Question about HP Pavilion a1510n PC Desktop
Dvd player wont play and when it does my computer automatically restarts
I installed a dvd player model number gh24ns90 lg modisc its a multi dvd rewriter, i just cant play anything it reads the disc but when you right click or open my cpu automatically restarts,my cpu is a hp pavillion model a1510n can somebody help?
    Guru:
  • 571 Answers
Have you installed the correct driver for your DVD player? Chances are, your computer is not properly communicating with your computer or your DVD player isn't compatible with your computer. To automate your driver update, you can install Radarsync to your computer.
If updating or installing the driver won'f fix the issue, then I suggest that you contact your DvD player manufacturer and check whether it is compatible with your computer.
I hope this helps.
Carlo
Posted on Dec 05, 2012
5 Suggested Answers
  • 31 Answers
SOURCE: I would like to install a LG CD/DVD in a HP Computer how?
do you have a cd or something
Posted on Sep 26, 2009
SpideRaY
  • 687 Answers
SOURCE: hp pavillion a1120n wont auto read cds
This would mean that autostart is not turned on many programs will turn this on for you like Apples iTunes.
You can turn it off using TweakUI powertool if you use WinXP Home, howeverthe best way is to use a reg tweak to turn it ON however I suggest that you keep it OFF for normal use;
Click Start, Run and enter REGEDIT Then go to:
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\Explorer
Create a new value called: NoDriveTypeAutoRun
Type is: DWORD
Value is: 0x000000b1 (177)
If you use WinXP Professional and feel up to changinf your templates you can enter the Group Policy window.
You should select Administrative Templates \ System in the tree view: grouppol.png You will see an item in the right side pane called “Turn off Autoplay”
Double click the item, and set the radio button to Enabled, and change the “Turn off Autoplay on” to All Drives.
Posted on Dec 14, 2009
zooless
  • 109 Answers
SOURCE: HP Compaq DC7900 CD/DVD problem - computer does not read them
I guess the CD/DVD drive is not detected in my computer
Then you can follow the following steps:
CAUSE-It may happen due to some corrupted registry keys in the computer. We can follow the following steps to delete the upper and the lower filters.
RESOLUTION/ WORKAROUND-
1. Locate the following key in the registry: HKEY_LOCAL_MACHINE\SYSTEM\ControlSet
2. In some cases, there may be multiple ControlSets. You may see something similar to the following HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet002
Or
3. Select either CurrentControl Set or the lowest numbered ControlSet, for example, in the second list above, ControlSet001, and do the following.
4. Locate the following key and highlight it in the left window of the Registry Editor. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
5. In the right window, you should see something similar to the list below. There may be some variation in the listed drivers for the upper and lower filters. For example, the upper filters may list a driver other that PWD_2K. You may also see only upper or only lower filters:
LowerFilters = CDRALW2K
UpperFilters = PWD_2K
6. Delete the upper and/or lower filters.
7. Exit the Registry Editor and restart the system.
NOTE: If the computer still does not recognize the drives, go back into the registry and repeat the above steps for editing the registry for each of the ControlSets listed on the system.
Hope it works for u
All The Best !!!!
Posted on May 11, 2010
akjh90
  • 24 Answers
SOURCE: THE CD/DVD PLAYER ON MY HP PAVILION a1110n WILL
First of all check if the drivers are properly installed in device manager:-
Right click on Computer and then click Properties--device manager, expand CD/DVD Rom drive and check if the driver is installed.
If driver is installed right click on it and click on delete and then restart the computer.
If the above step doesn't help then try to delete upper/lower filter in registry:-
Click Start--Run type 'regedit' and press enter and now expand the following-
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
now on the right panel right click the 'upper filter' and click delete and then right click the 'lower filter' and then click delete.
If these steps doesn't help then it means there is a hardware fault with your dvd/cd drive and you need to replace the same.
Posted on Dec 19, 2010
What SATA cables do I need to hook upDevice? Have factory installed into my CyberPower Desk top a LG Multi BlueRay/DVD/CD
SATA devices do not have jumpers to configure as a slave/master.
You connect each SATA device to separate SATA connector on the motherboard.
Nov 20, 2012 | LG GH24NS90 24x DVD RW DL SATA Drive Black
My LG RH397D HDD wont recognise dvds any more
The only thing you can do is try a DVD cleaning kit and follow instructions, if that fails the laser pickup assembly will need to be replaced, but this would be to expensive and far cheaper to replace the player.
Mar 27, 2012 | LG Televison & Video
Some multi video dvd"s &
Probably is not problem with dvd but you don't have adequate player, install this software it is free and can play various formats:
http://www.videolan.org/
Jan 17, 2011 | LG GSA-H55N DVD-RAM Burner
Apparently they are locked to region 4 and I have bought region 1 DVDs so they won't play
In most models the unit cannot converted to multi-regions.So it will play only in the specified region in which it is applicable to.But in some unit models there is a procedure to turn the unit to multi region so it can play all region dvd.On all models the procedure to convert the unit to multi region is different.As you have not mentioned the exact model number of your unit.t will not be easy to give exact details.If in case there is a procedure to convert your unit to multi region.
Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Sep 14, 2010 | LG Audio Players & Recorders
No sound with my LG Portable Super Multi Drive
It will not work properly. If you contact their support they will just try to get you to pay for an upgrade of the software. Take it back to the store and get something else.
Mar 06, 2010 | LG Electronics 16x DVD and 48x CD-ROM...
Wont read dvd video discs
1st step; Acquire/buy a cd/dvd rom drive cleaning tool kit from your local pc store.
2nd step; Install a dvd coder/decoder software, try Power DVD player software it has a trial version
3rd step; After installing the DVD coder/decoder from Power DVD player try playing a dvd movie rom disc it should work/play... hope these tips help ;-)
May 24, 2009 | LG GMA-4020B Super-Multi...
Regional code
You should contact the manufacture support to see if they have a version of firmware you can install in to the player to re-program it for the UK standard.
In most cases you will have to go out and buy a player that was originaly designed for the region where you are. You can also shop around to see if it is possible to have a multi-region player. In some locations these are legal to be sold.
Jerry G.
Apr 26, 2009 | LG DVD 5253 DVD Player
DVD PLAYER MULTI REGION CODES
you can change your dvd region code but i advise you not to change it instead use a software . here is the link for the software to download :- http://www.4shared.com/file/19492658/43612f11/DVD_Ghost.html?s=1
if it doesn't work then contact me ok.
Jun 28, 2008 | Televison & Video
Regional code
open tray
Press PAUSE
enter 0000
The region code set page should appear.
Set code. 0 for multi region
Press PAUSE.
OR
Make sure your TV is on and the DVD player is active on it
Unplug the DVD player
plug it back in
wait for text "nodisc" to appear on the DVD display
Use remote control to open tray (tray must stay open)
Use remote control to Press "Pause" (you won't see anything)
On the Remote control number pad enter the number "0000" (4 zeros)
The region code setup window will appear on your TV
on the remote control number pad enter number "0" (zero)to set multi region
Use remote control to Press "Pause" again
close tray
Jun 06, 2008 | LGDVB418 DVD Player
HP Pavilion a1510n PC Desktop Logo
65 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
