Question about Singer 14SH654
The thread is too loose - Singer 14SH654
  • Singer Master
  • 7,365 Answers
Here are 2 links for a manual see if one of will work for the machine
http://www.singerco.com/uploads/download/434_14sh644_654_e.pdf
http://www.singerco.com/uploads/download/555_14sh644_654-(e_s_f)-(new-led-version).pdf
try adjusting the tension one number higher until the stitch becomes
normal
Posted on Dec 04, 2012
Stiches are loose how to adjust the tension
Loose upper thread requires the top tension to be increased (higher number).
When threading the top thread, be sure to ALWAYS RAISE the presser foot while threading so the thread will seat properly in the tension disk.
If the bobbin thread is loose, then the bobbin tension needs to be tightened.
Understanding Thread Tension Threads
Mar 06, 2017 | Sewing Machines
I do a lot of hemming on my machine, the underneath stitch is real real loose, I tried adjusting stuff, still is so loose I have to cut it and begin again, thanks
Is your top thread not pulling the bobbin thread up? This would be top tension too loose. FYI--be sure to ALWAYS RAISE the presser foot when threading the upper thread so it will seat properly in the tension disks.
If the bobbin thread is loose, then the bobbin tension may need to be tightened.
The thread is loose at bottom
When the bobbin thread shows on the right side, the needle tension is too tight or the bobbin thread, too loose, as shown in the middle drawing at right. When the needle thread shows on the wrong side, the needle tension is too loose or the bobbinthread, too tight, as shown in the bottom drawing at right.2 Nov 2008
Understanding Thread Tension - Threads
www.threadsmagazine.com/item/4302/understanding-thread-tension/page/all https://www.google.co.uk/webhp?sourceid=chrome-instant&rlz=1C1CHBD_en-GBGB719GB719&ion=1&espv=2&ie=UTF-8#q=Sewing+Machines+The+thread+is+loose+at+bottom
Dec 15, 2016 | Sewing Machines
Doing zig zag the bottom thread is so loose - what is wrong?
the needle thread tension is too loose
tighten it up so that it pulls the bottom thread up into place
Sep 26, 2016 | Sewing Machines
Bobbin threat loose
Make sure you have threaded the machine properly--which usually involves removing the thread and rethread from the beginning. Make sure to RAISE the presser foot before threading the upper thread. Check that the bobbin is loaded in the bobbin case and it is threaded properly.
sewing machine loose bobbin thread Google Search
Jan 26, 2016 | Sewing Machines
When I finish to sew the end of string does not lacks it self and when you pull the bottom of the string everything opens
If the upper thread is looping on the bottom of the fabric as you sew, the upper tension is too loose. It could be threaded incorrectly, the upper thread may not be seated in the tension disk properly (be sure to RAISE the presser foot BEFORE threading the upper thread), or the upper thread tension is set too loose.
If you have checked everything and it is still looping underneath, the bobbin tension may be too loose or the bobbincase needs replacement.
Sewing Machine Thread Bunching Up Here Why
Oh You Crafty Gal Sewing Lesson 10 How to Fix Tension on Your Sewing...
Dec 20, 2015 | Janome Sewing Machines
Harrision gc5550. Why is bottom stitching loose?
Usually, loose threads under the fabric indicate a loose upper tension. Be sure that you RAISE the presser foot BEFORE threading the upper thread. This allows the thread to seat properly in the tension guides. If the loose threads are still appearing under the fabric, try tightening the upper tension. The upper and lower threads should meet in the middle of the fabric.
Sep 18, 2015 | Sewing Machines
How to top thread 158-1355080 kenmore
try this site
sewusa.com they have some threading diagrams
also youtube has video's
for a manual
sewingpartsonline.com
sew4less.com
a1sewingmachines.com
since the bottom thread is loose try adjusting the top thread tension
Apr 17, 2012 | Kenmore Sewing Machines
The upper thread breaks immediately I start operating
Upper thread breaks
needle may be in backwards
Raise the needle bar to the highest point, then loosen the clamp screw
to remove the old needle, place the new needle in the clamp with the flat
side to the back of the machine
Push the needle all the way up to the stop or as far as it will go, then
tighten the needle clamp screw
upper tension may be to tight
the needle may be bent or damaged
thread may be hanging up in bobbin case--check area for loose threads
or lint
Apr 17, 2012 | Sewing Machines
The thread underneath when sewing is too loosed
Usually thread too loose on the bottom is caused by the upper tension being too loose. The top and bottom tensions work together with the top thread making the underside of the stitch seem too taunt or too loose and the bobbin thread causing the top side of the stitch to be loopy or too tight. Select a large zig zag stick and sew a couple of inches. Then examine the stitch. It should look identical on both sides. Look to see which side is drawn too tight, the zig zag being smaller on that side with threads from the bottom threads pulled through. Then adjust the two tensions so that they make a uniform, identical stitch.
Also, when the bobbin tension is right you can hold the bobbin dangling by the thread and it won't spool out to the floor but will let loose a bit with a slight flick of the wrist. Too loose it will just spool out. Too tight and it won't drop at all. When you get that set right then do the above zig zag test to see where the top tension should be set.
Mar 02, 2011 | Sewing Machines
Singer 14SH654 Logo
19 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
