Question about Garmin zumo 665 GPS Receiver
Purchased a new Harley Davidson Zumo 665 with XM, handlebar mount and radio interface connections (all HD dealer items). The unit started freezing and turning off without warning day one (immediate black screen). I got a replacement unit from Garmin (warranty) and the new unit is doing the same thing. Replaced the cradle and it worked for the first day without noticeable issues but yesterday it started doing the same thing again after the screen calibration when I turned it on. The unit will now turn off within 10 seconds of powering it on while on the Harley cradle. The battery is fully charged and it works fine in automobile mode using the automobile mount. The XM will play through the ear bud and stereo and the radio mutes when voice map commands come through the ear bud. I do not have a SIM card or music, or photos downloaded to the unit. Garmin confirmed the unit does have the latest map and program software installed. What should I check next?
  • 6 Answers
SOURCE: Will not power up out of cradle
To power the unit back on, press the "Mode" and "Reset" buttons at the same time. Let go of those two buttons, press the power button, and the unit will turn back on."
Posted on Apr 29, 2008
marcelbakker
  • 174 Answers
SOURCE: my zumo won't power on
This sometimes happens if the cradle is owered while you connect the zumo...i guess it hits some wrong contacts first and goes bonkers. I'd advise th zumo users to pack a small allen screw bit to unscrew the battery, just in case it freezes or blacks out again....better safe than lost in the middle of nowhere!
Posted on Oct 27, 2008
SOURCE: My Garmin Nuvi 260 is frozen on the Garmin screen
with the garmin off, hold down the right bottom of the screen and turn the garmin on, it will then ask you if you want to perform a hard reset. Choose yes and that should fix your problem.
Posted on Sep 15, 2009
SQUIRESXX
  • 486 Answers
SOURCE: My Garmin 1350 is fully charged. I used it
the software on garmin 1300 models is atleast 3.6/7 sounds like ur update didnt take, also check in settings see if you have a timer setting for sleep mode/stanby after x time
Posted on Dec 26, 2009
HarryHarley
  • 343 Answers
SOURCE: My Garmin nuvi 205w turns itself off. I switch it
Sounds like your battery is getting weak.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The nuvi 200 series, 300 series, 600 series, 700 series, 1000 series and the StreetPilot C300 and C500 series do not have user replaceable batteries. These units must be sent in to a Garmin approved repair facilities if a battery issue arises. Garmin and Raytech are the only Garmin approved repair facilities. Raytech is a repair facility for Canadian customers. To repair your device please contact the specific repair facility probably at Garmin.com. If your device is not still under the 1 year warranty, there will be a cost associated with the repair of your device.
Posted on Feb 06, 2010
2008 ultra classic radio wiring diagram
Hi Anonymous, for a free wiring diagram please visit the website below and good luck.
Harley Davidson Wiring Diagrams and Schematics
Aug 17, 2012 | 2000 Harley Davidson FLHTCUI Electra Glide...
How can I my 2004 Honda Goldwing mic to work with my Garmin Zumo 665 to answer my cellphone? The phone bluetooth connection works fine with the Garmin in my car, but my Honda mic does not work through the...
The microphone input from the Zumo 665 motorcycle mounting cradle is the smaller 2.5mm jack.
Be sure to use this one as some microphone jacks will require a 3.5mm to 2.5mm adapter.
The audio output is the 3.5mm jack.
Be sure not to confuse the two.
It may be necessary to have a custom 5 or 7 pin DIN adapter made to connect between the GW audio system and the Zumo.
It would be best to consult with your local Honda GoldWing dealer for more information on interfacing the GW audio system.
Oct 07, 2011 | Garmin zumo 665 GPS Receiver
I have a garmin 655 zuma i have the xm, use it on my harley ,,,,want to use it also in my motor home but my radio dont have a plug in it for the audo,,,how can i do this ???? Thanks Gene
I would recommend using one of the many FM transmitters that are available on the market and plug the Zumo 665 into it using the audio out port. The audio can then received by the FM radio in the motor home. This is assuming that the radio in the motor home has a FM receiver.
Sep 19, 2011 | Garmin zumo 665 GPS Receiver
How do I Install a '96 Harley radio into a '99 Harley Davidson FLHTPI? And how do I get the wiring schematics for the '99 Harley Davidson FLHTPI?
96 mounting and wiring will be completely different. The handlebar controls on the 99 will not function on the 96 radio.
Search HD forums for the wiring diagram or buy then from harley
Jan 07, 2011 | Harley Davidson 426290 AM/FM Radio
My radio will not accept any input from the handlebar mounted switches......not on the volume treble or bass or the other side with band. In addition i cannot turn off the unit, it will not accept any...
If there is no audio, the radio is locked on an fm station with preset 1 highlighted, and no control from the handlebar or face, the TMS 320 processor is locked. The radio cannot be repaired. try to get your HD dealer to exchange it.
Oct 30, 2010 | Harley Davidson 426290 AM/FM Radio
How to install Garmin Zumo 660 gps on harley-davidson. It needs to be installed on a 2009 Street Glide FLHX.
The unit comes with a Motorcycle mount with integrated power cable and mounting hardware.
Oct 09, 2009 | Garmin zumo 660 GPS Receiver
Harman kardon audio system for harley davison not calibrated
problem is radio has blank data, i guess are left blank for language intergation
New Harman/Kardon radios come blank from H-D however, and currently the dealers are the only ones who can calibrate/program them properly.
Check with your local Harley-Davidson dealer to see if they are willing to help get your new radio programmed before you install it on your bike.
Jun 06, 2009 | 2008 Harley Davidson FLHX Street Glide
Installing XM on my Motorcycle
Pick yourself up a Garmin Zumo 550, it has a navigator, MP3 player, photo viewer, and XM (Radio, Traffic, & Weather) and best of all the music gets interupted when it's time to give you directions.
May 03, 2008 | XM Radio (XMP6000)
Trying to add more audio equipment to my Pioneer Nav stereo
The Avic N2 is only XM ready not Sirius ready like the N3, which is SAT ready(both XM and Sirius). If you must have your Sirius the only option left for you is use the rear input on the hide away unit but you won't have it on the touchscreen. There is one more expensive option by have your N2 hardware upgrade to N3, some Ebayer have that service offer for about $275. It's done by replace a surface mounted chip with 70 plus leads. That would take some expert de-solder and solder skill with a solder torch or
a tech's heat gun. I can do it but I don't know which chip it is. I have an immaculate N3 for sale on Ebay. Maybe you could sell your N2 and buy an N3. I usually get about $550-$650 for an N2 depend on the condition. Hope that I did some help. You can call me at 801-414-4566, I would do anything I can. Goodluck.
Feb 15, 2008 | Pioneer AVIC-N2 Car DVD Player
Garmin zumo 665 GPS Receiver Logo
248 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
