Question about Acer Aspire One Netbook
Acer aod257 freezes up after about 10 minutes. runs hot. Any ideas?
Picked up a used acer one d257 an after about 10 minutes the system freezes. It seems a bit warmer then my other acer netbook. Motherboard bad? Bad cpu?
  • Acer Master
  • 32,281 Answers
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Posted on Dec 04, 2012
SOURCE: Acer Aspire One AOD250 Netbook Built-in Webcam problems....
try this it sometimes works. 1. Start Registry Editor (Regedit.exe). START > RUN > (Type) REGEDIT (and hit ENTER) 2. Locate the UpperFilters and LowerFilters value under the following key in the registry HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{6BDD1FC6-810F-11D0-BEC708002BE2092F} Write down the upper & lower filter valuse. Delete the UpperFilters and LowerFilters value (it's safe, and if could be restored later on if you have written it down, so don't worry)
Posted on Feb 18, 2010
  • 30 Answers
SOURCE: I can't connect to the internet on my ACER Aspire
Most Acers use an IPN2220 Wireless card. If yours does and your router is using WPA or WPA2 (TKIP or AES) security then you'll need to update the driver by searching for it manually using the Custom button (Hardware) in Windows update (instead of Express). This driver is not part of XP service pack 2 or 3. In my experience if you don't update to the newest common form of home wireless security (WPA2 AES) then the older formats seem to become unreliable
Posted on Mar 25, 2010
SOURCE: My Acer netbook aspire one just shut down on its own
You may have a Virus, try a factory restore. As you know, the Acer computers and those of other manufacturers are now delivered with a system of restoration installed in a hidden partition of your hard disk. This system launches out while pressing keys ALT+F10 simultaneously. And sometimes for various reasons this system ceases functioning.
The first cause often comes owing to the fact that function D2D Recovery is disable in the bios (menu principal).
The solution : enable the function and try to press keys ALT+F10 during the starting of the computer.
The second cause : in this case hidden partition PQSERVICE was erased or damaged, or you replaced the disc and in this case it is not present.
The solution : If you did not previously make a backup of your system by making an image disc. It will not be possible to use the D2D recovery. Your only hope will be to have in your possession Acer Recovery CD/DVD.
And the third causes : the Acer Master Boot Record (MBR)was damaged or replaced by non-Acer MBR. As long as partition PQSERVICE is present or that you can put the hand on the necessary Acer files you can reinstall the MBR of Acer.
The solution :
First method : on a functional Windows system:
1 disable the D2D recovery option of the bios.
2 open a Windows session with an account administrator.
3 Download, unzip and launch partedit32(registration required for download).
markymoo: ptedit32
4 Identify the Pqservice partition by its size (at the bottom of the partedit window there is a partition information box) it is a small sized partition approximately 2 to 6 Go.Once made change the type of your partition into 0C and save. Restart and open a session with an administrator account, you should be able to navigate to the PQservice partition. Seek these two files mbrwrdos.exe and rtmbr.bin once localised open a command prompt and launch this command mbrwrdos.exe install rtmbr.bin, this will install the Acer MBR. Close the command prompt window restart again Windows go into the bios and reactivate the D2D recovery. Now ALT+F10 should launch Acer recovery at the starting of the computer.
Second method : On a nonfunctional Windows system.
For that you must use a Linux distribution (for me Mandriva provided all the tools necessary).
1 Boot on the Mandriva install CD/DVD the boot menu will give you the possibility to repair or to restore the Windows boot loader.
2 If that is not enough launch an installation of linux(this will be an occasion to test this terrible OS) and choose LILO as boot loader(a boot menu that allow you to choose between several operating systems) once finished the installation. Restart your computer in the boot loader menu system you will have at least 2 Windows options the first generally point to PQservice choose it and you will boot directly into acer D2D recovery. __________________
Posted on Apr 06, 2010
Testimonial: "Thanks... It isn't software or virus because if I leave it at a DOS screen, it dies in 25 sec also. I tried your suggestions but it died in 25 sec"
  • 7 Answers
SOURCE: Hello i have an Acer Aspire One model zg5 netbook
You're going to need to boot it from the Windows XP installation disk, which means if you don't have a CD drive you'll need to get an external CD-ROM drive. This will fix the problem.
Posted on Oct 10, 2010
josema_sv
  • 485 Answers
SOURCE: Hello! I have an acer
Please try removing battery for a moment (getting cold) and install it again, don't forget to connect charger, after the charge is completed try to turn it on, if there's no motherboard failure the computer should work normally, but if not, maybe you have a "fried" motherboard that needs to be replaced.
Posted on Aug 11, 2011
Acer d257 wifi is not working after reinstall
try latest driver . check also if airplane mode is on !
http://www.acer.com.au/ac/en/AU/content/drivers
find wi fi driver for your d257 use serial number or model number. You may need to open cover on bottom of laptop to see which rf board is being used in your laptop as I found a aod257 but it had three possible wi fi drivers . but aod257 may not be your model number.
select the correct operating system in the web page
Oct 08, 2014 | Computers & Internet
Wifi driver for acer aspir one n455
There are several: http://us.acer.com/ac/en/US/content/drivers/3659;-;AOD257
Jun 05, 2014 | Acer Aspire One D257-13608 Intel Atom N455...
Why i cannot install any of OS ?
Have you tried loading the bios and changing the AHCi to IDE or vice versa!
Jun 01, 2014 | Acer Aspire One D257 Netbook
I cannot install any of OS!
That's a sticky wicket. Windows can be finicky. It might be easier to install an open source OS before installing Windows if you still want to. I have limited experience installing an OS on an Acer D257. I accidently erased WIndows while trying to dual boot Mint. I like Mint 16 better anyway because it doesn't have all the lost time of Windows installing updates and system repair stalls because the battery ran out don't happen etc. Mint is cool and free online for download.
Linux Ubuntu is also free and very easy to install. If you install Mint first then install Ubuntu it is fairly simple to dual boot and have two operating systems.
It is possible to dual boot Windows 7 of course, yet Linux is free online so if you botch it another try doesn't cost anything, while if you lose Windows 7 or Windows 7 Starter and lose the product key it can cost quite a bit to replace it. In some future Universe Windows might make its O.S. available free for home versions and charge a low price annually for using it and receiving upgrades etc. That would make it easier to dual boot with other systems. Mint 16 has everything Windows offers essentially except for the Windows Movie maker. I had a lot of trouble getting the free app movie makers to work in Mint for some reason.
http://www.linuxmint.com/edition.php?id=157
Mint has a lot of free apps that accomplish everything Windows has.
My acer aod257 just halts not give any hash
Does it display anything? You need to provide more information.
May 08, 2014 | Acer Aspire One D257 Netbook
Aspire one d257-13473 wont factory reset
Windows key > All programs >Acer Empowering Technology>eRecovery management>Restore>Factory(Top of list)..
Or
If computer will not boot.
Tune computer ON
When Acer splash is on screen hold Alt and keep pressing F10...
Select factory from top of list.
You will need a password , the default is "000000" (Six zeros).
Recommend you use the first option if you can...
1. Power on the machine.
2. At the ACER BIOS screen, hold the "Alt" key and press the "F10" key simultaneously to start Acer eRecovery. The window of opportunity is very small, so this may take a few attempts.
3. Once eRecovery has loaded, click "Restore to Factory Default Settings" (the password is six zeros, 0.0.0.0.0.0.).
4. Click "OK" to continue.
5. From here, the eRecovery process will update all the data on the C: drive and restore the factory image (approximately 10 minutes).
6. Once eRecovery has run, press "OK" to reboot unit.
***This will erase all your unsaved data!***
Or
Running System Recovery from Windows
1. Click Start>All Programs>Acer Empowering Technology.
2. Select Acer eRecovery Management.
3. Select Restore (bottom of eRecovery screen).
4. Select Restore system to factory default (the password is six zeros, 0.0.0.0.0.0.).
5. Select Yes then Next, the system will reboot and start the recovery.
Or
1. Reboot, and press F8.
2. Select Repair.
3. Select Reinstall Windows and follow prompts.
Dec 06, 2013 | Acer Aspire One D257-13473 Netbook
There is missing system configuration option in acer AOD257 bios
Search for a recent update for your bios. You can also try a different bios all together. Google "Acer AOD257 BIOS Upgrade" and "Acer AOD257 compatible BIOS". I remember my old BIOS having very limited options available. The BIOS I use now has two pages of options. Hope I was able to help!
Jan 30, 2013 | Acer Aspire One D255-2670
I have acer AOD257. before i have a acer crystal eye webcam but it suddenly stop working.everytime i open it says
The oiriginal Acer webcam was providied by the manufacturer as a software program to be used by microsoft! After the warranty expired, I installed windows 7 and the camera disappeared! What does that tell ya!
Nov 01, 2012 | Acer Aspire One D257 Netbook
Acer aspire one d257-13608 freezes randomly
It's likely to be the BIOS that needs updating. Full solution and link to get the stable BIOS flash is here:
http://blog.robkershaw.com/2012/01/acer-aspire-one-d257-freezing-issue.htmlhttp://blog.robkershaw.com/2012/01/acer-aspire-one-d257-freezing-issue.html
Sep 07, 2012 | Acer Aspire One D257-13608 Intel Atom N455...
I cant find the PCI controller drivers and the Video Controller drivers. My netbook is Acer Aspire D257.
Just install the VGA drivers for your netbook.
Assumption OS for you netbook is Win 7.
Acer Aspire One D257(AOD257) Windows 7 Drivers Download. ->(Download VGA_Intel_8.14.10.2230_W7x86_A.zip)
Click on Link : Download
Hope it helps.
Jun 17, 2011 | Computers & Internet
Acer Aspire One Netbook Logo
199 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
