Question about Fisher Price Power Wheels Lightning McQueen
Troubleshooting motor for power wheels lightning mcqueen
The sounds on the steering wheel work, but when you put in forward or reverse and push the pedal, nothing happens
    Genius:
  • Fisher Price Master
  • 1,508 Answers
You need to recharge the mototr battery, it should be under the seat, the sounds on the steering wheel are run from a different battery source
Posted on Dec 07, 2012
5 Suggested Answers
  • 33 Answers
SOURCE: Kawasaki Ninja 4-Wheel
I have taken a lot of these power wheels apart, there are nylon gears that when the vehicle is powered forward and cannot move the teeth on the plastic gears will wear down and slip.
Here is an ebay site.
To replace the gearbox you will need to take off the axle cap and shaft washer that holds the wheel on.
Slide off the wheel.
I think this power wheel has a silver plastic housing that covers the gearboxes and axle, which means that there will be an amount of screws to take out before you can get to the guts.
Once you get to the wires on the motor you will need to cut and strip them and install the replacement
If you can, I would prefer you would crimp the wires together with a blue or Yellow **** splice, but if you do not have crimper or lugs You can use wire nuts large enough to firmly connect both wires. Then electrical tape the nuts and wires to prevent loosening by vibration. Even though these are 6 volt batteries their current is enough for wires not connected well to overheat, melt and could possibly become a fire hazard.
Ideally the wires from the replacement would be the same color as the original but if not you will want to test to see if while in forward it does go forward. If not you need to reverse the two wires. This is a headache saving measure.
Re-assemble everything making sure that the axle nut or cap goes back on Tightly to prevent the wheel from falling off during use.
Posted on Sep 27, 2008
SOURCE: power wheels kawasaki ninja fx will not go in reverse
If you use a butter knife to pop out the forward\reverse button there is 2 other prongs that the wires are no connected to. Connect the wires to the unused prongs. I had this problem and I was going to order a new switch until I tried this. It worked for me.
Posted on Feb 17, 2009
SOURCE: Power wheel F150 only works
My son had the same problem. At first I was angry because we just bought this toy, but then I realized he didn't have it in gear all the way. I had him put it in reverse and drive it back a little. Then I told him to put it in drive, and (making sure it was properly in gear), told him to go and it did. I think it just takes the kids a little while to get used to it and make sure it's properly in gear. Good luck!
Posted on Jan 12, 2011
canwoodjc
  • 3301 Answers
SOURCE: I have a Power Wheels
check for a shorted switch under the pedal , its just an on and off momentary switch, so just run a jumper wire between the 2 contacts, and if it runs, replace the switch , if it doesn't, use a meter to make sure the switch is actually getting power to it
Posted on Jul 04, 2011
The bike will go in reverse but won't go forward. how do I fix this?
Lil' Rider FX 3 Wheel Battery Powered Bike, Black - Amazon ...
www.amazon.com/Lil-Rider-Wheel-Battery-Powered/...
Amazon.com, Inc.Amazon.com: Lil' Rider FX 3 Wheel Battery Powered Bike, Black: Toys & Games. ...On Motorcycle 6V Toy Battery Powered Electric 3 Wheel Power Bicyle, Red ... VTechGo! ... sound effects, working chrome colored headlight, and forward and reverse ...power wheels vehicle more to handle size, weight, and your child won't ...
Lil' Rider FX 3 Wheel Battery Powered Bike, Blue - Amazon ...
Amazon.com, Inc.Amazon.com: Lil' Rider FX 3 Wheel Battery Powered Bike, Blue: Toys & Games. ...Sold by: Global Supplies (We currently can't ship to, HI, AK,APO,FPO, POB) .... Ride On Motorcycle 6V Toy Battery Powered Electric 3 Wheel Power Bicyle, Red ... sound effects, working chrome colored headlight, and forward and reverse ...
KB901 Lil' Rider FX 3 Wheel Battery Powered Bike ...
? 8:05
https://www.youtube.com/watch?v=fED8N8DTQfU
Oct 21, 2013 - Uploaded by TMKGL
Jan 07, 2016 | Lil' Rider FX 3-wheel Battery Powered Bike...
My 99 explorers fuel pump went bad so i had to push it out of a parking lot. My wife got behind the wheel and took it out of gear and we started pushing i looked down and noticed that the reverse ligh
I doubt it. The brake system would not know or care what the transmission was doing.
You could move the truck with the trans in reverse as long as it was not running. No difference from being in drive or reverse.
I have pushed power steering fluid out of the pump by turning the wheel with the engine off, but never brake fluid from the master cyl.
Aug 30, 2014 | Cars & Trucks
Put in new batteries status light blinks no forward or reverse
The blinking is a flash code, maybe you should check the free wheel lever is in the drive position."hard to manually push"
Scooter Doctor App
May 31, 2014 | Pride Value Line Revo Scooter 3 Wheel
Fisher price power wheels dune buggy will not work when put in the forward gear but it will work in the reverse gear
check to see if both wheels are spinning in reverse, if not one of the motors is bad or disconnected and this will affect the forward gears
Feb 04, 2013 | Toys
I have purchased a fisher price power wheels lightning mcqueen ride on. I want to re sticker it but I cannot find the decals with the large lightning bolt and 95 fur the side or the rustler decal. Can...
hi I have a lighting McQueen electric ride on car can anyone tell me where to get replacement stickers for it as they are falling off.
Dec 01, 2012 | Toys
How do u put the front wheel on the Huffy Cars Lightning McQueen 16 Boys' Bicycle
back off the nuts and washers up on the wheel axel. Place the wheel between the forks positioning the axel in the slots. Replace the washers and nuts and tighten with a wrench
Dec 25, 2010 | Huffy Cars Lightning McQueen 16 Boys'...
Son's can pedal 12" bike
Yes, something isn't turning freely. It's either the front wheel, the back wheel, or the pedals and chain. Lift the bike off the ground and turn the front wheel by hand. If it doesn't turn very freely, it could be the hand-brake is dragging or the hub bearing is too tight. Try the back wheel in both directions. It should move freely in the forward direction. When rolling it backwards it is normal for the pedals to move too if this bike has a coaster brake (that is the kind of brake that is applied by pushing the pedals backwards.) It the back wheel moves forward freely, but backwards is a problem, then try the pedals by hand with the rear wheel off the ground. If this doesn't turn freely, the pedal crank bearing (a.k.a. bottom bracket) is too tight. Once you have identified the problem take it back to where you got it. It should be easy to fix, or they should replace it.
Jul 28, 2010 | Huffy Cars Lightning McQueen 16 Boys'...
Power wheel wont reverse
I would call customer support and find out why the powerwheel does not go into reverse. You advised that it was the f150. I can give you the link as to where I tried to see if there might of been a safety feature of not letting the unit go into reverse. Here it goes http://www.fisher-price.com/us/powerwheels/product.aspx?pid=38040 I am not sure if it is the same one. You can also call this number Contact Consumer Relations toll-free at 888-892-6123.
We are available Monday through Friday 9 AM to 6 PM Eastern Time, 6 AM to 3 PM Pacific Time.
They might be able to tell you about your exact model.
May 01, 2010 | Fisher Price Power Wheels Barbie Jeep
Fisher Price Power Wheels Lightning McQueen Logo
284 people viewed this question
Top Fisher Price Toys Experts
Bill Boyd
Bruce Mommaerts
Bruce Mommaerts
Jennifer Rock
Jennifer Rock
Are you a Fisher Price Toy Expert? Answer questions, earn points and help others
