Question about Frigidaire Dryers
Frigidaire affinity dryer wont heat - Frigidaire Dryers
  • Official Brand Answer
  • 4,342 Answers
Hello - Do you have a gas dryer? If so, and it only heats up sometimes but provides a gas odor, it could possibly be a defective gas supply or igniter. Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn on the fuse for the dryer. Turn on the dryer and select a normal cycle. If it proves to be ineffective, I suggest contacting a professional to move forward accurately. Since it is such a complex unit, the technician will likely diagnose to confirm if it has a defective sensor, control board or high limit thermostat.
If you have an electric dryer, the issue may lie with the main control board. However, if the unit is not producing any heat please have a professional diagnose the heating element and the blower assembly as well. Either, or, could be faulty at this time. This is not a typical DIY job so please consult a professional.
Posted on Dec 05, 2012
dragonsthatk
  • 547 Answers
SOURCE: FRIGIDAIRE AFFINITY ELECTRIC DRYER NOT STOPPED HEATING
eleiment
Posted on Feb 18, 2009
dragonsthatk
  • 547 Answers
SOURCE: Frigidaire affinity dryer doesn't have heat but it tumbles, stops
clean air duct
Posted on Mar 13, 2009
SOURCE: Frigidaire Affinity Dryer (model LEQ7000ES0)
right now i took the whole bottom apart from the main brain and so far is working good is not turning off now it may work on your too
Posted on Jun 22, 2009
localwonder
  • 6784 Answers
SOURCE: Turns on but wont heat up
Check the following areas to combat this issue. the most common problem spot will be a blown Thermal fuse.
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Posted on Jul 13, 2009
How do I make my Frigidaire Affinity dryer stop beeping and run?
Have you checked the lint has been cleaned off filter and water reservoir emptied.?
Dec 09, 2014 | Frigidaire Dryers
Dryer wont heat up
Good Afternoon Friend,
I understand that you are having trouble with your Frigidaire Affinity dryer not heating up. There are some things that you are able to try. First check to make sure that the lint filter, the ducting, and the outside vent, are clear of lint and not constricted in any way. Second, reset your appliance by either unplugging it or shutting the power off at your homes circuit breaker for 3-5 minutes. Once power has been restored, run any cycle. If you are still noticing that your dryer is not heating, I suggest contacting your local authorized technician for further assistance. They should be able to diagnose your dryer and determine why your appliance is not heating. Hope this is helpful.
-Best Regards-
WP
May 12, 2014 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire Affinity AEQ6700FSO electric dryer does not heat, then shuts off within 10 minutes.
Hello Scott Joseph Brandt - Since you have already replaced the thermal limiter check your breaker or fuses. Some dryers are run by two separate fuses, one for power and one for heat-ours is. If it is not the power source more than likely the issue lies with your heating coil.
Feb 05, 2013 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Heating element quit working on my frigidaire affinity dryer
If the unit still works, it just does not dry, please have a professional diagnose the heating element and the blower assembly. Either, or, could be faulty at this time. This is not a typical DIY job so please consult a professional.
Sep 19, 2012 | Frigidaire Affinity AEQ6000WH Dryer
My frigidaire affinity dryer works but does not heat up.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 06, 2010 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
My frigidaire affinity dryer is not heating up but still works what is wrong?
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 11, 2010 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Dryer not heating frigidaire affinity front loader
heatman101
fgssggs
Feb 22, 2010 | Frigidaire Affinity AEQ6000WH Dryer
Dryers Logo
54 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
