Washer stopped before spin cycle, wont restart,upper agitator turns freely, but lower one turns the tub,washer goes through itstrouble shooting then shuts off.
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
What is the complete model number of the unit?
Posted on Dec 04, 2012
SOURCE: Bosch Axxis WFL 2060 Front Load Washer--Tub won't move
what a bogus website you are. you offer no free support and you should say so
Posted on Jul 13, 2008
  • 71 Answers
SOURCE: agitator won't turn and tub won't spin
The motor coupling is broken, the part located between the motor and the transmission.
Posted on Dec 25, 2008
  • 3 Answers
SOURCE: whirpool washer wont agitate or stop filing with water
If that didn't work there is another possible solution... I had the same problem... and since I am cheap I like to make sure I try everything I can before buying parts... so heres what you do...
-Remove the front panel off the washing machine.
-Look on the side of the tub for where the pressure hose attaches to the base of it.
-Check for a build up of gunk in the hose near where the tube meets the tub... you'll probably notice wht looks like mildew... usually you can just pull it apart.
-I used pipe cleaners to clean out the end of the tube (you can usually unattach from both ends to make it wasier to work on)
-Now before you put it back together grab a can of compressed air and use it to blow down into where the hose connects (as there is usually a build up there too).
-Reassemble... TADA... if that fixed it you just saved yourself some $$$.
~~~~ Mittonman
Posted on Jan 26, 2009
jsrock516
  • 5911 Answers
SOURCE: Whirlpool LSR5233EQ0 top loading washer wont spin
If the washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupler that is more resilient and should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria. Let me know if you have any questions. I hope you find this information helpful. NOTE: There are other problems that can cause the washer symptoms as you describe, but the motor coupling is the least expensive and easiest solution to try first. If the motor coupling is still intact, please let me know.
Posted on Jun 24, 2009
  • 126 Answers
SOURCE: maytag washer wont agitate
you have a bad bad break package which is mounted above pulley located on bottom of machine.special tool required.Hope this helps .pleases rate my answer:)
Posted on Dec 09, 2009
Agator not spinning
There is no belt on that unit. It is a direct drive machine. When the unit goes into the wash cycle, does the motor run but it does not agitate?
Nov 28, 2012 | Maytag MVWC400XW Centennial 27" Top-Load...
My Whirlpool Ultimate Care II washer goes thru all cycles but will not spin, so clothes are wet. We replaced the motor coupler but will only spin without clothes. Once you put clothes in the tub does
sounds like direct drive gears are bad.. there is a slip coupling that goes over the shaft of the transmission adn assist turning the tub that could be worn or broken. you will have to remove the agitator and check the nut on top of the tub to see if it is tight or to remove the nut and check that coupling.
Dec 01, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Amana Washer LW4303W. Tub spins much to freely while the agitator agitates. Could be coincidental but this problem seems like this all started after I replaced the drive belt. Washer cycles like it...
Yes, there is a brake that holds the tub while the machine is agitating. I don't have a manual handy for that model, but you probably have a plastic pulley in the center bottom of the machine. The brake is above that. There is a cam arrangement inside the pulley that will disengage the brake when in spin.
May 10, 2011 | Washing Machines
Is the upper part of the agitator supposed to spin with the lower part? It spins freely when I turn it, but doesn't spin when spin cycle is activated during a cycle.
You have bad agitator dogs . Easily replaceable and inexpensive . Remove the center bolt holding the agitator on and seperate the 2 agitator pieces . You will see 4 teardrop looking pieces ( dogs ) . Replace and your done .
Jun 29, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
My Kenmore elite wont drain. every time it starts the cycle it stops spinning because the water wont drain. we think its clogged but we don't know what to do.
It won't drain If your washer won't drain, check these: It spins, but doesn't pump It doesn't spin or pump It pumps, but the water returns It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump. It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems: If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Jan 01, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Full of water, won't drain past the agitation stage, just goes dead
  • If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
  • If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
May 04, 2009 | Washing Machines
The tub jumps around in the spin cycle of Kenmore 90 washer.
The following advice is for replacing the "Agitator Dogs" on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are "Agitator Dogs"? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
SYMPTOMS REQURING REPLACEMENT: The agitator fails to turn during the wash cycle, or will not turn with a heavy load. The timer will run normally through all cycles, and you will be able to hear the gearcase (transmission) engage and run. The washer will also drain normally. The only indication that something is wrong will be the agitator slipping or not turning at all. The result will be clothes that do not wash properly and will sit on the bottom of the wash tub.
To replace the Agitator Dogs, follow these steps:
1.Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2.If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3.Remove the center bolt of the agitator. You will have either a 7/16" hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8" to ½" ratchet adapter to remove.
4.Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
5.Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It's that simple.
7.With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
8.Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
9.Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
10.Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 15, 2009 | Kenmore Washing Machines
Maytag top loader washing machine
i believe i can help you,,but washers dont agitate in the spin cycle,,i believe you ment it wont wring or spin in the spin cycle..your lid switch is defective,,replace,,if need be i can talk you though,,onthejob
Dec 28, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washing machine shaft wont move
hi friend,
hoses
* If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
* If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Dec 08, 2008 | Amana 3.2 cu. ft. Top-Load Washer
Whirlpool top load washer
Check to be sure inner tub is not spinning freely on spin tube. It can be noisy when this happens. When it's spinning and stops it may continue spinning for a bit when this happens. You usually need to replace spin tube, because the tabs that key into drive block for inner tub break off. Also replace drive block.
Nov 08, 2007 | Washing Machines
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
