Question about Samsung LN40A650A LCD TV
There is double imaging on my samsung tv, i replaced the tcon board and it still has the double image.
  • Samsung Master
  • 933 Answers
Does it go away when the set warms up? or if you tap the set? Sounds like a possible defective LCD panel tab. Samsungs and Sony's are known for this.
Posted on Dec 04, 2012
    New Friend:
I had the same problem with my Samsung 40" LED tv. I was able to fix it for no money, all on my own. It took a little bit to get the picture back but it was a very easy fix. Watch this video on YouTube. I hope this helps.
https://www.youtube.com/watch?v=j7vl7-vZEL8
Posted on Jul 22, 2014
  • 27 Answers
SOURCE: Samsung LN52B750 LCD TV image smear/trailing
It transfer the universal image signal of TTL and LVDS signal to specific TFT LCD.
No offense, but it is a very complex subject.
Unless you're an EE.
Posted on Apr 09, 2010
Testimonial: "relevant response"
  • 8 Answers
SOURCE: LN37A550 LCD TV has washed out image
It is possible the problem is caused by a wrong option byte setting in the service menu. The correct setting depends on the type LCD panel used in that version. Version number can be found on a sticker on the right side of the television. A bad main board or TCON board can also cause that type of problem.
Posted on Jan 30, 2009
mfspencer
  • 58 Answers
SOURCE: LNS4692D - TCON Board (seems there is a systemic issue)
You have to be very careful with the flat ribbon cables and be sure not to have an electro static discharge to the board while handling it but it is not that difficult of a repair. It is the board that is located at the top center of the back of the lcd panel. Depending on your problem, eg. line in picture, no picture with backlight.... it unfortunately only fixes about half of the units. The other half need lcd panels which are very expensive. hope this helps.
Posted on Apr 02, 2008
  • 304 Answers
SOURCE: Hello, I have a Samsung LN-S4692D.
You cannot test the T-Con bd with a meter. However if you have the luxury of having another same model tv, you can install the bought T-Con bd and see if it is good or bad. Since you said the Menu and channel flashses, then I would replace the Main board.
Posted on Apr 16, 2010
james tv man
  • 91 Answers
SOURCE: Samsung ln52a650
This is called the LVDS cable.........try Encompass parts.com they are samsung distributor........shopjimmy.com has salvaged sets where you can buy the cables and ribbons for a given model as a set
Posted on Jun 02, 2010
I have a samsung LN52A750R1FXZA TV. The bottom of the image is now discolored, with some wiggling colors in the center of the screen.
The TCON board or the LCD panel is faulty. Can confirm by replacing Tcon board
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Jan 20, 2017 | Samsung Televison & Video
Samsung LN46D630 screen flickers
The Tcon board or the LCD pnle is faulty ,can confirm by replacing the Tcon board. If you wish to get some more information about Tcon board problems and solutions then check the following link.
Oct 03, 2016 | Samsung LN46D630 LCD TV
Model UN55B7100WFXZA. Why Double image & horizontal lines on top part only?
T con board faulty or the LCD panel is faulty . Can confirm by replacing the Tcon board .
If you wish to get some details about tcon board problems ; check the site linked here. Pull up older posts.
Apr 17, 2016 | Samsung Televison & Video
I have a Samsung model LN40D630 with double picture ,I changed the t - CON BOARD AND ribbon still have a double picture what next?
Always the double image will not by the faulty T con board. There can be problem with the buffer ics which are located in between the tcon and the lcd panel . The buffer ics are not replaceable one because it integrated to the ribbon which is moulded to the panel. Either you have to go for a new panel or a new tv.
Jan 07, 2016 | Samsung Televison & Video
Double image, how to solve this ?
It has T'Con board. But, it can't be replaced. It is an integral part of the LCD pane; and inside it.
Jul 22, 2015 | Samsung HG32NA470PF 32 LED-LCD TV - HDTV...
I have a Samsung LN37550A LCD TV (full HD 1080) that is 2 years old. 2 days back the images got washed out. All I see is mostly very bright images and negative images. I am told that the TCON card needs to...
U can't buy the T-CON board in any stores in anywhere in the world because this T-CON board it is not buy able it new u only can buy it as a salvage tv PCB board only.This T-CON board u can buy it as refurbish board only.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON board for the replacement.
Sep 22, 2011 | Samsung LN37A550P LCD TV
Our Phillips flat screen TV picture is split down the middle vertically. One side shows a mirror image of the other side, and then sometimes one side is a lighter shade than the other, when it is full...
This may be due to a faulty Timing Control board (TCON board). I had a similar problem with my Samsung LCD TV picture being split vertically down the middle. The image on both halves appeared fuzzy and in reverse (mirror) including the menus. I replaced the TCON board and the problem was resolved.
Aug 18, 2011 | Televison & Video
Samsung LN40A650A LCD TV Logo
1,604 people viewed this question
Jerry Greenberg
Jerry Greenberg
