Question about Hotpoint Washing Machines
Why is my hotpoint top load washer is getting grease on cloths
    Top Expert:
  • Hotpoint Master
  • 9,472 Answers
What is the complete model number of the unit?
Posted on Dec 04, 2012
  • Robin Short
    Robin Short Dec 04, 2012
    not sure, it's my sisters!
  • Richard Roth
    Richard Roth Dec 04, 2012
    You might have an issue with the tub seal or possibly some built up grime below the agitator.
jsrock516
  • 5911 Answers
SOURCE: Fridgidaire Front Load Washer
This is usually an indication that the rear tub bearing is starting to go bad. The bearing is located in the rear shell of the wash tub and cannot be replaced. In order to repair, you would have to replace the entire rear shell because the bearing is actually molded into the plastic. This is common with front loader washing machines. Another possibility could be items getting caught in the rubber door boot and leaving rubber marks. However, normally this will be associated with a leak somewhere. Inspect the entire door boot and clean in behind the rubber. Inspect for any rips, tears, or places where clothes can get caught. I have experienced clothing getting snagged and actually pulling the door boot off. If the marks continue to show up on your clothes (they may even turn a brownish color) I would look into an estimate on how much it would cost to have the tub bearing replaced. It is not an easy repair, and it is not cheap. The cost usually runs around $500. I hope this helps.
Posted on Aug 08, 2007
prasanth83
  • 68 Answers
SOURCE: Oil spots on clothes
HI Friend,
First of all relax alright, you are in safe hands.
See every washing machine has a turbine at the bottom f the washing bowl and below that there is a motor. And there wud be a safety valve or (washer ) which basically looks like a ring made out rubber or plastic and when this ring gets outdated or torn it stops controlling the oil flow and thats the reason y ur clothes have the oil stains ,so once it is replaced you will not have this issue.
This would surely help you in getting the clothes clean and tidy.!!!!!!!!!!!!
Have a great day!!!!!!!!!!!!!!!!!!
And please rate me so that I can improve myself(vote).
Prasanth83:):):)
Posted on May 13, 2009
  • 512 Answers
SOURCE: GE top loading washer does not spin out water
The belt could be broken, if not. Unplug washer for 2 minutes, plug back in, open and close lid 7 times, this should reset electronic motor.
Posted on Jun 12, 2009
SOURCE: Hotpoint bwd129 washer dryer won't dry my clothes.
my Hotpoint dry will not dry my clothes. It will run for hours and the clothes still haven't dry just felt hot.
Posted on Jul 23, 2009
SOURCE: washer is leaving grease all over my clothes
I have this problem on my front loading washer too, but only when washing white clothes. I have just read that perhaps the inlet hose is disintegrating from the hot water being too hot. The hose disintergration can cause black greasy stains on the clothes. I am going to check out the inlet hose when I get home. Hopefully this is the problem... I am sure a new inlet hose is a lot cheaper than a new transmission or new bearings. BTW, my washer in only 18 months old.
Posted on Aug 20, 2010
Gunk gets on clothes-stains them,i pulled agitator out and cleaned it off ran bleach thru-its better but still getting on clothes
The problem may be the seal on the transmission failing. If this happens, grease from the transmission (necessary for it to function) will leak and float (recall from science class that oil is less dense that water) up into the washer. As the grease enters the tub, it stains your clothes.
Washer Transmission Replacement Whirlpool Kenmore Top Load Washing Machine...
Washer Leaks Water GE Top Load Washer Tub Seal Replacement Part WH02X10383
Jan 21, 2016 | Amana 3.2 cu. ft. Top-Load Washer
GE Top Load Washer WLSR2000G3WW~leaves oil residue on clothes and bowl
If it is grease that is in the tub then the trans is shot. Thats the only part that would result in this. Very pricy part but if you want to order it go to marcone.com with your model number and you can get the parts. I would not recommend fixing this, costs almost as much as new unit.
May 22, 2012 | GE WBSR3140DW Top Load Washer
What is thebest tepmerature for white garments
Set your water temperature to "cold" on your clothes washer. Unless your clothes have oil or grease stains, cold water is usually adequate to clean white and colored clothes. In fact, washing clothes in cold water allows fabrics to retain their color and strength longer.
Feb 17, 2011 | Hotpoint Aquarius WD640 Front Load...
Leaking grease
All washer machines have a "transmission" - just like a car these units have oil in them and when the seals that protect the oil from going to our clothes is breake, oil finds its way to your clothes.
Transmission needs to be replaced.
Aug 18, 2009 | GE Profile WPRE6100G Top Load Washer
Grease on clothes
this is joyce
I have the answer its the seal in the drum you need to call the manufacture.
Feb 03, 2009 | Kenmore 24032\24036 Top Load Washer
CLOTHES NOT SPINNING DRY
you have something stuck in the pump..a sock maybe or some other small article of clothing
Jan 11, 2009 | Hotpoint -Ariston VVSR1030HWO Top Load...
WMA 10 Hotpoint firsy edition
elbow grease will sort the problem take plastic clip off and take metal ring off pull most of rubber free the problem is grease ,petrol, etc on clothes that soaks into rubber start by scrubbing .with power off obviously its an easy job
Sep 06, 2008 | Hotpoint First Edition WMA12 Front Load...
Black mark on clothes after washed in Maytag top load washer.
Check and make sure the seal at the bottom of the washer is not wore out. Alot of times you will get grease from the bearins and drum assembly if this wears out.
Apr 14, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Stained clothes
there no grease in ft loading washer possible cause fabric softner
Feb 03, 2008 | Kenmore 44102 Front Load Washer
Washing Machines Logo
16 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
