Question about Whirlpool Inglis IP8200 Dryer
Inglis dryer making thumping sound when drying
Thumping sound while drying unsure if its the rollers or the pading
  • 1,602 Answers
Is the unit level, open the dryer try moving the drum around, see if the drum loose, there mite something in the machine that got caught on the drum some how and when it goes around it bangs,
you mite try spinning the dryer without turning it on and listen to the drum and see if you can hear any thing hitting the drum or what is make those load sounds. if you cannot turn the drum manually you mite bribe a guy or friend to check it out for a beer or glass of wine, and if they down drink bake some cookies.
good luck rod
Posted on Apr 24, 2015
kachbibi1
  • 979 Answers
SOURCE: Dryer is making loud thumping noise.
Take off the back panel of the dryer and look at the motor and belt turning the drum. There may be something caught on the drum and is pinned in place causing the noise. The motor could be loose on the platform and needs to be tightened. It is probably something physical and seen causing the noise.
Posted on Jan 14, 2009
  • 10865 Answers
SOURCE: do you have a digram to show you how to change belt on inglis dry
amana.gif Diagram A
Style: Flat with ribs
Installation Tips: Ribs face toward drum
transparent1.gif frank.gif Diagram B
transparent1.gif frig.gif Diagram C
transparent1.gif ge.gif Diagram D
Installation Tips: Ribs against drum
transparent1.gif maytag.gif Diagram E
Installation Tips: Flat side of belt against drum
transparent1.gif admiral.gif Diagram F
transparent1.gif westing.gif Diagram G
Style: Flat belt
Installation Tips: Side of belt with words faces away from drum
transparent1.gif whirlpool.gif Diagram H
belt1.gif Diagram J
belt2.gif Diagram K
belt3.gif Diagram L
belt4.gif Diagram M
Posted on Jun 25, 2009
  • 401 Answers
SOURCE: dryer making thumping sounds when on. can feel
Sounds like the drum rollers have flat spots on them.
Posted on Jan 03, 2010
Testimonial: "thanks, will have a techncian check it out"
heatman101
  • 43501 Answers
SOURCE: Clothes dryer makes a ''thumping'' sound
The thumping is probably the belt going bad... a small chunk comes out of the belt but it does not actually tear. When the part of the belt missing the chunk goes around the motor pulley it makes a thump....
Get a new belt and change it before it breaks completely...
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
Heatman101
Posted on Mar 11, 2010
  • 27 Answers
SOURCE: My 3 yr old whirlpool dryer is making a grinding/
1. check your vent
2. Check your belt
3. Check your rollers and tension pulley
4. Check your belt
Posted on Mar 30, 2010
Frigidaire gallery stackable dryer with a thumping sound
POSSIBLE BAD ROLLERS, BAD DRUM GLIDES, WORN BELT, DAMAGED BELT TENSIONER? AND BAD FELTS ON THE DRUM ITSELF
Feb 25, 2015 | Frigidaire Dryers
Creda simplicity TVU1 tumble dryer is making a thumping noise while drying
Hi dave hemming.
I do not believe it is a bearing that is causing your thumping noise
No...you do not need a new drum...all you need is new drum rollers
You probably have a flat spot on one of the rollers, it will make the thumping sound when the drum rotates.
Go to the following webpage and get your drum rollers and install them and that should take care of the noise you are hearing
Please take time to rate me
Bud
http://www.appliancepartspros.com/index.aspx
Oct 13, 2012 | Dryers
Our electric dryer sounds like it csme off trsck...drum turns freely and dries good,but when drum goed round it's like thump,thump,thump,thump... Rick THANK YOU
Hello Rich,
What your describing sounds exactly like one of the drum support rollers has a flat spot on it. Depending on your brand and model number dryer drumm rollers vary somewhat by are pretty much similar. Reply with your brand and model number and ill be able to give you specific info about your dryer
Sep 10, 2011 | Dryers
My dryer makes a thump thump sound
  1. Thoroughly check the inside of the dryer for any foreign objects with hard surfaces. Sometimes items that fall out of pockets become stuck inside a dryer and make thumping noises.
  2. Check for level
  3. Make sure the dryer is level. A dryer that is out of level may not rotate properly. Banging or thumping noises from unleveled dryers are common, particularly if the dryer is resting against another metal object such as a washer.
  4. Check rollers
  5. If the thumping noises are present only for the first few minutes of the drying cycle the likely culprit is rollers. If the rollers are warped they will need to be replaced and a professional should be called in to help
Dec 17, 2010 | Frigidaire Electric Dryer
Not drying
Hi. When a dryer takes that long, check the entire length of the vent pipe for a partial clog from lint. Clean out the lint and the dryer should dry in just one cycle. Regarding the thump it most likely is a loose or bad roller. J.
Jul 02, 2010 | Dryers
SOUNDS LIKE YOU ARE DRYING SHOES IN THE DRYER. EVEN WHEN THE DRYER IS EMPTY!
Bad rollers
These rollers get a flat spot on them and make a thump type noise with every revolution. More HERE
Jun 10, 2010 | Kenmore Rear Control 8885 Dryer
Thumping/rubbing sound in drum
The belt tensioner roller has a flat spot caused by a worn bearing that catches and stops whilet the drum is turning. This causes the flat spot and the noise its making. You can purchase a new roller by itself and do change the belt the same time too
Apr 08, 2010 | Frigidaire Electric Dryer
Dryer making a thumping noise, heating okay, drum is going round. could drum be out of round and thumping on the rollers
the roller is out of round instead for the internal bearing has dried up and locked tight making the belt to burn the nylon roller flat in the spot the belt rides on. It will be neccessary to replace the belt and the roller as well
Feb 20, 2010 | LG DLE2532W Electric Dryer
Makes thumping sound on start up,thumps or knocks ocassionally while drying
This is probably your drum rollers going out. While you are replacing the rollers, I recommend you also replace the belt and also blow all the lint out of your dryer while you are inside the unit. This will prolong the life of your dryer as well as prevent a potential fire from lint getting caught on fire. Call us for your parts and we will be sure to get the right ones for you. We need the brand and model number off your dryer. Ella :>)
Sep 09, 2009 | Dryers
Constant "thumping" sound when dryer is going
you can fix it by ordering a whirlpool roller kit but its no big deal the drum sits on rubber rollers when it just sits the rolers get flat spots on them like tires and makes the thumping sounds its just noisey but no big deal but they do make a kit with softer rollers
May 24, 2008 | Kenmore 63942 Dryer
Whirlpool Inglis IP8200 Dryer Logo
95 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
