Question about KitchenAid KSM150PS Artisan Series Stand Mixer
Bowl stuck in base
I cannot unscrew the stainless steel bowl from the blue base.
  • KitchenAid Master
  • 1,238 Answers
Try harder, there is only one way to get it off and that is to turn the bowl.
Posted on Dec 25, 2013
What is the difference between a KitchenAid KSM155GBCA and a KitchenAid KSM150?
There is sod all difference except it comes with a glass bowl where the KSM150 is stainless steel bowl.. Motor is the same so not more powerful.
Dec 08, 2015 | KitchenAid KSM150PS Artisan Series Stand...
My bowl gets stuck. It is extremely difficult to unscrew from the base. It's like it is getting tighter and tighter while it mixes
Well you will be happy to know that it is only a matter of "Wear and Tear" The culprit can be one of two possible things. The screw cup on the mixer or the bowl itself. Understand that...the metal on the bowl or mounting cup are pressed or what you might call metal stamping. When you use the bowl and the mixer over time the metal wears down and or compresses and it takes more pressure from you when you seat the bowl for use and the pressure created by the use of the mixer when the bowl is in place is caused because the locking cup and bowl screw together the same way that the mixer turns and cookie batters or bread dough help to lock the bowl tighter and tighter. Now that you know the reason how do you fix it?? Well the screw cup is the easiest and least expensive. Just order one off the internet and when it arrives unscrew the three retaining screws and put the new one on. If that doesn't fix it then you may have to consider a new bowl. Hope that helps.
Jun 28, 2014 | KitchenAid K45SS Classic Stand Mixer
Kg25h0x mixer
Type not found at Kitchenaid. no_image_available_kad_71x71.png 5-Qt. Stainless Steel Bowl with Comfortable Handle
5-Qt. stainless steel bowl with comfortable handle offers enough capacity to mix dough for 9 dozen cookies, 4 loaves of bread or 7 pounds of mashed potatoes in a single batch. The bowl is also dishwasher-safe for quick and easy cleanup.
Mar 04, 2014 | KitchenAid Food Mixers
How do you attach bowls to mixer
The bowl sits on a round plate. If the bowl cannot sit properly, moce the round base a notch on the right to give more bowl space.
Nov 27, 2013 | Kenwood Food Mixers
Bowl lift on my kitchenaid 5 profesional is slipping
Replace the plastic bowl lift part on that crankhandle inside the pedestal.
Dec 12, 2012 | KitchenAid Kitchen Aid Mixer Stainless...
Dough blade is scraping the stainless bowl. The mixing head seems to be sitting lower. In order to lock the tilt I have to lift the head a little.
If you're still having this problem, here's what I did a few minutes ago that fixed it. Lift the head, then turn the screw that connects the head to the base to the left. You're basically unscrewing it. That screw regulates how high or low the beater is. Unscrew it a little at a time, and lower the head and try to lock after each turn. The head will gradually get in a more locked position. Keep turning the screw till the head finally locks in all the way. Read the "beater to bowl clearance" section in the manual.
Nov 20, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
Does anyone know the model number of a stainless steel bowl to fit the Kenwood Chef KM300/
The model number doesn't really exist other than the fact that the stainless steel bowl is available for just about every Chef made. My own KM300 has a stainless steel bowl for example that came as standard - it however is the same bowl you can order from Kenwood or EBay under the A701/A901 model - all bowls from Kenwood can be fitted on the Chef model with the exception of the Major model which is a larger and taller machine.
May 06, 2009 | Kenwood KM300 Chef Stand Mixer
Bistro Staned Mixer;Mixing bowl is stuck(?) to base
You have to twist the bowl anti-clockwise to release it from the base. Twist clockwise to lock it when using the beaters.
Nov 23, 2008 | Wolfgang Puck Stand Mixer
Stainless Attrezzi Bowl
I bought a stainless bowl for a kitchenaid mixer and it fits
Jun 05, 2008 | Jenn-Air Attrezzi JSM900 Stand Mixer
Replacement stainless steel mixing bowl for kenwood chef A901D
I have the spare part number for the bowl.
KW638821 - bowl - polished - stainless steel
KW672487 - with handles bowl - mirror finish
try to find a store near you to get one.
Apr 15, 2008 | Kenwood KM300 Chef Stand Mixer
KitchenAid KSM150PS Artisan Series Stand Mixer Logo
110 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
