Question about Samsung Televison & Video
BN96-19469A BOARD HAS WHITE RESIDUE ON BOTTOM. TV CLICKING NOT TURNING ON. POWERBOARD CAPACITORS LOOK FINE.
  • Samsung Master
  • 933 Answers
Just because the capacitors look fine don't mean they are. You will need to get a tester and check. Do you have standby 5vdc? is the main board supplying the 3.3-5vdc "on" signal to the power supply? If you don't have any repair experience, I recommend a professional diagnoses.
Posted on Dec 04, 2012
  • joe craft Jan 06, 2013
    the volume goes up and down red light is on power, everything works with remote like it should a repair like this should cost what?
SOURCE: Philips PLASMA TV 42PF9956/37 42" power board 3104 313 60173 relays clicking TV does not turn on
The capacitors for 2533,2540,2541,and 2508 should be replaced. They are all 100uf 16v surface capacitors. Those capacitors are sold on amazon.com http://www.amazon.com/Rubycon-Electrolytic-Capacitor-IMPEDANCE-Continuous/dp/B0015A8U9M/ref=sr_1_2?ie=UTF8&m=A6Q8GCHJGURD6&s=industrial&qid=1225140147&sr=1-2
Posted on Oct 27, 2008
  • 98 Answers
SOURCE: tv wont turn on
You can check the two board.
One is Power board another one is Y-main.
You can find right part with serial # & version #.
Posted on Feb 12, 2009
dbTVfixer
  • 79 Answers
SOURCE: are there any powerboards or
the power board is available from Andrews Electronics
but you should really look again at the capacitors, make sure you placed the in there correctly polarity-wise
the stripe on the capacitor goes along with the marked side on the circuit board...this is the negative leg.
Posted on Apr 12, 2011
jdvillanueva
  • 2098 Answers
SOURCE: Amber Visio light comes on
Hi dezrl,
Check the fuse on the y-sustain board. If you they are open replaced it with same current(ampere) ratings and try again if the symptoms still there. Check the voltages at connector (P3). Let me know the reading to asssist you further.
Jdvillanueva
Posted on Aug 07, 2011
gopakumarg43
  • 74251 Answers
SOURCE: Samsung 42" Plasma #SPR4212X/XAA TV was
Hello
In normal casses, if the power supply regulator board of Plasma Ts cannot be get repaired by any means. The inverter transformer [Switched Mode Power Supply]; will get shorted windings inside it, which cannot be retifed. this is a critical part, that cannot be available at local electronic sparepart market, of as part at Samsung service center. it is best to replace it as card basis, as plasma power supplies must be very right in every respect for the proper working of the plasma TVs. Thie is quite normal case also, that unlike LCD power supply sections, plasma power supplies will get troubled soon, as it supplies more current to the plasma screen to illumitate. Just replace it. You can get it from the Authorised Service Center for Samsung at your town. It will solve your TVs problem. The oscillating frequency of the switched mode power supply of this model of TV you owns have [350kHz] a very high frequency than normal LCD or other Samsung power sections. It will have a high stability, which cannot be accuired by normal service techniques, and components in it will be of special type. OK.
Posted on Sep 03, 2011
How do I fix my lcd tv that won't turn on? It does not appear to be the powerboard.
Vizio logo is an indicator that the tv is live n changes to white that the screen is on meaning if no change to white the smps switch mode power supply board ain't switching the mother board....diagnosis is its MOSFET transistors need replacement or the smps board n ya tv will be fine
Sep 22, 2015 | Vizio XVT473SV 47 in. LCD HDTV
Samsung TV cycles on and off continuously
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jul 07, 2015 | Samsung Televison & Video
Clicks but won't turn on
if the power board is ok ( seams ok) the and it does 3- 5 clicks it could be a fault in the inverter board for the screen lights. have you been getting screen blank out before. or screen getting realy brite.
Aug 20, 2013 | Sony BRAVIA KDL-46V3000 Television
I have 32 inch Emerson flat screen. It wont turn on, there are no lights at all. I opened it up and the fuse looks blown. I am going to replace it but while looking at the capacitors I saw some white hard...
Yes,those white hard residue are glues.The fuse just don't blow like that.The power supply board could have more trouble than that.If u replaced the tv fuse and tv still don't work.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power suppy board for the replacement.
Jun 15, 2011 | Emerson LC320EM9 32 in. LCD HDTV
Zenith Z50PX2D 50" Plasma HDTV will not stay on. It clicks on then off then on then off several times. I unplug it and wait a few minutes and sometimes it will come on, but not today it just keeps going on...
Had similar problem; I have determined that it was the capacitors in the powerboard! I replaced the capacitors at a higher voltage, and the tv is working again (for now) :) To anyone else having issues, I highly recommend looking at the powerboard before spending any money either fixing or replacing the tv. Take the back off the TV and look at the powerboard, if any of the capacitors are blown they will be bowed out in the back (should be flat) Mine had 7 blown capacitors, all were 3300uf 10v capacitors. (Funny enough it was every single 3300 10V capacitor on the powerboard that blew out...) The fix cost me a total of $21!! And $15 of that was for both soldering and de-soldering irons. Through e-bay I got the 3300uf 16v capacitors for $6.50 (including shipping) I am hoping that the higher voltage will thwart this issue in the future, however only time will tell. If they blow again, I'm going to try 25v capacitors. wish me luck!
Oct 02, 2010 | Zenith Z50PX2D 50 in. Plasma HDTV
I have a 37" Philips (37PF9431D/37) flat panel tv. It won't power on. When you plug it in you can hear a click the green light stays on for a few seconds then goes out. I've checked the power board for bad...
i am having the same problem. My Phillips 37" 37PF9431D/37I LCD High Definition TV won;t turn on. When I press the power button i hear a click and the green light comes on for a couple of seconds and then the red light appears. I can;t figure it out. Did you find a solution?
May 20, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
Philips lcd 37pf9431d/37
finally got some help from customer service ----
the code flashing one then two red lights is for an upgrade of the software ---- you can go to their website and download a current fix to that problem onto a thumb drive----
\the power problem is caused by a bad power board--- you can replace them for any where from 130-330.00
dont need a service tech - take off cover and easy to replace---can find part on parts store.com for philips televisions --- used is about 130 and new about 330 -- used is a refurbished unit and works just as good as the new one
Feb 18, 2009 | Philips 37 in. LCD TV
Philips lcd tv doesn't turn on no power at all
I replaced 3 capacitors on the powerboard. They were listed as 16v/1000uf and all 3 had popped(the tops raise up). I learned on another forum that replacing these capacitors to 24v/1000uf would fix the problem and...it did. My LCD works fine now.
Supposedly all the powerboards were sub-contracted out to another company. To verify exactly which capacitors to change I looked up pics of the powereboard on E-Bay and was not surprised which ones had been changed. It cost me $5 to fix my LCD TV.
Sep 12, 2008 | Televison & Video
No power
First off I did not see make or model. When plasmas die you have failure in either the power supply of the sustain boards. Do you have any voltage readings from va or vs ?
Craig www.classtorations.com
Jun 08, 2008 | Hitachi 42PD7800 42 in. HD-Ready Plasma...
Televison & Video Logo
156 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
