Toshiba Regza 55zu655u won't turn on no lights
Turned off one night would not turn on in morning
  • Billy Aletinov Dec 04, 2012
    all fuses are good has power going in
  • SD Tech
    SD Tech Dec 13, 2012
    Someone (tech or a shop) is going to have to follow the voltage inside the set to see where it vanishes . All these sets only sell boards, no single parts so it may come down to replacing boards which can get rather expensive if you can find the boards you need.
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
If its total dead with nothing suspect the fuse the power cord goes to inside the set, if other let me know what it is doing or not doing in more detail.
Posted on Dec 04, 2012
  • Billy Aletinov Dec 13, 2012
    I have power at all the resistors on each side of them, the condensers all physically look fine. I am now at a stand still I do use a multimeter and know how to use it on resistors and ac and dc power.
My car won't turn on it was working fine last
Just because you charged the battery it doesn't mean it is any good. Modern sealed batteries fail; just as you described, fine one moment and then nothing, they go open internally.
Jul 19, 2013 | Cars & Trucks
Toshiba REGZA 40E200U 40 LCD TV wont turn on after it was working fine the night before.
Your TV needs servicing, Most likely you have a power supply related issue. Do you have any experience with electronics repair?
Sep 01, 2012 | Toshiba REGZA 40E200U 40" LCD TV
What's your problem? won't turn on..... yellow/orange light continually flashes three times...
Toshiba Regza 37in - 37HL17
TV will not turn on - Yellow power ind. Light blinks three times...
Fixed with a firmware update (hard to believe, but true). Search Google for a file named: 2007SEN069.zip (don't worry if the page you find it on doesn't mention the 37HL17 - it worked fine). Unzip the file, and copy the 3 folders and 3 files to the root of a small SD card. The SD card MUST be 2GB or less in size (I used a 1GB card), and it MUST be formatted with FAT-16 (not FAT-32). Mine was pre-formatted as FAT (FAT-16). The SD port is on the back of the TV behind a cover plate near the power cable. You do NOT need to remove the back cover of the TV, just the small cover plate (1 screw). UNPLUG the TV; remove the cover plate; insert the SD card (prepped as explained above); Plug in the TV; Watch the yellow lights blink, then turn blue, then go dark; UNPLUG the TV; remove the SD Card and replace the cover; Plug in the TV; Yellow lights will blink a few times (this is normal); when blinking stops, turn on the TV and you should be good to go. :-)
Pictures attached are from a Toshiba software upgrade bulletin I found online.
09adb97e-8925-4d59-b218-7443a6e64989.png 82ea33aa-2353-4e13-a5db-8be13ba85711.png
Aug 06, 2012 | Toshiba Regza 37HL17 37 in. LCD TV
My Toshiba regza television won't turn on
A model number would be helpful but in general if the red light just blinks the set is in shutdown since some error or problem has been detected.
Jun 03, 2012 | Televison & Video
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Jul 16, 2011 | Toshiba Computers & Internet
Hi. I have a 42"
The best solution to this problem is to call Toshiba directly and ask for assistance. Any TV repair company/shop will probably charge you an automatic fee to assess the problem, and then tell you it's a very expensive fix. With just the model and serial number of your TV, an easy 5 minutes will get you the answer you are looking for.
May 03, 2011 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Toshiba regza 47" flat screen last night i was
Check your power cable. Unplug it from both ends and plug it back in
Mar 05, 2011 | Toshiba REGZA 47HL167 TV
Tv won't turn on
you might want to hook it straight to the wall plus the surger may be fried even though it turns on it may of messed your tv up so i would try that if not then get back with me and i'll try to help more
Jun 07, 2009 | Toshiba REGZA 47WLG66 47 in. HD-Ready LCD...
Televison & Video Logo
82 people viewed this question
Top Televison & Video Experts
Electro Med Services...
