Question about Dryers
WIRING DIAGRAM DRYER DOES NOT WANT TO HEAT
    Top Expert:
  • Dryers Master
  • 9,472 Answers
What is the complete model number of the unit?
Posted on Dec 04, 2012
NO HEAT FROM ELECTRIC DRYER
What kind of dryer is it? maytag has a battery that needs to be changed periodically. Check out your model number, type of dryer and do search for wiring diagram. or look on back of dryer for diagram.
Oct 31, 2011 | LG Dryers
The air blows but there is no heat. damn thing is only year and half old and samsung will not help
Unplug the dryer. Remove the control panel on the top. Look inside for a sheet of paper with the wiring diagram or service instructions. If you don't find one there, look on the back cover panel. (Every US appliance maker provides this, but I've never looked inside a Samsung dryer so I don't know about their practice.)
If you find the wiring diagram, you can use it to identify the wires going to the thermostats and heating elements. Now you can use an ohmmeter to check which part is open; the wiring colors marked on the diagram will let you find the terminals in the control panel going to the thermostats and heaters so you don't have to take everything apart for diagnosis. Note: in a typical dryer, if you get no heat on Medium, but you get heat on the Low setting, you already know the Medium heat element is burned out. High heat uses both elements.
If you don't find a wiring diagram, you will have to look for the thermostats and heater terminals. Usually there is a thermostat mounted on the door frame at or near the top of the opening to the drum. There will be a second thermostat mounted on the top of the heater pan or box. Usually these are supposed to be closed (you get continuity) when they are closed. The heaters should show some resistance, but should not be open.
If you find an open circuit from the control panel, it doesn't mean the part itself is bad; it could be a problem with the wiring terminal connecting the part. This is often obvious when you see it; the insulation at the terminal will show signs of overheating.
May 30, 2011 | Samsung Dryers
Maytag LSG 7806 Electric Dryer doesn't heat up how can I get a wiring diagram
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 30, 2010 | Maytag LSG7806A Front Load Stacked Washer...
Dryer will not heat up. can not get the top of dryer off to look at the wire diagram to be able to check fuses. MOdel FSE446RHS2 Frigidare.
I have the wiring diagram directly from Frigidaire. All you need is adobe acrobat reader to use it. It has a parts breakdown as well as the wiring diagram. However I can tell you that there are 3 inside this dryer one at the top back left portion of the dryer. the thermal limiter. One on the heater housing. And one on the blower housing.
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Webster/5995381570.pdf
Nov 07, 2009 | Washing Machines
Dryer tumbles but not heat
here is the link for the wiring diagram... heat is definatly on a separate circuit.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5174194
May 25, 2009 | Maytag MDE308DAYW Electric Dryer
My whirl pool dryer does not dry?
coil never gets power usually a sign that you have a blown thermal fuse , small white 2in' fuse located behind rear panel, there should be a wire diagram behind the console, few screws acrosss the back
Oct 30, 2008 | Dryers
Hotpoint dryer plus 9303
hot point dryer plus 9303 not heat everything else ok
Jan 01, 2008 | Dryers
Kemore Dryer / Model # 63742
I'm not familiar with this specific Dryer, but in most of them you can find their wiring diagram glued under the upper panel or the rear panel. Good luck !
May 16, 2006 | Kenmore 64742 Electric Dryer
Dryers Logo
29 people viewed this question
Top Dryers Experts
