements that are worn off the printhead. No energy is getting there to release the ribbon, causing a void area. To see the full extent, just create a label, using your widest label, that prints a thick black line. You will easily see the "void" areas as white lines.
This is common over time due to the constant contact with the ribbon. The elements wear down just like the tires on a car from the constant contact with the road.
The only way to correct is to install a new printhead.
Apr 28, 2010 | Zebra Z4Mplus Label Printer
I have a Zebra 110 XiIII p it does print different size bar codes
Keeping up with the Drivers is a very good idea, it will fix little problems that come along from time to time. Try resetting the printer defaults by entering the menu system and exiting, at piont of exit don't save permanently but cycle around to load defaults and exit. Go back in and set the printer up again, this time exit saving permanently.
Jan 21, 2010 | Zebra 110XiIIIPlus Label Printer
Zebra Z4MPlus not printing dark enough
In your label software there should be a setting option for print darkness (I assume it adjusts the head temperature) In ours (bartender) you can get to it when you select 'print' and a window appears with a 'documents properties' button. Click on this and select options and a darkness bar appears which you can adjust. You may also need to slow the label print speed if the darkness adjustment is not enough. I suspect it isn't in the printers best interest to run the print head at maximum darkness/heat so a sensible balance of darkness and print speed is best.
Another, less likely, possibility is an incompatability between the label material or surface finish, and the ribbon type. We did have a problem once whem Homebase changed their price label design and we had to test a load of other ribbon types until we got one that did the job. A chat with the label or ribbon supplier is always usefull, they sent us several sample bits to test.
Sep 30, 2009 | Zebra Z4Mplus Label Printer
Brother P-Touch 1200 label printer doesn't feed whole label
Take out your cartridge and look at the end of the tape, it should be under the guide, the skinny bar, before going into your machine. Make sure you tuck it in under that bar and it should be OK.
Aug 28, 2009 | Brother P-Touch PT-1200 Label Printer
Epson LQ 590 Label Problems
Make sure the option for bidirectional printing is set correctly.
Try it both ways
Make sure you are not printing too far to the left or the right - the print head can hit the end of its run and lose its place.
Mar 27, 2009 | Epson Dot Matrix LQ-590 Printer
Zebra 110PAX4 Thermal Label Printer Print Engine - P/N 113el01-00000 Logo
170 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
