Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA HD52 Color has a a lot of Red
I have a RCA HD52. The Color changed to too much red? Had been working fine until the afternoon I notice the people look to have more red in their skin tone? What would case the problem and what do I need to do?
  • 3 Answers
In the fron of the speakers there is 3 Ic (microchips) called CRT IC's you need to remove it and replace it since you wont know wich one is bad is better if you replace all 3 it cost about 15 dlls each if you take it to a tv repair guy they charge about 400dlls but you will need a solder iron and some solder is really simple Good Luck make sure to add some heatsink compound to the heatsink
Posted on Jan 12, 2009
How do you adjust color on a RCA D52W20B other than the remote?
Are you running component input on this--If so, make sure the red cable has not worked loose or gone bad.
Apr 28, 2014 | RCA Televison & Video
I bought a new TV and hooked up the Wii like I normally would and when I turned it on and was looking at the selection screen, (game, netflix, other various things) I noticed that the Netflix icon was...
Hello.
Try inserting the RCA (yellow, red, white cable) into a different port. There are usually an RCA port at the back and at the side of TVs. You can also try interchanging the RED and WHITE cable and see if the problem will be transferred to the WHITE cable, then you will need to replace the cable.
Aug 06, 2011 | Video Game Consoles & Games
My picture is gone crazy
Call a good TV Tech and have him replace the color wheel assembly.
Jul 29, 2009 | RCA HD50LPW175 50" HDTV
Color ghost
Sounds like your convergence is off. Go into your menu and try setting your convergence. If you can not move any of the colors you need to have your convergecnce amplifers replaced
Apr 08, 2009 | RCA HD52W56 52" Rear Projection HDTV
Red color absent from projector picture
try to use another vga cable connector ther might be a cut on the red color signal try to move the connector form left to right until it gives you the red color if it does change your vga connector hope this help you on your problem thanks
Feb 04, 2009 | InFocus ScreenPlay 4805 Multimedia...
2600n prints greenish little reds
i have priner hp laser jet 2600n but it is printing very low any pic if i print it is come very low color i changed toner cart but still same problem.
Sep 03, 2008 | HP Color LaserJet 2600n Printer
RCA P46921. Just changed flyback.
First, this assumes nothing else is going on to cause it. Here's what I did. Go to the 'green grid' via the v76 menu and go through the alignment there. Notice that there are red letters, blue letters, and a green grid. While you are in this screen, adjust the red, green, and blue focus watching the individual color's item until they are in focus. If they won't focus here, they won't focus and you have something else wrong (what I do not know). Then, return to normal programming, then select menu on the remote, then screen, then adjust projection tv convergence both horizontal and vertical crosshare. That ought to get it.
Mar 16, 2008 | RCA P46921 46" Rear Projection Television
The color in my tv is changing
Sounds like either the red crt drive bd is failing or the red crt may be shorting. Either way this is not an easy problem and will require a qualified professional to diagnose.
Feb 21, 2008 | RCA HD52W56 52" Rear Projection HDTV
No power rca hdtv modle d52w14
Check the AC fuse...follow AC cord into set....find fuse in clip.
Be sure to replace with correct amperage value................T.
Dec 24, 2007 | Televison & Video
RCA MM36100 color problem
sounds like you have a deguassing problem with your TV .. have the repair person bring out a deguassing coil and see if thsat helps.. This will only be a temp repair as you will have to have the problem that caused this to be fixed. good Luck
Aug 12, 2006 | RCA MM36100 36" TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
