Question about Kenmore Dryers
My dryer stopped and a click sound heard around the timer when the start button pushed. There is power. A few experts says it seems to be the thermal fuse.
It took me several days to open the panels, because the back panel of my model cannot be opened by unscrewing like in the videos shown a lot in the YouTube. It would have been really easy in that way. I finally opened the front panel below the laundry door AND the control panel on top of the machine. I know I didn't need to open both, but I didn't know which to open because some say it's next to the thermal unit and others say I need to open control panel. OK, now I hope I am almost there. Where is the fuse located?
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
What is the complete model number of your unit?
Posted on Dec 04, 2012
  • Harry Goh Dec 04, 2012
    I cannot find it. There seems to be no model number anywhere on the machine. Where can I find it?
  • Richard Roth
    Richard Roth Dec 04, 2012
    Look in the door area.
3 Suggested Answers
  • 172 Answers
SOURCE: control panel looks ok but dryer wont start
Sounds like an electronic problem on the timer circuit board.
Posted on Aug 12, 2009
  • 574 Answers
SOURCE: The controls will not come on when I press the power button
if you tapped on it and it work then you have a loose connection somewhere
Posted on Aug 27, 2009
Just stopped working. No burning smell. When start button pushed, some kind of tiny "click" sound heard around the timer.
The click is most likely the timer motor moving the dial on the timer. The motor circuit on American dryers is 120 volts whilst the heater requires 240 volts to operate its 5k element. The motor circuit always has the fuse in it. The heating element has limits mounted on it but they only kill power to the element and not the motor. Fuses are usually located on the blower housing next to the control thermostat. MORE HERE
Nov 29, 2012 | Dryers
Our Whirlpool Model LEQ9858PWO just stopped working. It sounds like the function timer might be running and the start button has it's first click when pushed. With the dryer door open and holding the...
The problem is usually caused by a blown thermal fuse. Disconnect power then access and bypass the thermal fuse on the blower housing. The blower housing is located on the rear left bottom.
Bypass the thermal fuse by disconnecting the wires and connecting them together. Insulate them properly and plug the dryer back in. The thermal fuse is indeed blown and needs to be replaced if the dryer starts. Do not use the dryer with the thermal fuse bypassed due to fire hazards.
Dec 29, 2010 | Dryers
The dryer will not start, you can hear timer.
your problem could be : Door switch, Motor, Thermal Fuse, Timer.
I would start with Door switch and Thermal Fuse.
Jan 07, 2010 | Dryers
Just stopped working still has power-inside light comes on and timer makes noise when you turn dial but does not start when you push start button
This sounds like the door switch. But it could also be the non-resettable thermal fuse inside. Open the door, depress the door switch until it clicks, and while holding it in see if the dryer starts.
Jan 05, 2010 | Whirlpool Dryers
Dryer Won't Start
Make sure it has power. Then:Check the door switch. A little lever sticking down through top right of door opening. If it is not there you will need new door switch(sometimes the little lever breaks off). If it is there and does not click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
May 27, 2009 | Kenmore 73952 Gas Dryer
My whirlpool LGQ8611LW1 Dyer won't start.
Johnny i dont know the machine, but with photos i might be able to help
May 10, 2017 | Dryers
Won't start
Hi check the thermal fuse at the rear of the dryer It looks like this 00208689.jpg
Dec 16, 2008 | Maytag PYG2300A Gas Dryer
Dryers Logo
47 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
