Question about Ovens
Kenmore electric oven not heating. model#790.97453800 both the broil and bake elements are good.it shows that everything is working on front panel and it sounds like the relays are clicking but no heat.
hotuna
  • 288 Answers
SOURCE: GE Wall Oven - No heat (broil or bake)
On appliances like this only the heating elements use 220 volts. things like the clock, fan, etc use 110 volts. That is why some things work and other do not. Start at the breaker, sometimes a double pole breaker will have 1 side tripped, but will look perfectly fine. switch the breaker all the way to off then re-set. If nothing changes follow the power to the appliance remove the panel and look for some fuses, check to see if any are blown. Also sometimes the microwave will have a separate power source even though its built in to the same appliance. So that's not always a good symptom to follow.
Posted on Nov 11, 2007
SOURCE: Bake element does not heat
After removing the racks, rack rails and the back plate I removed the 2 screws the hold the bake element. Lifting the front of the bake element up and carefully pulling the element out and gently moving the element so the connector clear the hole I was able to disconnect the wire. After testing for continuity with an ohm meter (non found) I determined the element need to be replaced. $37 and 45 minutes total.
Posted on May 29, 2008
  • 33 Answers
SOURCE: Oven does not work after running self cleaning
Dear Dupe,
please rate this solution if it mends up ur needs,else choose fixya,
please do the following checks,
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Check the thermometer bulb
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • please rate this solution if it mends up ur needs,else choose fixya.Thank you
    Posted on Dec 17, 2008
    • 7 Answers
    SOURCE: KENMORE OVEN C970-417757
    possible solution for above...this would apply to any electric oven.
    First of all there are two elements.. one for baking (lower) and one for broiling. (upper) . I assume the lower is not working but is the upper.
    Unplug the oven. Then remove the element and have a look at and the connections.
    I found that on an lolder ovens where I thought the element had burned out that the electrical connections- ( screwed or spade connection) was so badly corroded that electrical contact was poor. I might add that this was also a fire hazzard.
    Drudgedread..
    Posted on May 10, 2009
    • 3230 Answers
    SOURCE: GE JTP 1580W288 Set oven to Bake, switches to broil at bake temp
    The F2 Error code means the oven has detected an excess temperature condition. Most often this is due to a bad temperature sensor - the sensor costs about $75 from an online repair site.
    How to remove and replace the temperature sensor. In most GE ovens, when you open the door, you'll see the rod-shaped temperature sensor sticking out of the back wall at the upper left. It's about six inches long and a bit more than 1/8" in diameter, held in place with two screws.
    Turn off the circuit breaker (built-in ovens) or unplug the range before attempting the replacement.
    The replacement sensor will come with instructions, but basically it's a matter of removing the sensor, pulling out the wires to where they are connected and disconnecting them. You may have to snip. The replacement sensor will come with high-temp wire nuts to hold the new connection. Polarity doesn't matter; it's a straight resistance thermocouple. Hook it up, be sure you poke the connections back far enough so that they're on the other side of the thermal insulation and not resting against the back of the oven.
    If you continue getting the F2 error after replacing the sensor, then the problem is likely in the control module - this is the circuit board behind the keypad and clock.
    You'll need to remove the decorative bezel to get behind the control panel. Remove screws and set off parts in order - it's not complicated. Once the bezel is off there are two more screws that hold the panel in place. Then you can lift the panel up about a half inch and pivot it forward toward you. You'll see a bunch of wires going to a circuit board.
    On the panel you will notice some black plastic boxes that say "Potter & Brumfield" on them. These are relays. Check the relays - slide the black plastic cover straight up to expose the coil and the contacts. The coil, when energized, closes the contacts - look at all the relays. You can manually close the contacts with your finger (be gentle). If the contacts of one of them are stuck, they might be welded together. You can fix the problem by prying apart the welded contacts gently with a knife blade. Take some time to gently polish the relay contacts with a folded bit of fine grain sandpaper - this will get some more life out of them. Be gentle and careful - the relays aren't complicated but if you bend the contact or rip it out, you'll have to replace the controller, which will set you back a couple hundred dollars. If you unstick and burnish the relays, they will probably eventually weld together again as the rough spot will spark, but when you burnish them with sandpaper they should be good for some more life before they need to be replaced.
    If the problem isn't the temp sensor or welded relay contacts then the problem is obviously somewhere else, but temp sensor and relay contacts will account for the lion's share of F2 errors.
    Once again, be safe, be careful, be gentle. Ovens are not very complicated and they're tough, but always exercise care. Always disconnect electricity before messing with them.
    good luck,
    Posted on Jun 28, 2009
    Oven temperature will not cycle
    How To Fix Oven With Little or No Heat When Baking ...
    www.partselect.com/Repair/Range-Stove-Oven/No-Heat-When-Baking/
    Repairing a range, oven, or stove can seem like a big task, but our ... Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake... If the bake element isn't working, the oven may not reach the set temperature or ...If the element appears to look normal, then turn the oven on to a bake ...
    Electric Stove Repair ' Electric Oven Repair Manual ...
    www.appliancerepair.net/oven-repair-4.html
    Inside the oven, the heating element is called a "bake" or "broil" element. ... To maintain a set temperature in an electric cooktop, the element is cycled on ... Do not put any cleaning agents or solvents directly on heater elements or surface units. ... A switch will show no continuity when off and good continuity when turned on.
    Electric Oven Will Not Heat ' RemoveandReplace.com
    removeandreplace.com/2015/.../oven-not-heating-how-to-fix-range-repa...
    Aug 24, 2015 - The issue is most likely a bad internal fuse, oven temp sensor, ... oven replacement parts ... Bake and Broil Element Test - Electric Oven Repair ... Dryer Spins But No Heat - How To Troubleshoot Dryer is turning the drum but ... If your dishwasher is completing the wash cycle but will not dry your dishes, we ...
    Oven Temperature Not Accurate - Repair Parts ...
    Jan 28, 2016 | Frigidaire Ovens
    Kenmore electric range model 911.95875790, no heat to either baking and broiler elements.
    Hello. I looked carefully at the service manual for your unit--surprisingly, there is no thermal switch inline with the bake/broil elements. Usually, if the bake or broil elements pop, this blows out the thermal switch, killing power to the elements for safety. The main control board can get damaged due to the high current draw during a short-circuit. The part number for the main board is WB27T10008. The overlay(the decorative sticker with the button/names on it) numbers are as follows: almond WB27T10022, black WB27T10023, and white WB27T10021. I hope this helps you!
    Sep 18, 2015 | Kenmore Ovens
    Kenmore electric oven will not bake
    The bake element
    is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
    Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. If the element is burned or no longer has continuity, it will need to be replaced.
    Apr 04, 2014 | Kenmore 40494 / 40495 / 40499 Electric...
    Kenmore electric range oven baking element does not go on eveything else works
    The bake element
    Jan 30, 2014 | Kenmore Ovens
    Broiler element not working at all. checked element--it's OK. Called a serviceman-- he thought it was an oven sensor--replaced sensor ---no change Electronic clock some times shows a code "F2 ...
    you do not say it is electric oven. if so broil element requires 240 vac. may be controlled by relay. Is bake element working? also controls for broil may be different setting if digital panel is in this design. I think same sensor may be used for bake or broil.
    you do not say if gas oven, electric oven, single or double oven or if digital panel control, a little more information would help.
    if you have digial voltmeter, FULLY disconnect electric power and measure element on terminals. probably less than 15-20 ohms for a good element.
    Dec 28, 2010 | Ovens
    My oven is burning my baked goods, but shows the right temp with a thermometer. Do I have to turn the dial to broil and then back to the desired temp? Even if the rack is in the middle, everything burns....
    If it is convection bake you have to turn the temp down (25 degrees or so) that is listed in the recipe.
    The broil setting is not used to bake because it operates differently from the bake setting. So, don't go to the broil setting at all.
    The element for bake is under the floor of the oven. You have not indicated whether it is gas or electric, but both of these can have issues with the burner or element.
    If you are baking on the correct setting and the oven is heating from the bottom, not the top, this can be caused by hot spots that are created by elements/burners.
    to check, look under the floor of the oven. Turn the bake heat up to high and see if the flame is uneven. For an electric oven, the color of the element should be evenly red, no brown spots.
    If you are using an oven thermometer, move the thermometer to the spot in the oven that seems to be burning things the most.
    Nov 27, 2009 | Kenmore Ovens
    Kenmore electric range - oven temp low and takes forever to heat
    if lower element tests open with continuity meter then it for sure is bad. i would also check the wire ends that connect to the element and/or the control board, they could have loosened allowing a bad connection and low voltage to elementor burnt off.. most ovens do not use the broil element at all during the bake cycle, only during the broil cycle.. some however do utilize the broil element during baking, but at a lower wattage or something..
    best of luck,
    ttfn
    Oct 25, 2009 | Kenmore 30169 Electric Single Oven
    Oven will not heat.
    Usually, when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
    It bakes poorly Here are two instances of when food "bakes poorly:"
    • When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
      You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
      If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
    • When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly.
      If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective.
      Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details.
      Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat.
      If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
    Jun 01, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
    Ge wall oven will not heat up on bake,boil or clean cycle
    GE JKP86BF3BB COMBO MICRO/ELECT OVEN
    NO HEAT ON BROIL OR BAKE ELEMENTS
    CKD WIRING FROM PANEL OK
    CKD TERMINALS AT ELEMENT HAVE 120V ON EACH ELMT
    FAN COMES ON
    THE ON INDICATOR SHOWS WHEN TMP &START PUSHED
    MICROWAVE WORKS FINE
    I ORDERED A NEW BAKE ELEMENT TO TRY-NOT HERE YET
    STUMPED
    Mar 16, 2009 | GE JTP15 Electric Single Oven
    Oven won't work
    It sounds like your heat ignitor went out. To find out open the door and look for a 1/4" rod that starts in back and wraps to front then to back again that is it. shout door turn on oven to se if that get bright red I would start at 475 degrees. If it does not get bright red it went out and needs to be replaced. If I get model # I can get part # and manual to show you how to replace it. Or you can cal out an appliance repair man.
    Good luck.
    Dec 16, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
    Ovens Logo
    52 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
