Wiring schematic for heil heat pump Model # CH5024Ukb3
  • 230 Answers
SOURCE: RTH7400 thermostat installed-screen display unlit-used
w2 and y2 are used for 2stage applications
w2 = 2 stage heat
y2= 2 stage cool
If your system is a single stage system, look for the y1 and y2 terminals. If the thermostat does not have y1 and y2 then you may have the wrong thermostat. As always, please read the directions carefully. Thanks!
Posted on Jul 03, 2008
jumptrout51
  • 3361 Answers
SOURCE: where can i find wiring schematic for goodman heat
Inside the terminal cover of the control panel.
Posted on Sep 26, 2009
koolbreezes
  • 540 Answers
SOURCE: When to change from heat pump to alternate heat
We says the outside can pull heat out of 40* air, below this change to emergency heat or it should do this with the thermostat on its own.
Posted on Dec 14, 2009
atocrxr
  • 135 Answers
SOURCE: Heil Heat pump model # NHP218AKC2, I need the
I can help you on part of your question, the system that you listed above is a 1.5 ton unit, if I had the serial number I could give you the age of the unit. If it is a late 1990 model, then it is probably a 10 SEER unit, maybe a 12 SEER, if it is older than 1994 it will be a 8 to 10 SEER, but due to new federal rules, all new heat pump or air conditioners are at least 13 SEER. If you just replace the outdoor unit and leave the coil indoors, it will be mismatched and cause the unit to be less effeciant, and some problem in adjusting the Freon levels.
Ideal is to change the outdoor unit and indoor coil.
I hope this helps, I am new to this site, so I am still trying to get to the point, and yet give you the details that you need.
Sincerely,
Paul Gibson
Posted on Mar 31, 2010
Testimonial: "Thanks for the advice!"
  • 4 Answers
SOURCE: I need a wiring schematic
Contact carrier. Give them the specs and they will send u a electrical schematic
Posted on Apr 06, 2011
How long is the compressor in my heil max pro 10 waranty good for
Not sure which model number the Heil Max Pro 10 warranty uses. Heil will usally place the model number on the side of the outside unit or inside the cabinet for thee Inside unit. Click here for a direct link to=> Heil HVAC
Use care when reading any warranty because the wording is mostly written so you do not understand.
To help you decide which Heil product and warranty protection is best for you, select from the following at-a-glance comparisons.
Please let me know If I can help you with other question, Thank You, Sea Breeze
Aug 31, 2011 | Heating & Cooling
Dec 12, 2009 | Amana PTH123B25AJ Heat Pump Air...
Heil furnacwe wiring.... no idea
C= common-usually blue or black wire
G= fan-usually green wire
Y= A/C-usually yellow wire
W= heat-usually white wire
R= Hot side of transformer-usually red wire
Mar 24, 2009 | Kenmore Heating & Cooling
Old Ruud Air Conditioner
all heat pumps follow the same schematics universal get a hold of any heat pump schem and you should be able to aplie it to yours
Jul 03, 2008 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
76 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
